The system will not power on - it just comes on long enough to display "chk spkr" and then shuts down. it also buzzes when it tries to come on. it's not even on long enough to check the volume or anything else. any ideas? Help!!!!
Your problem is the output IC's The case where you say the speakers buzz tells you theres a short in the audio outputs. If your unit didnt shut off, the speakers would fry and the unit would also smoke. These are solid state devices and are soldered in, and are not concidered user serviceable parts, unless you know how to solder and trouble shoot Stereo systems. This is a job for the pro if you want it fixed. Good Luck
Overloads can be from excessive periods of high output and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced hands-on tech.
