Question about Pioneer Car Amplifier GM-5100T - 2CH 760 Watts Car Audio Amplifier
Mosfet 760 watt pioneer amplifier
When i first hooked up my amp it worked great. had some awsome sound coming out of it but the one day when i started my truck it was no longer working. the light is on and all the cables look to be good. no fuses blown either. sometimes it will make a loud thump noise in my subs but no sound from the actual stereo.
  • Anonymous Mar 29, 2009
    the blue light comes on for a sec then turns off
  • 3 Answers
Check all ground cables from your truck's stereo and amplifier as well. Sometimes when ground cables get loose you hear those thumping noise in your subs. GOOD LUCK!!
Posted on Nov 06, 2008
Thoght i coukd...
Posted on Oct 20, 2008
Channel A wont work
check to see if the signal to the amp is low pass and check to see if the switch is on high pass.. if all checks out send the amp back .. if u want to repair it email me at steven007_maharaj@hotmail.com and i would tell u how
Jun 14, 2013 | Pioneer GM6500F 760 Watt 4 Channel...
I have mine hooked up to two 12in pionners it worked fine and then after about a year everytime they hit it will blow the fuses
So maybe that amp isn't made to go or take that much amount of power. It is only a 760 watt so i would say you might want to think about upgrading. Also check your battery wire and your ground wire
Jan 20, 2010 | Pioneer GM-5300T Car Audio Amplifier
No bass coming out
u probably have to replace the rca inputs on the amp or resolder the short on them if u can
Aug 31, 2009 | Pioneer Car Amplifier GM-5100T - 2CH 760...
Power problem amp
Sounds like its going into protect mode-try disconnecting the speakers from the amp entirely and turn the system on if it stays lit up- then ya know its the speakers (one of them at least) thats making your amp shut itself down. If thats the case look into replacing the speaker thats causing the problem.Also make sure that you have sufficient wiring to your amp - at least 8 gauge if you can. check all terminals /power/ground make sure everythings connected tight and not grounding out anywhere
Mar 29, 2009 | Kenwood KAC-9152D Car Audio Amplifier
There is no sound coming from my 15's when my stereo is on
it is Either the RCA Jacks or the Blue Remote Lead Wire is Bad or Loose in the Harness inside the Dash. Please Rate My Response! Thanks!
Feb 03, 2009 | Pioneer Car Amplifier GM-5100T - 2CH 760...
Support Question about RMS
you are going to need an amp that can supply the right amount of rms power to make it sound good. these sony subs are rated for 380 watts rms. so in order to find an amp that will supply two, you must multiply that figure by two. so you will need an amp that can supply around 500 to 750 watts continuously (or rms). also you are going to want an amp that is either class d or class ab rated. these amps are built to push subwoofers exclusively and will give you the best efficiency and sound out of your subs. you will also want to get an amplifier is a monoblock amp, and not a stereo amplifier. make sure the amp can put out that rms rating at 2 ohms as two 4 ohm speakers equal 2 ohms wired in parallel. i have a kenwood kac9152d that puts out about 2000 watts max at 2 or 1 ohms (900 watts rms) that i used with my two sony xplod 10's for about 2 years. it was kick ***! now i dont know if you need that much power but they will handle it as long as you dont push them too hard for long periods of time, otherwise you might end up blowing them up! (depending on the box size that is, and the quality of it as well...)
i have years of car audio installation experience and can help with setting up and wiring any mobile entertainment system you can imagine. may i ask what kind of music you listen to and what kind of box do you have for these subwoofers?
if you have any questions email me at thadoggma420@hotmail.com
Jan 22, 2009 | Pioneer Car Amplifier GM-5100T - 2CH 760...
Hits intemittently
ive had problems kinda like this ... normaly its a crossed or reversed speaker wire check the positive and negitive wire into the speakers "they move sometimes when there is more air moving around the speaker"
second make sure you have the impedence correct "possitive to positive negitive to negitive'
hope this helps
Dec 21, 2008 | Pioneer Car Amplifier GM-5100T - 2CH 760...
Improper function
try hooking up your subwoofers in series. then connecting them bridged to the amplifier. as follows: positive from sub#1 into positive of amplifier left channel.. negative sub#1 into positive sub#2. negative sub#2 into negative amplifier right channel. turn the gain down as this will sound pretty loud.
Jul 13, 2008 | Pioneer Car Amplifier GM-5100T - 2CH 760...
Pioneer Car Amplifier GM-5100T - 2CH 760 Watts Car Audio Amplifier Logo
1,048 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
