MY Evesham TV keeps switching itself off - each time it takes less than 5 mins to turn off
4 Suggested Answers
  • 133 Answers
SOURCE: Sony TV keeps shutting down ever 5 mins
Could be loose connections on the board where the solder is expanding as it heats up causing a loose connection or something in the power supply or horizontal is over heating and your tv is going into shutdown protection . Good luck
Posted on Mar 03, 2008
SOURCE: My 50 inch hitachi projection tv keeps powering up and down.
First it is not an emergency.
No Legitimate repair company should be that busy.
Call Hitachi and get an AUTHORIZED Hitachi dealer to service your TV.
Your problem is beyond self help/
Unplug the TV until it is repaired properly or you will do more damage and have a much larger repair bill.
MR. TV Sales & Service Inc
Milwaukee Wisconsin 53405
(414) 762-8600
Established 1974
Posted on Mar 24, 2009
falspet
  • 438 Answers
SOURCE: where is the air filter on this tv ?? it keeps
the filter is located internal to the unit and you must dissemble your unit to clean or replace it this is not as a user serviceable item on some units, contact Panasonic via there web sight and request information from there tech services for further info.
Hello, i will list the criteria required to service TV and projector TV`s first and foremost you require a good understanding of how TV`s work and the ability of reading schematic diagrams, then you require a knowledge of how printed circuit boards are patterned so you can navigate around them to locate possible trouble spots.
then you require
1 multie meter of good quality
1 oscilloscope 20 MHz or better
1 shop service manual pertinent to your type and model of unit you wish to repair
this is a minimum requirement of test equipment you can have
you also kneed a location or locations to obtain the replacement parts you may require to complete the service task.
Now if you have all the above criteria in place then you have some hope to service your unit
a flashing red indicator on your TV usually refers to an internal circuit failure, most modern TV`s have circuits incorporated in the circuit design to protect good working components not involved in the fault from further damage so the set will not power up and an indicator light will start flashing, trouble spots can be anything like power supply under voltage, over voltage over current, no vertical deflection, excessive high voltage, XRAY, convergence failure,, EXT EXT,EXT,
Warning rear projection televisions can harbor in excess of 30,000 ,yes that is thousand Volts
There are and never will be user serviceable components inside LOL
Now if you are ready and require further assistance you may contact me and i will step you through the diagnostic procedures Good luck
Posted on Mar 01, 2011
My GPS nav-cam 6200 battery die so soon. its always on car charger. and the min i take it off. it dies after 5 min.?
Evesham is no longer in business but the following url is for a company that supports their products..
http://www.tewktech.com/
As a matter of fact, I understand this company has ex-Evesham employees. Good Luck and please rate this solution ...
Jan 19, 2009 | Evesham Nav-Cam 7700 GPS Receiver
My Tv is turning off by itself
unplug and let sit for a min then plug back in
Jan 01, 2009 | Televison & Video
TV keeps turning itself on and off, onto standby
I managed to find a local repair man who fixed the problem. He put in a new transformer.
Dec 01, 2008 | JVC AV-32D305 32" TV
Sony Bravia KDL 52 keeps turning itself OFF
i had prob where my sony would switch off for a few secs thenh come back on . The solution was in menu / tv settings / sleep timer . Go into that and make sure its set to off. there are opions for off , 5 min 20 min 30 min etc... mine was set to nothing just blank.
Apr 06, 2008 | Sony BRAVIA KDL-52W3000 52 in. LCD...
My less than 2 year old sony dsc-w100 keeps powering off and on
my only idea would be that the power button is glitching out...anything in the manual about this?
Jan 22, 2008 | Sony Cyber-shot DSC-W100 Digital Camera
Tv switches itself off then back on again
Hi.
If the tv set is still under warantee get it sorted before gtee runs out.
The problem is caused by cummunication error between ATV Micom and DTV Micom.
To correct this problem requires going in to service mode to make changes & updating the DTV firmware.
This will need to be done by a proffesional.
http://dysonmanuals.llc.nu/
Chris.
Jan 02, 2008 | Samsung LE32R41BD 32 in. HD-Ready LCD...
Tv keeps turning off
take your remote control and find the symbols shows watch click,then will show you the time setting if you want my be your tv to turn off 10 mn or 5mn or 60mn.then turn off the time there.
Aug 21, 2007 | Durabrand DU1901 TV
Oven switches 'itself' off without the timer
I sorted it it is a simple solution, if you take the top of your oven you should see the problem...it will be big and black..dont spend a ortune getting it sorted i brought the part off ebay for less than a fiver.. just cant remember what it was called..very simple to fix though.  Mike
Dec 19, 2006 | Electrolux EOB6632 Electric Single Oven
Right i had this same problem for ages! i cannot explain why but when i uplugged my DVD player (which was flashing its light at the same time as the tv for some reason) the TV has worked fine.
Aug 24, 2006 | Philips TV Tuner Video Capture PCI Card -...
Televison & Video Logo
Top Televison & Video Experts
