Wireless LAN cardbus IEEE802.11g won't detect router. every other computer in the house is picking it up fine but it doesn't show in my list of available networks (even though I am detecting the neighbours' network). It was fine this morning and now... it's not. Help?
  • 29 Answers
Right click my computer go into properties and select hardware. now select device manager find the wireless lan card and uninstall the drivers. now restart your computer the drivers will re-install them selfs try this first
Posted on Oct 19, 2008
Samsung wireless lan adapter can't find network
Samsung server is your router ,
Use the DLNA and check .
Use a computer to log In to the router and check if the device is listed
( the TV with USB)
Sep 24, 2012 | Samsung WIS09ABGN WIRELESS LINKSTICK...
Was working ok then internet down and red light on router constant - have done the turn off turn on routine and reset router to no avail. have also plugged indirectly to computer - green light then comes...
Try rebooting both the modem and the router. It could be that the modem didn't pick up it's ip number when the internet went down. Then try pluggint you computer directly into the modem first to make sure it is setup and working properly. Then plug in the router (to the modem) and the PC plugged in directly to the router and check.
Once you have it connecting at that point then check the wireless settings on both the router and the pc. Then enable the wireless on the pc, unplug the LAN and switch to wireless network on the pc and see if it won't work.
If it works plugged in on the LAN but then not on the wireless then either your configuration isn't correct (ie wrong gateway ip number...gateway should be the same ip number as the router...ie 192.168.***.***) or perhaps the wireless part of the router died. It is possible for the wireless to die and the LAN (hard wired connection) to still work.
Aug 08, 2011 | Belkin N Wireless Router wireless router
I have a wired network in my house. An aerial on my roof picks up a wireless signal from a transmitter/receiver unit in the village. I can also pick up a wireless signal from the same aerial. I want to...
You can, in most cases, connect a Wireless router to your POS and let your provider know the MAC address of the device and then go from there for setting up your network. If you don't wish to replace your current router you can connect the wireless router to the current LAN router and establish a wireless network from there. Make sure you set up WEP or WPA security on your Wireless network to keep other people from hacking or using it without your knowledge. This is normally the only requirement Service Providers place users establishing a wireless network.
Oct 12, 2010 | Encore 802.11G WIRELESS LAN ROUTER...
D-Link Router not working suddenly.
Can you connect to the internet via an ethernet cable to the router, or even to the modem???
Are the computers set to automatically detect settings in internet options.
They may have been reset due to an update
Control panel / internet options / connections / lan settings / tick the box for automatically detect settings
Jul 22, 2010 | D-Link DIR-615 Router
My dell inspiron e1505 tells me that it cannot pick up wireless networks. My computer was picking up wireless earlier today in front half of house. we extended the signal via ethernet cord and plugged in...
Depends apon the signal and how you have the computer settings some of the older computers have programs where differant places will not be picked up !
Did you check your internet options in your control panel?
1.Check your internet options and see if your lan settings have a check mark in the top box for lan atuomatic detect settings click ok then your internet should pick up ..... if you are still haveing prombelms please let me know ... Lala linda
has a check mark on the top box so there is a
Dec 24, 2009 | Dell Inspiron 1501 Notebook
Accidently made my belkin router secured to just one computer
When there is another computer in your house and have also wireless lan connection.
Automatically can detect your Belkin Wireless Router with Name of it. But they are going to enter a passcode so that they can access the internet. And knows you have the passcode access to the router.
That's very easy because wireless lan obtain & detected network available on the area.
Hope this idea can help to you.
If i am helpful please rate me.
Thank you.
Yboyandrei
Aug 18, 2009 | Computers & Internet
I have bought a laptop from someone and it has a edimax EW-7305Pg wireless LAN Cardbus. I am having problems connecting it to a netgear wireless router supplied by sky. I have sky broadband. I uninstalled...
is the mac address registered through your wireless router, your router maybe running wireless mac filter, if not try registering your wireless mac address on your router then try reconnecting your computer to your router.
Feb 01, 2009 | Computers & Internet
Laptop won't detect wireless connection (but does detect others)
Dearest crystal 7, you prombally need to reset your windows
wireless. go to add and remove and remove the wireless
drivers the reboot your computer and the reinstall your wireless driver ,then go to the control panel go to internet options then to connetions then scrow down to lan settings the put a check in atuomatically detect settings the apply then ok . the reboot your computer then set up your wireless for connections for your house and it should work ...... lala linda
Jun 20, 2008 | Computers & Internet
Wireless cardbus pc card tew -601 pc
Hi..thanks for ur suggestion..my problem has been solved by opening my computer - properties - hardware and clicking on device manager and thr other device showing yellow question mark and i thought wirelss device doesnt work properly and i cliked on update device..a nd now my pcmcia card works fine
Thanking you
Neethan
Feb 11, 2008 | Computers & Internet
Computers & Internet Logo
64 people viewed this question
David Payne
David Payne
