Question about Acer AL2032WD 20" Flat Panel LCD Monitor
Acer AL2416 LCD
I purchased a used monitor which when turned on is perfect and within a few seconds the screen switches into horizontal interference. when turned off and back on the same happens, any suggestions what might be wrong and how to repair-Thank you
  • 1,476 Answers
About a year ago I encountered the same problem with an LCD flat screen. It turned out to be a bad driver board but the customer did not want to spend the money to repair it. A good computer repair shop should be able to fix it for you. www.fixmymonitor.com would be a good place to start.
Posted on Jun 22, 2006
Bad power switch
warranty is onsite
call them they will come to ur place
Jun 03, 2010 | Acer X233H 23" Monitor
Screen turns off seconds after image is displayed
are using dvi cable is yoour out put on the cpu ok video out video card ect u test antehr screen on it test this one on differnt one if it bad its bad u cant usally get parts for these priotory
Feb 04, 2008 | Acer AL1916W 19" LCD Monitor
White horizontal lines flicker and screen goes off.
check the wiring inside the monitor, pull the sceen out and move the wires with the screen on so you can see when it's working. then tape the wires where it works.
Dec 16, 2009 | Proview PL926WBi 19" LCD Monitor
My monitor screen appears only a few seconds, and close but then blue light stay on. if i shut the monitor down and reopen it, the screen appears and close after a few seconds. can you help me
lacouche, You didn't let us know any history of this monitor!!! Was it working perfectly fine on Sep 19th 2009? How old is the lcd monitor? How many "on" hours of use can you estimate that is has seen? If you lived next-door to my house I could help you trouble shoot it and find out if the "switch-mode-power-supply' has a problem with swollen CAPACITORS--which may/may not cause a problem with the cold-cathode-fluorescent-tube's" electronic ballast circuit which is called ( in lcd monitors ) a INVERTER CIRCUIT. The new style CURLIE-Q screw-in-energy efficient CFL light bulbs use a cheaper electronic ballast called CONVERTER circuit. I suspect that either one or both circuits are at fault and causing the unit to go into SHUTDOWN mode. Well, I guess that the only one to help you will be someone at ACER, or maybe a local TECH can repair it for $40-$90US. Or if you investigate your problem you might(with a lot of luck) repair it for 15-20dollars. Anyway, Good luck. I'm louie12fix on fixya or lmistyrel @aol.com
Sep 26, 2009 | Acer Computers & Internet
Monitor displays the PC screen but switches off within 10 second
Unfortunatley your monitor is going out. I just had that problem. My sceen would come on, but after about 10min. it would blink off and turn black. I would have to hit the off button on the monitor, then turn it back on. It would work fine for a few minutes then black out again. I got a new/used monitor where I no longer have that problem.
I did check to make sure my hybernate was not activated, it wasn't, I had it set to never turn off.
Good luck.
Sep 02, 2009 | Rosewill R900J 19" Flat Panel LCD Monitor
22" Acer flat screen monitor
this sounds like an electrical fault or failing component, within the Monitor.
Check the cabling, to ensure it,s not damaged-broken-kinked et,c. by carefully moving the cable gently side to side and up and down.
If it puts itself right for a second or two. you can assume its a broken internal wire, within the lead.
Or a dry soldered joint-Connection.
Mike @ compurepair.
Sep 16, 2008 | Acer AL2216WBD LCD Monitor
Black screen
Hi
did you get a solution for this problem as mine does exactly the same!
Thanks
jim.ross@virgin.net
Aug 22, 2008 | Relisys RLT1720 17" LCD Monitor
Mounting an Acer AL2416 to the wall
Hello Poet,
I recently purchased two of the Acer AL2416W to mount onto a monitor stand. I ran into the same problem, it looks as though you have to remove the entire rear of the Monitor to take the factory leg off. I believe I was trying to make it too complex, just gently pry the rear cover off of the hinge this will expose 4 screws remove these and you are all set.
Mark
Jul 02, 2008 | Acer AL2416W 24 in. LCD Television
ACER AL 1716
There are two types of lines.
Lines caused by a bad LCD screen and lines caused by poor sync.
A bad LCD will cause perfectly straight vertical and horizontal lines that don't move at all. This is because the row and column addressing ICs have gone bad, so you will end up with rows or columns of bad pixels.
Poor sync looks more like what you are describing. The picture will flip vertically and horizontally.
Poor or missing sync can be caused by a bad video cable, or a bad IC on the main board.
If the monitor has a removable video cable, borrow another one from a friend to test if the monitor is working. If it works, head to your local computer store and buy a new cable.
If the monitor still doesn't work with a different cable, you may have a bad main board. The only way to repair the monitor will be to replace the board.
If you open the monitor, be sure to check for bad capacitors. They can cause all sorts of strange faults. Look elsewhere on this site for how-tos on inspecting capacitors.
If your video cable is not removable, there's not much you can do. You will need a way to test that each pin on the cable connector on the main board conducts to a corresponding pin on the other end of the cable. You can do this if you have a multimeter, or a continuity tester.
Mar 28, 2008 | Acer AL1716 17" LCD Monitor
Horizontal banding that looks like Interference
i would take this in for a service check could be issues that need resolving from a service standpoint not a simple driver or resolution fix
Dec 18, 2007 | Acer AL2216W LCD Monitor
Acer AL2032WD 20" Flat Panel LCD Monitor Logo
121 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
