Question about Blitzz Technology (BWP712) 802.11g/b Wireless Adapter
Need security option
I have installed a new router (NetGear) and now the BWP 712 does not work. I have 5 options for a security code. Which one do I use for this card?
1. none
2. WEP
3. WPA-PSK[TKIP]
4. WPA2-PSK[AES]
5. WPA-PAS[TKIP]+WPA2-PSK[AES]
Susan
guerapendeja@yahoo.com
  • 4,338 Answers
The security code is set in the wireless section of the router. You need to access the router's setup page and go to wireless. Under security you will see the encryption key which you need for your adapter.
The setup page is at 192.168.0.1. Put that in your browser.
It will open to the router's setup page.
You should see a box prompting you for your username and password. Enter your username and password now. By default the username is admin, and the password is password. Click the Ok button to log in to your router. Then go to wireless tab, then security.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Oct 19, 2008
  • JDTec
    JDTec Oct 19, 2008
    http://www.portforward.com/english/route...
    For instructions, pick your router from the list on the link above.
    You may have to copy and paste the link into your browser.
    Thanks, Joe
How do i find the security code for a netgearwgr614 router
For finding security code of Netgear WGR 614 router follow the steps-
1. Login the Admin.
2. Click on Advanced
3. Go to the Administration
4. Click on Set password
5. Enter old password.
6. Enter New password.
7. Repeat New password.
See in images:-
Not finding security code visit:- Netgear Router Tech Support Number
Feb 13, 2015 | NetGear WGR614 Wireless Router
Reset password
The default password for the router's Web Configuration Manager is password. NETGEAR recommends that you change this password to a more secure password.
To change the administrator password: 1. On the main menu, under Maintenance, select Set Password to display the Set Password screen. 2. To change the password, first enter the old password, then enter the new password twice. 3. Click Apply.
Best of luck!
Sep 06, 2011 | NetGear WNR2000 Wireless Router
I have windows 7 running program on my computer, Well its not allowing me to upload the CD for Netgear to install the programs
to configure the netgear router and to secure its network. . . .1, first make sure that your laptop is connected directly to the netgear router via ethernet cable.2. after securing step 1, on your computer, open browser, ( internet explorer or firefox )3. go to the address bar, the one with the http:\\ and erase everything inside it.4. type in there, 192.168.1.1 or www.routerlogin.net.5. username is " admin "password is " password "6. you would see netgear set up wizard. 7. for wireless configuration, click wireless settings on the left side of the set up wizard.8. you can edit network name, and get your network security key under security options. make sure to choose WPA PSK TKIP. so that you can have a personalize network key9. the network security key is the " passphrase "then click apply.then your all set for wireless connectivity.you dont need the cd to have it work. just follow these steps
Aug 03, 2011 | NetGear WGR614 Wireless Router
I need to reset or find my origional password. Please help. Thanks
If you have changed the default password, you need to reset the router to the factory settings to get in with the default user and password (user admin and password as password, or if that doesn't work try 1234 - these are the default password for NetGear routers). Note that you will lose the ISP settings and wireless settings when you reset the router.
Here's a video on how to reset the router to the factory default settings: http://kbserver.netgear.com/media/flash/training/Troubleshooting/NG_WGR614V9Router_TS_LostPassword.html
Feb 17, 2011 | NetGear DG834G Router
How to use dual band on router?
You can only use it in the 2.4 ghz mode or the 5 ghz mode:
1. Log in to the Router by going to http://www.routerlogin.net or http://www.routerlogin.com
and entering the default user name admin and default password password, or using whatever
LAN address and password you have set up.
2. Select Wireless Settings under Setup in the main menu to display the Wireless Settings
screen.
3. Select the region in which the wireless interface will operate.
4. Set up the 2.4 GHz wireless network:
a. Enter the SSID name. The default is NETGEAR.
b. Select the operating channel for the wireless mode. The default is Auto. When Auto is
selected, the router finds the best operating channel available.
If you notice interference from nearby devices, you can select a different channel.
Channels 1, 6, and 11 will not interfere with each other.
c. Leave the wireless mode set to the default setting of Up to 145Mbps for 2.4GHz.
5. Select security options for the 2.4GHz wireless network.
The wireless Security Options are set to None by default. NETGEAR strongly recommends
that you use wireless security. You can select a different Security Option and a different
passphrase for each wireless network. For the highest performance of the 2.4GHz wireless
network and the most secure encryption, NETGEAR recommends that you use WPA2-PSK as
your security option.
6. Set up the 5GHz wireless network:
a. Enter the SSID name. The default is NETGEAR-5G.
b. Select the operating channel for the wireless mode. The default channel is 36. If there is an
Auto option in the channel list and you select it, the router will find the best operating
channel available.
c. Leave the wireless mode set to the default setting of Up to 300Mbps for 5GHz.
7. Select security options for the 5 GHz wireless network.
passphrase for each wireless network. For the highest performance of the 5 GHz wireless
network and the most secure encryption, NETGEAR recommends that you use WPA2-PSK asyour security option.
8. Click Apply to save your changes.
please rate it and give a testimonial for my response
Thanks, Joe
Feb 02, 2011 | NetGear WNDR3400 N600 Wireless Dual Band...
I put my disc in my dell computer and installed it .the internet still wont work
to configure the netgear router and to secure its network. . . . 1, first make sure that your laptop is connected directly to the netgear router via ethernet cable. 2. after securing step 1, on your computer, open browser, ( internet explorer or firefox ) 3. go to the address bar, the one with the http:\\ and erase everything inside it. 4. type in there, 192.168.1.1 or www.routerlogin.net. 5. username is " admin " password is " password " 6. you would see netgear set up wizard. 7. for wireless configuration, click wireless settings on the left side of the set up wizard. 8. you can edit network name, and get your network security key under security options. make sure to choose WPA PSK TKIP. so that you can have a personalize network key 9. the network security key is the " passphrase " then click apply. then your all set for wireless connectivity. you dont need the installer, just follow these steps
Dec 17, 2010 | NetGear WNR1000 Router
How do i reset password for netgear router
There should be the reset button behind the router, click on it for about 5-10 seconds.
Jun 26, 2010 | NetGear WGR614 Wireless Router
Need a securty code
Regarding your concern, please note that in order to get the network key/password on the NETGEAR router (MODEL_NUMBER), we need to login to the router's web interface using any computer which is physically connected to the router.
Please follow the steps on a computer connected to the router using an Ethernet cable in order to find the network/security key:
1. Open the browser (like Internet Explorer, Mozilla Firefox, or Safari).
2. Access the router, usually by typing 'http://192.168.1.1', 'http://www.routerlogin.net' or 'http://www.routerlogin.com' in the address bar.
3. When prompted for Username and Password please enter Username as 'admin' and Password as 'password' (please note that both Username and Password are case sensitive).
4. Click on Wireless Settings' under Setup from the left menu.
5. Check if 'WEP (Wired Equivalent Privacy)' or 'WPA-PSK (Wi-Fi Protected Access Pre-Shared Key)' is selected under 'Security Options'.
6. If WPA-PSK is selected, copy the code entered in the pass phrase.
7. If WEP is selected, copy the code entered in the key that has been checked.
This is the code required for connecting the wireless computer to the NETGEAR router's wireless network.
In some cases, for security reasons the pass phrase might show as asterisks. In this case type a new password and click apply. You will then have to use the same password for all the wireless devices connecting to the network.
Feb 07, 2010 | NetGear WGR614 Router
Dgn2000 set up works fine through ethernet wireless no connection laptop has wireless which is swiched on router shows wireless active - what channel? does the router need to be switch to?
How can you configure wireless settings on the netgear router.
1. Open IE and type 192.168.0.1
2. Enter login and password ( By default user name "admin" and default password "password" in lower case.)
3. Once you login to netgear router page
4. On the left hand side at the top you have wireless setting click on that.
5. You will get following screen
6. Name SSID: (any thing) Make sure when ever you change any settings on the wireless screen always change Name of your network.
7. Mode you can select any one of the option
8. Under Wireless Access Point
a) Enable (This option is always check if you want to enable you wireless feature)
b) Allow (Broadcast of name (SSID) (This option is always check if you want to enable you wireless feature)
9) You can select any of the security option
10 Apply
Then you can see your network name on your computer which you have setup on the netgear router.
I believe no one face any problem after that but still i am here to assist you.
Thanks & Regards
Oct 27, 2009 | NetGear DGN2000-100NAS Router
How can i make my wireless router connection secure? i mean for other people not to get my signal.
You need to set up network security on both the router and the computers you connect to it. Log in to the web settings page (probably https://192.168.0.1) for the router and you'll find a security tab.
Oct 03, 2009 | NetGear RangeMax WPN824 Wireless Router...
Blitzz Technology (BWP712) 802.11g/b Wireless Adapter Logo
450 people viewed this question
Top Blitzz Technology Computers & Internet Experts
Michael Galve
Michael Galve
Tre Elkins
Are you a Blitzz Technology Computer and Internet Expert? Answer questions, earn points and help others
