Question about IBM ThinkPad T40 2373 Notebook
Cy25 well the problem im having is everytime i try and format my hardrive it says physical memory only when it gets to 33 percent and something about newly installed hardware.
  • DEKR
    DEKR May 11, 2010
    how are you trying to format
    and what new hardware have you installed
My desktop is getting stuck so many times. It shows bluescreen and physical memory dump even when i tried to install new copy of windows. the error is technical error stop : 0X0000007A(0XCO7B9FB8,...
It can be a few things but usually the atapi.sys file is corrupt. If you can boot into your desktop, open the "run" box and type in "cmd". In that box type: sfc /scannow and press enter. There is a space between sfc and /scannow. You will be asked to put your Windows CD in the CD drive.
When did this problem begin? Have you installed a new harddrive recently? Have you installed new memory recently? Remove and re-insert the hardrive cables. Remove and re-insert the memory. Be careful about electro-static discharge. Sometimes just doing that will fix a bad connection.
Sometimes this error is caused by bad memory. You can download Memtest86 here: http://www.memtest.org/ Grab the prebuilt ISO.zip After downloading the file right click it and select "extract all" Use Img Burn http://www.imgburn.com/index.php?act=download to write the ISO to a CD. Keep the CD in the drive and reboot.
Also, there could be a problem with the hardrive. if you know the harddrive manufacturer you can usually go to their website and download their hardrive diagnostic software.
Sometimes erasing the hardrive (absolute last resort) will solve these kind of errors. Just be aware that you will lose ALL of your data and it mat not solve the problem. Darik's Boot and Nuke works good for that: http://www.dban.org/
Feb 09, 2012 | Computers & Internet
Hi Everytime I insert memory card to camera I
Hello Sir
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • Jan 16, 2010 | Olympus FE-210 Digital Camera
    4g sandisk (wont format)
    I have heard of cases of SD cards just giving up the ghost and not working. If it is only 3 months old I suggest you take it back to the place you bought it
    May 28, 2009 | SanDisk 4GB microSD High Capacity Memory...
    I'm not sure but did you try to go to my computer: right click the partition and check off (if it stands) protect or hidden
    May 27, 2009 | SanDisk 4GB microSD High Capacity Memory...
    LAPTOP DISPLAY,
    ok for some reason by running the game morrowind it fixed my display. Dont ask why, I dont know but thanks anyway. Maybe it has something to do with the mods that I have put on it.(morrowind)
    Dec 14, 2008 | Fosa CY25 Laptop
    Installing line comes up after each restart.
    did you tried to format your memory card via phone? if not, try it go to tools then select memory card, click option them select format memory card, then try to install some java applicatins. good lack
    Jul 20, 2008 | Nokia N73 Cellular Phone
    Insatalling Message
    it helped me very much thanks
    Jun 16, 2008 | Nokia N95 Cellular Phone
    NOKIA N95 MEMORY CARD
    seems like your memory card is corrupted. this site is about nokia n95 help
    Jun 15, 2008 | Nokia N95 Cellular Phone
    Rm cy25 service manual
    Compal manufactured this computer and it was sold under many different manufacturers names.
    To remove optical drive: Extract the two screws in the base that obviously attach to the drive. Remove cover from memory, roughly in centre of base, and you will see a screw that secures the drive. Remove the screw and the drive will slide out. Remove the bracket on rear of drive, attach to new drive and reverse above procedure. Memory is located under the said cover and also under the keyboard. Not too difficult to remove keyboard. Remove switch panel after removing screws in back of hinges. You will see several screws on rear of keyboard. Remove these (very small) and keyboard will swing upwards and out. Beware ribbon cable connector underneath as removing keyboard. You will then see second memory location. Max mem 1G
    Jan 14, 2008 | IBM ThinkPad T40 2373 Notebook
    IBM ThinkPad T40 2373 Notebook Logo
    41 people viewed this question
    Top IBM Computers & Internet Experts
    Alun Cox
    Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
