Question about Health & Beauty
My Pride Mobility Celebrity X Scooter appears to be dead.
I have a fairly new scooter. I got it new about a year and a half ago but I have not used it much more than once or twice a week as an average. I am very good about charging it. I used it this last week with no problems. The charge indicator showed full scale when I pulled it into its normal parking spot. I decided to move it a bit and put the key back it in to turn it to the on position. No charge was showing, not even the led to show the code of what was wrong. No lights work. I pulled the seat and the cover over the motor and trans-axle. All connections were tight. The battery voltages were correct. I checked all the fuses and made sure the voltage from the batteries was making the trip to the fuses. The scooter just suddenly stopped dead in its tracks. I checked the freewheel lever and I plugged and unplugged the connectors just to make sure everything was making good contact. Just before driving it into the house into its parking spot I noticed it still had a full indication on the meter and had plenty of zip. It is though the key switch is not turning the scooter on.
What should be my next step in checking the problem? The scooter has had very light use and has never been left outside or driven in the rain. It is kept in a nice clean environment. I don't have a schematic diagram for the scooter or else I might be able to troubleshoot much more as I have a lot of electronics experience. I hate to start taking things apart unless I know what I am working with. I feel it has got to be something simple that I have overlooked.
Please help because I just can't afford to take it to the shop right now.
  • Larry Kennedy
    Larry Kennedy Oct 20, 2008
    I don't know if it has a safety switch or not. There seems to be a reset switch at the center below the seat with a rubber cover. It does not look like it has tripped. I have tried pushing the switch but it seems to be in the recessed position. I checked again last night and it looks like there is no voltage reaching the fuse box located on the tiller. I took all the plastic covers off to expose the wiring and the connectors all seem to be seated properly. But, there is no voltage measured there at the fuse box. The scooter is too heavy for me to raise it much but it looks like all the wiring runs inside a nice metal housing. I wish I could get a schematic so I could troubleshoot myself. Does Pride offer schematics to owners? I am a electronics tech myself so reading schematics is very easy normally. My specialty is radio electronics.
    Can you describe this tip over switch and where it would be located?
Many people have problems with their Pride scooters.
Pride refuses to issue any information or schematics, telling the customer to visit their dealer for chargable service.
Guess what !! The dealers don't have the info or schematics or service manuals either !!!
There are known faults and flaws in the Pride designs.
Look under the 'hood' for the controller - big box with heavy wires connected to the motor. Write down the manufacturer and model number from the data plate.
Go to the manufacturer's web site and get your manuals and info there. Curtis 1228 is a common model.
Also, pay attention to the temperature limits, and EMF / RFI sensitivity -- big problem !!
Finally, if your dealer service rep suggested offsetting the throttle handle slightly for more speed, he may have created another problem -- all controllers have a PROGRAMMED deadband, shifting the centering of the throttle lever throws the whole system out of balance - integral part of original setup.
Bottom line - find a reliable independent instrumentation and controls service person who is familiar with programmed electronic motor controllers.
Good Luck
Posted on Feb 17, 2009
  • digitalgranp Sep 30, 2010
    Try this link for a trouble shooting guide: "Pride Mobility: Information from Answers.com" without the quotation marks of course.
Pull the black mat that covers the footboard, underneath you should see another black panel with four screws, loosen them and remove the panel. You should see a small fuse panel with two fuses along with the controller unit, check the connections on the controller then pull the fuses chances are the 10 amp fuse is blown. Trust me, I work for a mobility company and I service these scooters constantly.
Posted on Aug 09, 2010
HI MY VICTORY PRIDE SCOOTER IS NOT WORKING WRIGHT I PUT IT ON CHARGE AND THE TOP AND BOTTEM LIGHTS ON THE CHARGING BOX ARE ON BUT THE 2 IN THE MIDDLE ARE NOT THE SCOOTER IS RUNNING BUT VERY SLOW CAN YOU HELP THANKS
Posted on Feb 07, 2009
    Problem Solver:
  • 18 Answers
Curtis 1228 series dead./charge guage shows empty. to check power unplug batteries, locate 4-6 leads next to 18 way plug on controller,lable and pull off outer two leads ,connect 24 volt bulb or avometer to the leads then reconnect batteries should be 24 volts here.if nothing here check wires/connections to batteries.if o/k refit two leads to controller after[ unpluging batteries].
then reconnect batts locate neg battery term and attach neg lead of avo to,avo to 30 volt range remove top of tiller to gain access to key ign switch and should be 23 to 24volt on both terminals of switch.this comes from pin 10 of 19way plug on curtis controller{top right pin key at top} 24volt out to
ign/horh status.led,no volts here check for continuaty on wireing between ign sw and pin 10 controller plug if o/k remove plug and carefully check with avo neg lead to battery neg, pos probe to pin 10 of controller no volts here indicates faulty controller,hope this helps.shimtamper
Posted on Jun 17, 2009
SCOOTER STARTS OUT FINE WITH PLENTY OF ZIP THEN AFTER ABOUT 30 MIN. IT SLOWS DOWN AND SEEMS TO BE SLUGGISH.
Posted on Dec 31, 2008
    Scholar:
  • 62 Answers
Is there a safety switch under the seat to disable the scooter in case it tips over? If so, this switch could be out of place. Or perhaps another safety switch.
Posted on Oct 19, 2008
Need a service manual for Celebrity XL Pride mobility scooter
Goto pridemobility.com. It's the American site as pride is an American product. User manuals and spec sheets etc available to download
Sep 09, 2014 | Pride Celebrity Xl 4 Wheel Scooter
What do pride celebrity x sport error codes mean
Download the otherwise fairly useless Pride owner's manual, the beeper codes are listed there.
Jun 12, 2014 | Pride Celebrity X 4-Wheel Electric Scooter...
Celebrity x mobility scooter . error code 5
The freewheel lever is in the neutral position (which allows you to move the scooter around by pushing it. Turn the key switch off then move the lever to the drive position , turn it back on and it should run fine. The freewheel lever is sticking up through the plastic cowl. It is located under the seat on the right hand side near the rear of the sccooter
May 27, 2014 | Pride Celebrity X 4-Wheel Electric Scooter...
Celebrity x 3 wheel scooter fuse
More information u don't mention what u want to know ...cheers
Apr 21, 2014 | Pride Mobility Products Pride Mobility...
Lost key to Pride Celebrity Scooter. Have an extra key for another Celebrity scooter. Are keys interchangeable? Thanks, DJ
DJ should work try it if all else fails call Pride @ 1-800-800-8586 ask for tech Support and ask to get a set of keys or You can replace the keyed switch with a on/off toggle switch Hope this helps
May 05, 2011 | Pride Mobility Products Pride Mobility...
PRIDE CELEBRITY DX RUNNING SLOW
Hi
Please Check your Potientiometer also known as a Pot, This is your Speed Control and it may be on the way out after 4 Years ,
My Own Pot Packed up after 11 Months, Try to get a Second hand one as they are Expensive to buy,
Good Luck, Gerry.
Jul 19, 2010 | Pride Celebrity X 4-Wheel Electric Scooter...
Brake not holding on incline
remove wheel then using screw driver
remove brake then replace and re screw
replace wheel
ted mobility centre penge 0208 676 0944
Mar 30, 2010 | Pride New Mobility Celebrity 3 wheel...
Need manual for celebrity x mobilty scooter
Go to cheapest-scooters.co.uk Then click on photo of celebrity x sport mobility scooter.Then scroll down page and click link to download owners manual. Hope this was helpful?
Sep 24, 2009 | Pride Mobility Products Celebrity X - 3...
Celebrity Pride SC440 scooter makes continuous clicking sound
the motor break assembly is going bad, if not replaced soon it will quickly draw down your batteries. smithrm70@hotmail.com
Sep 11, 2009 | Pride Celebrity X 4-Wheel Electric Scooter...
Health & Beauty Logo
2,964 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
