I have a Brookstone digital picture frame that refuses to complete the boot cycle. It appears to get about 3/4 of the way through before locking up with the status bar and the big Brookstoneon in white on the blue screen. It is an model AH1812-B I have a similar problem with the Brookstone 10" Digital Picture Frame Model AH1812-B. The power connection in the back displays a green light when plugged in but it does not power on when I press the Power On button as directed in the instructions. It worked correctly for a few months. As others have reported, Brookstone will not honor the warranty even though I have the credit card statement as proof of purchase.
  • 2 more comments
  • tx_walkers Dec 07, 2008
    Same here, is there anyway to fix this, or is this thing useless now?
  • Ron Tulsa Dec 21, 2008
    Mine would not work out of the box. I took it apart but I couldn't see anything. I reattached the cables. It almost seems like they forgot to flash mine! :)
  • shalomyaes Jan 03, 2009
    I have the sam problem the green lights is on however the unit can not power on.
  • Anonymous Jan 28, 2009
    I have the same problem. When I hook it up to my computer, I can see that the pictures are still in the frame memory but I just cannot get past the "insert media" screen on the frame when I turn it on.
TampaNative
  • 778 Answers
SOURCE: Gateway FPD1960 TFT works with laptop, not desktop
Elbtax,
Click start > right click on "My Computer" > Properties > Hardware tab > Device Manager button > Display adapters > Right click on your device and select uninstall and re boot your computer. Windows should pick up your adapter and re configure it automatically. This method should Fixya!
Good luck, and let us know how it goes.
Posted on Mar 18, 2008
bammbammfran
  • 159 Answers
SOURCE: Power Light Blinking & Black Screen
A blinking blue light indiactes that your power-inverter board is not putting out what it should. It needs an overhaul which may be a simple as changing out the capacitors on the boards.
It could go beyong that to transistors or even a bad bulb.
It will have to be opened up to do that.
A picture may show visual signs of damage. If you can take one and email it to me , I'll take a look.
Fran
Posted on Oct 18, 2008
SOURCE: No Power
This is a very common problem. Theres a guy on ebay that will fix it for you for 24 bucks plus 5 bucks shipping. When you open the monitor, on the back panel there are 2 boards. One is a power supply board, the other is the interlogic board. The power supply board is where the problem is. I do not know the exact component that needs replacing as I did not test this yet. I do not have the proper test equipment. For 24 bucks, I'm just gonna let the ebay guy repair it. I will report my results here when I get the board back. I'm also gonna mark the components so I know what they replaced.
Posted on Oct 24, 2008
  • 1684 Answers
SOURCE: LG L226WTQBF black screen with blue light on power on button
It sounds like you have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of the monitor. If you are good at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Posted on Jul 14, 2009
SOURCE: LCD blank screen, blink white
blank_page Use a reset sequence on the monitor-
1. turn off monitor
2. unplug power
3. plug power back in, holding down the last button on the left, then push the power button to turn back on and off three times, holding on the third try until it comes on- hold for ten seconds and release; the monitor should work again
Posted on Aug 14, 2009
COBY DP853-1G CALENDAR AND TIME NOT LOCKED
SOLVED The remote control was inconsistant, apparently a bad battery. Set up is now complete.
Dec 26, 2009 | Coby Electronics DP562 Digital Photo Frame...
Brookstone my life pocket album error
I had the same problem. I lwas able to load more pictures because I bypassed the function. It is easy. Just open the resized picture file on your computer, then, copy (control c) the pictures you want, and then open the photo album device through "my computer" and paste into the appropriate album. My digital photo album was listed as F Drive in my computer.
Feb 06, 2009 | Tao MUSIC SPECTARE 5.6 DIGITAL PICTURE...
Cant copy any pictures from computer
You can start copying pictures to SV811 digital picture frame if you get the message “Use PC interface to copy files.” Here are the steps:
Copy pictures, videos, and music between your frame and computer, using your computer's normal file copying tools:
1. Connect the USB cable from the frame to your computer
2. On your computer, open My Computer or Windows Explorer.
The picture frame appears as removable drives—one drive for each connected picture source in the frame, in this order: internal memory, memory cards, and USB devices.
3. Navigate to the pictures you want to copy. Then drag and drop them to the new location.
4. Unplug the USB cable to view your copied pictures.
Copying pictures from EasyShare software:
1. Install EasyShare software (free download at www.kodak.com/go/sw )
2. Connect the USB cable.
3. On your computer, open EasyShare software. Select the pictures in My Collection and drag them into the Picture tray.
4. In the menu bar, select File and then Copy to the Kodak Drive letter.
5. Select the frame source to which you are copying.
6. Select Best for Digital Picture Frame to reduce the resolution of the pictures you are copying. Full resolution is unnecessary and quickly fills up the frame's memory.
7. Click Copy. Pictures are copied to your frame.
8. Unplug the USB cable and press “Home” icon to navigate to your copied pictures.
Feb 03, 2009 | Kodak EasyShare SV811 (8858946) Digital...
My kodak ev1011 pic frame stopped working
You may try the online troubleshooting guide at www.kodak.com/go/itg and if it does not resolve the issue at the end of the guide you can fill out a form to send the frame for repair and also just an FYI the frame is warranty for one year and you must a copy of your receipt before sending the frame.
Jan 08, 2009 | Kodak EasyShare EX1011 Digital Picture...
Photo resizer software
you are very stupid man!!!! i'm sorry:" me cagas""
Dec 30, 2008 | Tao MUSIC SPECTARE 5.6 DIGITAL PICTURE...
I can't transfer pictures from my computer to my digital frame. When I connect my usb cable to my computer from my digital frame , the frame displays "Connected to computer. Use PC interface to copy files....
Dec 26, 2008 | Kodak EasyShare SV811 (8858946) Digital...
I'm trying to transfer pictures from my computer to the picture f
Dec 20, 2008 | Kodak EasyShare SV811 (8858946) Digital...
I have a Brookstone digital picture frame that stopped working
I have encountered this same error on the frame I bought 2 years ago. I saved the pictures to a backup and then reformatted the frame - this didn't work - does anyone have any other solutions???
Nov 22, 2008 | Tao MUSIC SPECTARE 5.6 DIGITAL PICTURE...
The solution I suggest is to never buy anything from Brookstone again. I definitely will not.
Sep 11, 2008 | Tao MUSIC SPECTARE 5.6 DIGITAL PICTURE...
I have a Brookstone digital picture frame that refuses to complete the boot cycle. It appears to get about 3/4 of the way through before locking up with the status bar and the big Brookstoneon in white on...
cheap **** - Really Brookstone? No reset? No way to format? Crappy warranty? Poor workmanship? No software that resizes your images so they won't crash your picture frame? screw you guys, I'm never shopping here again
Jul 14, 2008 | Tao MUSIC SPECTARE 5.6 DIGITAL PICTURE...
Computers & Internet Logo
194 people viewed this question
David Payne
David Payne
