Question about Panasonic SB-WA100 Subwoofer
Bottom line I needed a solutions and right away and the guru's at hand were not helpful I would like to have my money returned since I am extremely dissatisfied.
  • 84 Answers
Oh! plaz. ask your question in detail? i will help you ....
Posted on Oct 20, 2008
  • rush2aaman
    rush2aaman Oct 20, 2008
    plz. give me sum detail about your problem?
What do I need to do when error 8 is displayed on turning on machine?
Jura does not allow access to internal parts for cleaning. Brew group is the dirtiest part as it deals with complicated movements to make coffee.
Error 8 means the brew group is not returning to start position after it completes entire cycle to make coffee.
Jura recommends to remove drip tray. Using a thin cloth, insert the hand all the way under the machine. You will feel access to the bottom of the brew group. Wipe clean the bottom of brew group as best as you can. There will be lot of coffee powder (wet & dry) that is partially responsible to prevent brew group return to start position.
A better method is to open the machine using special key. Clean & lubricate the brew group. every two months. This will prevent Fungus and Bacteria growth. .
Instruction videos are posted on You tube channel "Parts Guru USA"
Use the link below to order the special key. Services Unlimited Inc Parts Guru Since 1988 Services Unlimited Inc Parts Guru Since 1988
Mar 20, 2016 | Jura Capresso Impressa S9 Coffee...
I can't get the back cover off the nokia 1661 i already tried pulling off then end to bottom but it still won't. Please help I need this immediately. Thanks in advance.
Sadly these are just really stiff. hold the phone in both hands face down with the bottom of the phone pointing away from you. At the line just below the NOKIA badge press firmly down and away from you.
Also try holding the phone with your left hand keypad facing into the palm of your hand and the bottom pointing away from you. Place your right palm over the bottom cover of the handset and slide your hand away from you.
Jan 16, 2011 | Nokia 1661 Cell Phone
I need to solve this problem, can anyone help? 2.5/7 = x/10 How do I get this calculator to do it?
It looks like overkill to use the calculator to solve this first order linear equation but I will show you how to use the Solve function available on this calculator.
First solution: Pen and paper.
Use the properties of proportions:
Let a, b, c, and d numbers, with b, and d not equal to 0
if a/b=c/d then a*d=b*c
To apply it to your case, you set a=2.5, b=7, c=x, and d=10.
This gives 2.5*10=7*x
Dividing both members of the equation by 7 yields x=25/7.
Using the SOLVE program
  1. Calculator should be in computational mode: Press [MODE][1:COMP]
  2. Type in the equation in the way described below:
  3. You will need to use the key sequence [ALPHA][CALC] (=) to insert the = sign, the one at the top left, not the one at the bottom right.
  4. You will need to use the sequence [SHIFT][CALC] (SOLVE) to order the calculator to start solving your equation.
  5. You will need the key sequence [ALPHA] [)] to insert the X variable.
  6. Now that you have been alerted to the sequaences you will need, here is how to enter your equation.
  7. 2.5/7 [ALPHA][CALC] (=) [ALPHA] [ ) ] (X) /10
  8. While the above sequence is in the command line with the cursor still blinking to the right of the 0, press [SHIFT][CALC] to access the (SOLVE) command.
  9. The calculator displays in the top line of the dispaly "Solve for X". At the bottom there would be some old (irrelevant value).
  10. At this point you are expected to enter a value for your initial guess.
  11. You can for example enter 2 and press [=] at the bottom right. If you do not type a guess, the calculator uses the old (irrelevant) value as initial guess.
  12. So you enter initial guess 2 and press the [=/EXE] key at the bottom.
  13. After a while (could be short , if the initial guess is inspired) the calculator returns with the solution.
  14. The solution display screen recalls your equation on the top line,
  15. X=3.571428571 on the middle line, and
  16. L-R= 0 on the bottom line.
The L-R=0, tells you that the difference between the LEFT side and the RIGHT side of your equation is 0. That means the X given in the second line is the solution within the tolerance of the calculator.
If you are not happy with the solution (L-R different from 0), or the calculator failed to return a solution, you can press [SHIFT][CALC] (SOLVE) to restart with a better guess.
Feb 10, 2010 | Casio FX-115ES Scientific Calculator
I have a 3516 chain saw mod22-600035-18 Mcculloch the fuel lines
I wish I could help. There are no parts available, there are no Exploded parts lists I've found a link to. These are Chinese chainsaws with the McCulloch name. They ARE Chinese chainsaws and I'm disappointed in Mac. Most mechanics won't touch them. We can provide no more help with this saw. Sorry
Poulan or Craftsman gasoline chainsaws are reasonably inexpensive, parts are available, and given a little TLC perform well.
Jun 10, 2009 | McCulloch Garden
There is one red line from the top to the bottom of my TV screen.
This is a problem with either the processing board or the panel itself. If the set is only a few weeks old, you should be able to return it for an exchange. These things happen to these sets on occassion. Just request an exchange under warranty.
Mar 17, 2009 | Toshiba 37AV502U 37 in. LCD HDTV
Logitech Quickcam Express
Dear fixmy**** :)
Please find the driver for all operating systems at the following link
(Yes it includes windows 2000)
Regards, hope you get your fix (for the camera) :)
Please dont forget to rate this solution if you found it to be useful!
Apr 02, 2008 | Logitech QuickCam Messenger Web Camera
Rudder doesn't remain centred
Meanwhile the solution is EASY.
I had the same problem after a year or so. Trying to steer to the right, no response. Couldn't get worse, so i had to buy a new one, that gave me the possibility to experiment. This is what i did, and it worked. Turn the stick up side down, remove the bottom plate, only that. Put it on your desk and lift the grey plate up. There you see the x and y axis roll-contacts (excuse my tech-english). These are the little black rectangular contacts, you can recognise them by the multicolor wiring atttached. Theres 2 of them, one for pushing forward/back, and one for pushing left/right. Now be carefull, and spray a LITTLE contact spray on the middle of this roll-contact. It will lubricate the contact,which has dried up during use/time. For me it worked like a charm, as NEW! Do NOT unscrew the stick itself, otherwise you have to puzzle a lot to assemble it again (believe me, you don't need it and don't like it). Screw the bottom plate back and enjoy the flight again for months.
Dec 14, 2007 | Logitech Extreme 3D Pro Joystick
Thin bright red vertical line from top to bottom of screen
that is the screen burned out. if still have a warranty return to company and get a return/exchange.
Oct 26, 2017 | Sceptre X7G-Naga 17" LCD Monitor
2" black line from top to bottom
my Black line is horizontall top to bottom more to the right hand side
Dec 10, 2007 | LG MZ-42PZ44 42 in. EDTV-Ready Plasma...
Panasonic SB-WA100 Subwoofer Logo
48 people viewed this question
Top Panasonic Audio Players & Recorders Experts
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
