Computers & Internet Logo
Anonymous Posted on Jan 30, 2012
Toshiba Satellite Laptop M205-S4805 gets overheated and shuts down
Disassembling Toshiba Satellite M205-S4806
Javeed Khan
Level 3:
  • Master 316 Answers
  • Posted on Jan 30, 2012
Javeed Khan
Master
Level 3:
Answers
316
Questions
Helped
64517
Points
1000
Hi
This can happen when the air vents are blocked by dust or similar particles, it can also occur if the fan is not running to the full capacity. The best you can do is to seek an expert advice as trying to open the casing without proper knowledge has a risk of damaging the system.
Regards.
Javeed
My laptops shut down when i put the adapter and doesn't get start up , but it's work normally with betray
Problem description:The laptop shuts off when AC power adapter is plugged in. The laptop works fine on battery power but as soon as you connect it to AC adapter, the laptop turns off.
Possible cause:1. Power adapter failure.
2. Motherboard failure.
Possible troubleshooting steps and repair solution:First of all, test the power adapter. Make sure the adapter outputs correct voltage. It's possible that the output voltage is not correct and the laptop shuts down to prevent the damage. Test your laptop with another known good power adapter.
If the problem still exists, even after replacing the adapter, most likely it's the motherboard failure. Replace the motherboard.
Reference: http://www.chargerbuy.com/blog/laptop-shuts-off-when-ac-adapter-plugged-in/
My laptop model is Toshiba Satellite M205-S4806. My laptop speaker is producing noise causing not able to hearing quality sound. is that a software problem or hardware problem?. Can I get the solution...
i would say your speakers are done but try to reinstall them just the same then open and inspect if it still persists clean and finally replace if need be this order of operations should narrow down the issue in the cheapest and most efficient manner
My Toshiba Satellite M205 need recovery system
You can contact Toshiba to buy the recovery disk to put it back to factory setup or
You can download the user maunl here to show you how to create the recovery disk.
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=1909322&rpn=PSMC3U&modelFilter=M205-S4806&selCategory=3&selFamily=1073768663.
Finger print sensor not working with vista in toshiba M200
here is the link :
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=SB&os=&category=&moid=2211892&rpn=PSMC4U&modelFilter=M205-SP3018&selCategory=3&selFamily=1073768667&selModel=2211892|PSMC4U
Satellite A200-ST2041, A200-ST2043, A200-ST2042, A205-S4617, A205-S4618, A205-S4639, A205-S4638, A205-S4537, A205-S4557, A205-S5816, A205-S5814, A205-S5813, A205-S5812, A205-S5811, A205-S5810, A205-S5809, A205-S5806, A205-S5805, A205-S5851, A205-S5847, A205-S5843, A205-S5841, A205-S5835, A205-S5831, A205-S5825, A205-S6810, A205-S5823, A205-S5804, A205-S5803, A205-S5801, A205-S5800, A205-S7468, A205-S7466, A205-S7464, A205-S7459, A205-S7458, A205-S7456, A205-S7443, A205-S7442, A205-S4797, A205-S4787, A205-S4777, A205-S4707, A205-S5863, A205-S5859, A205-S5855, A205-S5853, A205-S5852, A205-S6812, A205-S6808, A205-S5821, A205-S5819, A205-SP5822, A205-SP5821, A205-SP5820, A205-SP5818, A205-SP5817, A205-SP5816, A205-S5000, A205-S5866, A205-S5879, A205-S5878, A205-S5872, A205-S5871, A205-S5867, A205-S5880, A205-S5861, A205-S5833, A205-S5864, A205-S4629, A205-S4607, A205-S4597, A205-S4578, A205-S4587, A205-S4577, A205-S4567, A215-S4697, A215-SP5811, A215-SP5810, A215-S48171, A215-S4817, A215-S4807, A215-S4767, A215-S4757, A215-S4747, A215-S4717, A215-S4737, A215-S5839, A215-S5848, A215-S5837, A215-S5829, A215-S5828, A215-S5827, A215-S6820, A215-S6816, A215-S7472, M110-ST1161, M115-S3094, M115-S3104, M115-S3154, M115-S3144, M200-ST2001, M200-ST2002, M205-S3207, M205-S4804, M205-S4805, M205-S4806, M205-S7453, M205-S3217,
Computer shuts down on its own
Usually what gives these types of sighns is that the laptop is overheating.
It hasn't cooled down yet and that's why it will continue to reboot a couple of times it's a safety catch so you don't fry anything within the laptop.
A couple things you can do put it down on a hard surface when in use do not cover the bottom vents that let's the computer breath and cool down.
Also they sell in many stores you will see laptop coolers.
They are flat and light which you put your laptop on there's fans on the bottom that blow up at the bottom of the laptop to keep it cool
I use one it let's the laptops life last longer plus it don't burn the legs or heat up the legs while on the laptop.
Happy Holidays
1helpful
Installation problem on Toshiba Satellite M205-s4804
Can you provide a little more info? In the mean time, you might consider browsing LaptopExperts.net to see if anyone else has had a similar issue, you can use their advice as a guide.
-TRT
Grand Canyon Tech
Grand Canyon Tech
