Unplug and replug from wall. See if that helps. Ours decided to turn to white and not show any picture now. This is a quirky tv. When it works it is great, when it does not work, it really makes you mad. It is brand new!!!
You either have a bad Power Supply or a bad Main bd. Worst case can be the inverters on the Panel have gone bad in which case the Panel needs to be replaced.
they must try to repair the smps [puff capacitors]first.then try a master reset thru the service mode.if these steps do mot solve the problem replace the t-con board on lcd panel.
Sounds like a backlight going bad or possibly the inverter. Check each backlight first for dark discoloration on the ends. If that checks out good then it's the inverter.
TV goes on but its black. I have another exact tv bought at the same time but that one is fine.
