Question about Samsung L200 Digital Camera
How can i fix it
My camera does not want to turn on but when i press the power button it makes a noise n the power light is still on
  • 2 more comments
  • brillant_4li Oct 22, 2008
    my camara will not come on but the lens lens and the power light is on
  • jaimico Nov 01, 2008
    i turned the camera on and it turned off after 5 sec. and the ligth still on and it makes a little noice
  • partida19 Nov 02, 2008
    mine just turns on but only the power button turn green but nothing appears on the screen....i have tried clickin the battery in and out again many times but i still have the same problem
  • deborah_pena Nov 19, 2008
    MY camera wont stay on it just turns on and off. Did anyone fix theirs. This seems to be a very common problem. I just got my camera 2 weeks ago and it has never been dropped.
  • 71 Answers
Digital cameras are very power hungry. Be sure you have charged battery fully. Other possibility is that the lens got stuck. Maybe you can fix the lens with your fingers, very gently.
Posted on Nov 22, 2008
My Samsung TL205 digital camera will not turn on. The lens is out but when I press the power button, the green on button will light up then the camera will make one beep sound as the green light turns off....
I just fixed my camera. I pushed the lens inside completely. took the battery out and put it back in. turned it on and off a couple of times and ready to go!! good luck!
Feb 17, 2011 | Samsung DualView TL205 Digital Camera
When I turn my Sony Cybershot dsc-p72 on, i am able to view my pictures, but when i try to take a picture the screen is black and it makes a whirring noise. Then the camera turns off automatically. How can...
Confirm if you're using a fully charged Battery with the Camera. Check if you're able to playback the images normally. Then, try to reset the Camera by either pressing the Reset button when the Camera is in ON condition or by removing the Battery and pressing the Power button for 1 minute and reinsert the Battery. Unfortunately, if the issue persists your Camera requires service.
You can create the service request at the following page: www.eservice.sony.com
Feb 15, 2010 | Sony Cyber-Shot DSC-P72 Digital Camera
Will not print. turns on lights up makes noise
There are two self tests you can try to test the printer. With only the black cartridge and on sheet of paper. Disconnect the printer from the computer and unplug it. Plug it back in and do the following:
Press and hold the power button. At the same time, press and hold the Ready/Insert button. Release the power button, but keep holding the Ready/Insert button. After 4 seconds, release and press the button again and release. It should print a one page diagnostic test.
The second self print test using all 4 cartridges. Turn the printer on, press and hold the Ready/Insert button for a few seconds and release the button. The test will use all 4 inks.
Jan 02, 2010 | Alps MD 1000 Thermal Printer
My camera's lens won't close when it's off and it
It seems your camera needs to be repaired. You can log onto www.kodak.com/go/itg and follow the online steps to book your camera in for repair.
Oct 25, 2009 | Kodak EASYSHARE M763 Digital Camera
Three beeps when i try to turn it on
i had the same problem a while back. I fooled around with my camera lens a bit and it turned out that one side of the lens was sticking out a bit. I pressed down on this and pushed the power button and it worked. The next time I turned it on the same thing happened but if you keep doing the same thing it should work.
Hope this helps!
Aug 21, 2009 | Samsung L100 Digital Camera
Olympus Fe-310, lens is messed. Possible sand in it but not sure.
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jun 14, 2009 | Olympus FE-310 Digital Camera
Toshiba 32A32 won't turn on
just fixed one with that problem it was the vertical output ic Q301
that was shorted. try wicking it out. it is a LA7833S.
Postings say to be sure to use the Toshiba part
Feb 27, 2008 | Toshiba 32A32 32" TV
Frozen lens and shutter
Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem. In any case it could not make it worse Good luck!
Sep 06, 2007 | Canon PowerShot A510 Digital Camera
Zoom error message
Aug 07, 2007 | Olympus SP-350 Digital Camera
Samsung L200 Digital Camera Logo
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
