Question about Citizen Eco-Drive BL5180-57L Wrist Watch
Watch strap Where can I find a replacement strap? The current one doesn't adjust small enough for the wrist.
Thank you! I appreciate the input!
Posted on Oct 21, 2008
Try by Google The Watch Prince. I had great success with them. FAST shipping with excellent customer service.
Jim
Posted on Oct 20, 2008
I need to find a wrist band for my Armani Watch AR0210. Can you tell me where to find a replacement wrist band and the cost of it... Thanks
first i have to know your location. but this model of armani watch strap is can be replace by any brand of strap not only armani brand but if you like a armani strap brand, you have to order it at authorized retailer of armani watch. i hope this will help you.
Aug 12, 2011 | Giorgio Armani AR0210 Wrist Watch
I have a dkny watch that i need to adjust the band on...it does have arrows and what appears to be small screws.....
it doesn't have arrows because you have to use small screw drivers to loosen it. so you can adjust it. You can buy it on any hardware store. i hope i had been helped you.
Jul 24, 2011 | DKNY 1035 Wrist Watch
How to change the watch strap, resin type
One way to change a watch strap, is if you have any old watch straps you can use them. There should always be a bump by the actual clock. You should be able to manuever the watch out of the two small holes by using your fingers. You can then interchange watch straps!
Jul 14, 2011 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
I am trying to figure out how to shorten the wrist band on my Casio Edifice EFA-119.
mcdevito75 here, If your Casio has a metal band, you can remove 1--2 links, this takes a special tool called a link remover, best bet is to look for a small watch repair shop in your area. If your Casio has a strap, the buckle may be able to move up the strap to fit your wrist, if so, move the buckle up the strap to fit your wrist and cut offf the exccess strap. If not, you"ll have to replace the entire strap. Hope this helps.
Aug 03, 2010 | Casio Edifice EFA109-7AV Wrist Watch
Where can I get a replacement band (strap)for my Nike watch model WA0021-002
mcdevito75 here, Your Best bet may be a small watch repair shop in your area fopr a new watch band / strap.
Jul 28, 2010 | Nike Oregon WA0021-013 Wrist Watch
How do I remove links from an Adidas Candy Wrist watch?
You can't. You must be referring to a different watch because the Candy Watches have a polyurethane strap as shown here:
http://www.shopadidas.com/product/index.jsp?productId=3078734
Jul 19, 2010 | Adidas Unisex wristwatch
I need replacement band for a 433LSLB Skagen watch. Please advise.
mcdevito75 here, BEST BET, look for a small watch repair shop in your area for a replacement strap or original strap from Skagen.
Jul 12, 2010 | Skagen 105LTX Wrist Watch
Watch strap a little big
mcdevito75 here, Maybe a link or 2 can be reoved from the metal band, or an adjustment at the clasp can be done. Look for a small watch repair shop in your area, they can help.
Jul 08, 2010 | Casio A168W Wrist Watch
How to adjust the watch strap
I just bought the o-ring watch by Starck, and it looks to have the same style of strap. If you look on the side of the clasp, you will see a pin on both ends. You have to remove these retention pins first (which may require tools that are unavailable to you). First, stabilize the watch on its side on a soft mat - I used the back of a mouse pad. Then, use a thin, stiff piece of metal tool to push the pins out slightly. I used a crafting tool. Once the pin sticks out enough, you can use a fine set of pliers to pull them the rest of the way out. (If this does not make much sense at this point, you may be best off going to watch shop.) Once you remove the pins, the clasp can be removed from the strap simply by lifting the clamp. You then trim the strap with a pair of sharp scissors to the appropriate length - make sure you see exactly what the end looks like, because the shortened strap will need to have the same apperance. After trimming, reclamp the clasp onto the strap, and reinsert the pin. You may need a small hammer to get the pins seated completely. Then, you're done. So obviously intuitive, why would anyone need directions, right? Honestly, Fossil did not make this one easy at all. Kind of irritating.
May 15, 2008 | Fossil PH1057 Wrist Watch
Adjusting the strap
Most clasps have a series of small holes drilled in them, and the end of the strap is held in by a small, spring-loaded bar whose ends are seated in one set of holes. Take the end of a small paperclip, or a large needle, and use it to depress the spring-loaded pin. You can then carefully slide it to another set of holes to make the band smaller. Don't let the ends of the pin slide all the way out of the clasp, or it might shoot off into space.
Jan 22, 2008 | Versace 27473-008-00 Wrist Watch
Citizen Eco-Drive BL5180-57L Wrist Watch Logo
111 people viewed this question
Top Citizen Watches Experts
Jimmy Accardi
Ansel Alberto
Ansel Alberto
Are you a Citizen Watch Expert? Answer questions, earn points and help others
