I have an RCA DRC 8300 combo VHS and DVD player and the DVD won't open when I press the open/close button. I know there is no DVD stuck in there and the manual doesn't help. Any suggestions?
I met a lady with the same problem.  I had to open the unit (use caution/check warranty) and I found out the foam pad that holds the discs in place fell off of its holder.  If you place this back on, the unit should work again just fine.
Posted on Nov 18, 2008
VCR/DVD combo. Why won't DVD tray move?
If the DVD drive opens and closes with the cabinet removed, the problem is poor assembly at the factory. Been there, done that with a brand new RCA combo right out of the box!
Nov 15, 2015 | Emerson Televison & Video
How do I program a RCA universal remote to my Toshiba SD-V392 vhs/dvd combo player
Turn on device , look up the code number for a Toshiba vhs/DVD combo then press setup and hold until it blinks then press device vhs/DVDs then enter code and press off button when device turns off it is programmed
Aug 29, 2015 | Toshiba Televison & Video
Rca dvd player stuck
There are a number of possibilities, jammed gears caused by a disc or gears out of time, some have a very small loading belt located under the draw in most cases, excessive ware and tare on plastic gear linkage.
Sep 05, 2012 | RCA Televison & Video
Jvc dvd player won't open
when you hit the eject button try tapping the top above the disk drive. it may be somewhat stuck. if that doesnt fix it you might have a broken belt or a belt may have come off in it. the belt controls the movement of the drive in and out
Mar 21, 2012 | JVC DVD Recorder - VCR Combos: DVD...
I have a rca drc 8295 and have old family movies on vhs and want to record to dvd. what dvd do i need dvd r?
Use the DVD+R Disc better for transfering recording.Read ur DVD Recoder/VCR combo owner manual,before u do this,for the correctly setting to do transfering recording.
Jun 23, 2010 | RCA DRC8295 DVD Recorder/VCR Combo
RCA DRC 8310 - not copying from VHS to DVD. When I am playing the VHS tape I press the COPY button, it says that is copying for about 10 seconds and then stops and locks up,. If I press the RECORD...
stay with the 8x dvd (these recorders look and only work with certain types of dvds)...if your manual says maxell stay with it dont look for the brandless sale...use 8x unless your have updated your machine with new firmware from the mfr. for that 16x...are you trying to record HBO / DISNEY? its not going to be allowed on DVD...yes you can record both onto tape...but not digital..(I put all my movies onto dvd, my kids still have tape DISNEY)
hope this help
Mar 10, 2010 | RCA DRC8300N DVD Recorder/VCR
MY RCA DRC 8320n DVD Recorder/VCR Combo will not accept tapes. DVD works fine. RCA help line is a joke. I will never buy another RCA product.
Yah, you're going to be taking that in for repair. I worked for couple of years at RCA / Sony / Panasonic / ... and 60 more names - service center. When a VHS Cassette loading mechanism doesn't work - it probably needs loading motor or loading gear, something repaired. At the cost of DVD and VHS combos these days I'd call it Not Worth Repair (NWR) out of the starting gate. At least $50 an hour, at least 2 hours ... that's beyond the cost of a new one.
Nov 22, 2009 | RCA DRC8320 DVD Recorder/VCR
I purchased a RCA DRC-8335 DVD/VCR RECORDER COMBO
For anyone who has an RCA DRC 8335 with dvd Recorder, here is a suggestion.
If your tapes have been recorded in SLP Mode, om another player, I can tell you they will NOT play on this thing!!
So, merely take another VCR, and a blank tape, Place the blank tape into the RCA DRC 8335 VCR side, and then, go to its Set-Up Menu, and go to OUTPUT. On the "ACTION BAR"Change the the RCA's output to "FRONT" and then, play the VCRr you stuck on top of the RCA!!
When the inage on the "Source tape is shown,
Record onto the RCA, in SLP Mode, Now, it will play, just fine.
Hope this helps. Jon (Found BY Accident!!)
Jul 31, 2009 | Televison & Video
VHS -DVD RCA Flashes in blue color
if i understand your statement, you are having an issue copying either VHS to DVD or vice versa, most media today has built in copyright protection to prevent what you are trying to do, there are PC softwares to bypass these, but you will have to hook the player to your PC using a TV Tuner, or an Application called VHS to DVD or something similar,
Jun 15, 2009 | RCA DRC8030N
DVD Player does not work
General Problems
Player won’t work (locks up)
• Try unplugging the AC power cord and plugging it back in.
• Reset the DVD/VCR: on the front of the unit, press and hold the STANDBY/ON button while you press and hold the STOP button—wait at least 3 seconds
before you release both of the buttons. You’ll need to set up your menu preferences because this Reset Procedure returns the DVD/VCR’s menus to the
factory default settings and also erases the contents of the Disc Library.
Mar 15, 2008 | Televison & Video
Televison & Video Logo
121 people viewed this question
Top Televison & Video Experts
Electro Med Services...
