Administration problem I can not save anything on the hard disk because Window Vista don't let me do it. It always says I need the permission of the administrator. I'm the one and only user of my Laptop computer. Please tell me what to do. Thanks
  • A Womans Computer Man
    A Womans Computer Man May 11, 2010
    well..log into the user panel on control panel, and see if you are listed as a admin person, or a usual user.
    Scholar:
  • 87 Answers
Go to Start then Log Off.
Log on as Administrator, there should not be a password, unless you or someone else set one. Once logged in, go to Control Panel then set your User to be an Administrator.
Posted on Oct 29, 2008
Remove write protection lacie disk
How old is the drive and has your set-up always behaved exactly the same way or what's different now, please?
Does this happen only with Word files or what?
Is that LaCie's own Disk Utilities, or what Mac OS are you using which pluralizes that?
Nov 05, 2017 | LaCie Computers & Internet
Windows cannot access specified device path or file you may not have the appropriate permissions
Is your account an "administrator" account? This is important in 7 as well as Vista.
Also, did you install whatever it was to an external drive? If so, Windows 7 is bad about changing drive letters of external hard disks every time you restart. If this is the case, click your start orb and right click on "Computer" then left click on "Manage."
In the left pane, there will be "Disk Management." Click on it and give it a second for everything to populate. There are a list of all your drives in the middle towards the bottom. You can right click in their partitions and left click "change drive letter." From there you can change them back to what they where before and things will start working again.
As far as permissions go, they're a pain if you change stuff over manually. But, there is an easy way if you know specifically what folder or file you need permissions to use:
Add Take Ownership to Explorer Right Click Menu in Win 7 8 or Vista
This will add a right click context item where you can seize permissions quick like. It's SUPER handy.
Mar 07, 2014 | Microsoft Windows 7 Ultimate for PC
Permissions read
Select the disk. folder, or file and choose File>Get Info. In the Get Info window, choose sharing and permissions pane to change.
Sep 15, 2013 | Samsung G3 Station Desktop External Drive...
I have a mac and a new iogmega external drive, 500g. I cannot move any files onto the iomega or save them. I get messages such as "that file does not exist" to iomega can't be modified,...
With the drive plugged in, going into your Applications ' Utilities ' Disk Utility Select the drive and press Verify Disk, Repair Disk and Repair Permissions. If you don't have anything on the drive right now, try formatting it with the Mac OS Extended (Journaled) file system from the Disk Utility.
If that doesn't work the drive may be damaged. If you have another PC / Mac, trying plugging it in and see if it works there. If the drive is under 1 year old it should still be under warrantee, in which you could return it / RMA and get a new one sent back from the manufacture.
Regards, Chris
May 31, 2011 | Iomega (33090) 250 GB Hard Drive
Window cannot access the specific device,path,file. dont have appropiate permission
Ok this happens when the user account don't have the permission to acces the folder, disk etc.
Verify that the account you are using have the permission to access it. Right click the object you are trying to access and choose properties, then security (I don't know your window versions but is very similar in all versions). Check if the user account show in the box and the type of permission. If is not in the list should be add. To add you need administrator account privileges. çlick edit and add the user and the type of permission to grant. gabytek_1.gif
May 23, 2011 | Samsung N13013B Netbook
I have recently upgraded my Mac from OS 10.4 to 10.6.7. Since then I am no longer able to save my daily back up on MYOB Accounting (Version 16.12). The 'save as' box appears with the details of...
Sometimes when systems are updated disk permissions can get out of sync which can cause problems. What I would do is go to the utilities in the applications folder, open disk utility and click on your hard drive in the left hand box and then click on verify disk permissions button and once run, then if anything has come up click on repair disk permissions. Hope this helps.
May 06, 2011 | Myob Computers & Internet
Hi My system speed is getting low. I have no registry cleaner or CCleaner (as in window) What is similar for MAC-OS? Kind regards
I would first try repairing your disk permissions. Go into Disk Utility, then click on your internal hard drive. (Not Macintosh HD, the one above it) Under the first aid tab, click repair disk permissions. If that is grayed out, then click verify disk permissions.
Feb 12, 2011 | Apple Mac OS X 10.4
My startup disk is full and the page is blue...what can i do..?
Start the laptop using the install disk by inserting it and pressing (and holding) the "C" key immediately after you turn on the computer. This will allow you to inspect your hard drive, clear some space and run Disk Utility to verify the internal hard drive.
Once you have a desktop, press command (apple) and "N",
1. Open the Applications folder.
2. Open the Utilities folder.
3. Launch Disk Utility.
4. Select "First Aid" in the bar in the upper middle of the window.
5. Select your laptop's internal hard drive from the list on the left of the window.
6. Select "Repair Permissions" in the lower center of the window. The software will check your permissions files, correcting any errors. This should include the kenell issue that is preventing your laptop from starting.
This may take several minutes, so you can check the capacity of your hard drive to see if it is actually full (simply open the hard drive, the capacity should be listed at the bottom of the window).
If it is full, consider what to remove while permissions repair is underway.
Oct 11, 2010 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Can't acess hard disk and security options
You need to Login As an Adminstrator then change the sercurity settings
Oct 07, 2008 | Hitachi TravelStar 80GN 80 GB Hard Drive
External hard drive
I'm not overly familiar with Vista yet, but I believe that you will have to delete these as administrator. Use the Vista help menu, you'll find it there. If it's a program file you will need to uninstall, versus delete, from the add/remove programs in the control panel.
Jun 24, 2008 | Acer Aspire 5100 Notebook
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
