Question about Relisys TL 766 Monitor
Relisys 19" monitor
Unable to turn screen off!
get message saying "autoadjusting"
this has happened just 2 days ago ,
previously i pressed the on/off button and screen turned off?
can i reset it ?
please help/
regards , mike, sorry unble to provide model ref as not on the monitor.
3 Suggested Answers
SOURCE: Cannot turn off Auto Adjustment... message.
i has same problem and I have no idea how to disable. :(
Hope someone know how to help us out!
Posted on Mar 01, 2008
  • 191 Answers
SOURCE: A 1/2
there are 2 possibilities 1. you have changed screen resolution by accident, try using that [right click desktop and properties, look in tabs there] or 2. your screen is old and it has "burned out" in some parts
Posted on Oct 14, 2009
Screen to bright and out of focus
Ive had this same problem caused by graphics card not being in tightly enough after a move or monitor swap it may be as simple as just pushing the graphics card back into the motherboard
Mar 29, 2010 | Relisys TL 970 19" LCD Monitor
A 1/2
Oct 14, 2009 | Relisys Intro TE988 19" CRT Monitor
My dell desktop screen says AutoAdjust and then
install graphic drivers from following link
then cherck ,.
If you still face problem then when you power up the computer pressF8 key then enter in enable vga mode. then change screen resolution to 1024*768
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=DIM_PNT_P4_8300&os=WW1&osl=en&catid=&impid=
Jun 25, 2009 | Dell Dimension 8300 PC Desktop
UltraSharp 19' Screen will not autoadjust.
Start in SAFE mode (press F8 wile booting) and choose Last Known Good to see if it works in Windows DEFAULT setting.
My guess is that MSoft pushed a patch or SP to your box and IT replaced the dll your monitor was using.
Goto www.support.dell.com and DL the correct drivers again
Good Luck!
Let me know what you discover ;-)
Let me know if this fixes it
Mar 26, 2009 | Dell UltraSharp 1907FP 19" LCD Monitor
JM777 no receiving signal from CPU
when u power up the computer press F* key then go to enable vga mode then set disaply resolutin incotrol panel to 800*600 or 1024 *768
Nov 24, 2008 | Relisys TL 766 Monitor
Monitor menu shows up all of a sudden
If the butttons are not stuck on these monitors it could be something as simple as dry joints on the monitor somewhere. When this happens again lightly tap the front where the buttons are without pressing any and the sides then finally the back. If any of this tapping causes the menu to suddenly disappear and reappear then its dry joints. Otherwise it could be a number of problems. Post if it does not work and I will tell you more. Good luck.
Jul 23, 2008 | Relisys TL775 17" LCD Monitor
Dec 27, 2007 | Relisys TL565 15" LCD Monitor
INPUT SIGNAL OUT OF RANGE
some how your screen resolution has changed above or below what your monitor can display. you need to boot your computer using another monitor that can work with the resolution your computer has switched to(i used a spare crt monitor when it happened to me) change your resolution in display properties to a normal level like 1027x768, and while the computer is on swap the monitor cables to verify the lcd is working.
It is perfectly safe to unplug the video cable and plug it back in while the computer is turnned on.
Dec 26, 2007 | Relisys TL775 17" LCD Monitor
Screen goes black after a few minutes, switching off and on and picture returns then goes black again
I have problem with my monitor, it is automatically switching off and switching on for 2 to 3 minutes for every 15 minutes why ?
Please mail me the solution to craju1@yahoo.com
Oct 21, 2007 | Relisys RLT1720 17" LCD Monitor
Monitor problems
You need to change down the res. to a minor mode. i.e. 800x600 low quality. For Windows enter the protected mode - i.e. after POST (bootup) press F8 then enter with your account, or the administrator. Right-click anywhere on the empty desktop and enter "Properties" menu. Turn the screen resolution down in there (i.e. 800x600); also, check whether your current monitor is recognized by model in there. Re-adjust to a suitable working resolution. If all fails, you can also de-install the video card driver in admin protected mode to go back to basics. Of course You need to re-install it again afterwards when in your original Windows.
Jan 28, 2007 | ViewSonic VP191b 19" LCD Monitor
Relisys TL 766 Monitor Logo
48 people viewed this question
Top Relisys Computers & Internet Experts
Samuel Konger
Samuel Konger
Marcin
Are you a Relisys Computer and Internet Expert? Answer questions, earn points and help others
