Question about Kenwood KDC-MP7028 CD Player
Attenuator light always on... no sound
Unit powers up, teh display is fully functional, but the attenuator light is constantly lit. Pressing the ATT button puts "ATT" in the display, pressing ATT again removes the "ATT" display, but the LED stays lit and I don't get any sound.
Any ideas?
  • 624 Answers
That light that stays on is not for the "ATT", it is just an indication that the unit has power. The problem with your radio is most likely the power amp IC inside the radio if you are using speakers connected directly to the radio from the speaker wires on the harness. If you are using an external amplifier for your speakers the problem will be either the electronic volume control IC or a muting transistor that has gone bad or the external amplifier is defective. There is no way to know exactly what is wrong without doing a few checks on the radio with a multimeter on have the radio on a work bench to be able to open it up and check a couple of things inside of it.
If you have a multimeter and a power supply (to turn the radio on while on a work bench) I can guide you thru the troubleshooting process to help you figure it out. But you will also need to have a soldering iron, solder, and solder wick to be able to remove the bad part and put in a new part.
Let me know if you will require any more help from me.
Posted on Nov 12, 2008
Sound won't play when I hooked up pineer avh 200 BT
turn the attenuator off
each input has an attenuator,i cant figure out where it is but check pg 40
Apr 11, 2015 | Car Audio & Video
My Sony xplod car stereo keeps going off saying att on/off but the light blue wire for Bluetooth isn't connected to anything. Any suggestions?
Att is not your bluetooth. Its the attenuator. Reset the radio an see if it clears. Sometimes the processor loses itself an needs to reboot.
Jan 29, 2015 | Sony Car Audio & Video
Hi!After a couple of storms,probablu due to statics in the antennas I use,after depressing the ATTENUATOR of the trahsceiver, the radio goes almost deaf...I guess some elemet around the attenuator circuit...
well the att does turn down the recieved signal but if it is too much ,,there is a chip resistor of value 56 ohm ,,,with magnify glass it sould have 56 on it on the curcuit board.
May 08, 2014 | Kenwood Radio Communications
What is amp remote and att
Amp remote: The In dash front unit has a remote switching output which is normally a BLUE wire which can be connected to the power amplifier kept at the rear for powering when the front unit is switched ON.
Att: this is the attenuation of the reduction of voluem/mute that becomes necessary when you are ina traffic condition and wants to listen to external noise.Pressing this button will reduce the level of volume in an instant which can be used as you desire than to reduce the volume with the controller.
Dec 11, 2010 | Car Audio & Video
My 1988 chevy truck won,t start.I put new battery clamps on .I charged the battery . I put new ground wire negative to body. all I GET is a click.what should I do next?
I would have the starter tested. Also check to see if the motor is turning freely, by turning the crankshaft pulley, just to make sure the motor isn't locked up.
Oct 27, 2010 | 1988 Chevrolet C1500
ATT. what is it and what does it do?
att is attenuator. It reduces the strength on incoming signals. It is meant to mainly reduce the signals of STRONG LOCAL stations that are blocking your reception of other stations adjacent channels. Or, if your are listening to the STRONG LOCAL staton but they sound distorted or muffles, turning on the attenuator (att) might clear up the sound of their transmission. It is alos used to just reduce the sensitivity of your scanner so that you will only hear local calls, like a local/distant switch would do.
Jul 10, 2009 | Uniden BC278CLT Base Scanner
The "Reset" button on Model# KRC-207S is located between the"ATT" (attenuator) and the "1" button. It is a tiny hole. Insert the end of a pen or pencil into the hole and hold for a few seconds and the unit will reset itself. Hope this helps...
Sep 03, 2008 | Kenwood KRC-207S
I have a Kenwood KDC MP2035, it is brand new, I try listening to somehting plugged into the AUX but when i press SRC to select AUX, AUX does not show up, only TUNER and STANDBY are in the options so far
here is some thing that will help u out. AUX Input: The KDC-MP2035 is equipped with a front panel 3.5mm minijack auxiliary input for connecting external portable audio devices such as an MP3 player or Tape walkman. The receiver allows you to select between the following AUX settings.
  • Off: the source button does not scroll through the AUX input when function is turned "off"
  • Aux 1: turns on the AUX input for use
  • Aux 2: turns on the AUX input in the attenuator mode - press the attenuator button to activate sound. pleas let me no if i can help any more and dont be afraidto rate me i dont bite lol just kidding
Apr 09, 2008 | Car Audio & Video
My Pro-96 Suddenly Doesn't Pick Up Transmissions
on scan mode press (man) for manual then pgm then trunk. screen should read not trunked press mode. if it does say that then press scan, and it should work. but if it doesn't say not trunked then press mode until it does say not trunked, then press scan. should work.
Nov 23, 2007 | Radio Shack Pro-96 Scanner
Kenwood KDC-MP7028 CD Player Logo
377 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
