Toshiba Sept. 1996 model Model #ce35f15 Black box will not go away?
When i plug the cable antenna in, the tv makes a popping sound. I need a atenna connection box for this tv. Any solutions.
Posted on Nov 02, 2008
What is this gun worth the serial number is 38636
Need make and model to answer
May 02, 2015 | Optics
Toshiba tp50h15
black-power
white-neutral
green or, metal frame-ground
Sep 23, 2013 | Computers & Internet
My old toshiba t.v. has short bodys and big headed people in the screen do i need to replace a tub ?
Yes you must replace the tub, with that brand tho the more expensive the tub, the more efficient it will make your Toshiba viewing experience.
Jul 21, 2012 | Computers & Internet
Toshiba 32AF45 Black Rectangle Issue
go into your menu and find closed caption, someone has accidently set the closed caption mode to text, when the on screen display of channel or volume goes away the box appears. turn off the closed caption feature or switch it to something other than "text" mode, and your box will go away.
Apr 10, 2009 | Toshiba 32AF45 32" TV
Cable box remote doesn't work when tv is turned on.
I am having this same problem with our Mitsubishi LCD Flat Panel TV, Model LT-46246 ans our Scientific Atlanta remote cable box, same model as yours. We cannot use the remote at all to change the channel. I called Mitsubishi and they said they have never heard of this. I find this incredibly hard to believe. Time Warner, our cable provider says that it is not the box because it works when not hooked up to the TV. What a pain. I would love to hear if anyone else is having this problem or has a fix for it.
Mar 25, 2009 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Toshiba CE35f15 TV
This is a vertical circuit problem that is either bad connections on the vertical IC or a defective IC. If you can solder, you can fix this yourself. Look for a small flat IC attached to a heatsink with about 9-11 pins. It may be marked LA7837 or something similar. Try resoldering the pins first. If that fails to resolve the problem, replace the IC. There may be defective caps in the circuit as well, but those don't usually cause complete vertical failure. If the picture does not return fully, update this and we'll continue on to the next step.
Dan
Sep 29, 2008 | Toshiba Televison & Video
Black box
Black box by itself coud be a software issue call toshiba tec support or could be in some stuck in a service mode for the factory regardless you will need to call tech support
Jan 11, 2008 | Toshiba 50HP95 50 in. Plasma Television
I just received my cordless, Panasonic Model #KX-TC1703 PHONE
I suggest you read the manual. If you don't have it, search for it and download it
Dec 02, 2007 | Uniden Cordless Phone
TOSHIBA tv
I had the same problem. A big black box in the middle of the screen that would temperarily go away if with the EDS button.
Go to the main menu and turn off closed captioning. It worked for me! :D
Sep 09, 2007 | Toshiba 27A34 27" TV
Toshiba TV MV13P2
All I can say is that the black box appears when the closed captions are on and set to TEXT. This is normal. Turning off the closed captions should make the black box go away. If the closed captions are somehow turning themselves back on, there may be an issue with the microprocessor in your TV.
Aug 24, 2007 | Toshiba MV13P2 13 in. TV/VCR Combo
Televison & Video Logo
57 people viewed this question
Top Televison & Video Experts
Electro Med Services...
