Question about Intertherm P3RA-048K Air Conditioner
Adding a Condensing unit to an Intertherm electric furnace
Well my problem is that an wiring issue that deals with the blower motor. It will work fine when in cooling but when switched to heating mode the motor will smoke. Its definetly a mis wire but schematic is set up for heating only and has had three other people rigging it up and now schematic isnt right and central air has been added also can anyone throw me some tips on what the problem could be
    New Friend:
  • 30 Answers
You have the motor connected on more than one speed in heat mode. make sure inly one mode is connected
Posted on Oct 30, 2008
I have a 1987 Intertherm FEH-015HA electric furnace. The issue I am having is that my blower will not shut of unless I pull the disconnect. My thermostat will operate the heating elements like normal,
You most likely have a bad fan limit / cycling switch. If you kill the power to the furnace see if you can trace the wires from the motor to where the connect to the switch. It looks like a round button with tabs sticking out of it for the wires to connect. Mark down where the wires were connected and take it to a HVAC business or furnace supply house. Be sure to have the model off the furnace with you so you can get the correct parts.
Nov 25, 2014 | Intertherm Heating & Cooling
Nordyne furnace FEH017HA-04 the fan runs full force when the ac is on but half speed when the furnace kicks in
That is probably normal if it is electric heat to slow the air over the heating elements. Even some gas units do this. Check to see if the unit blower motor has wires for multiple speeds.
Oct 24, 2013 | Coleman Intertherm Nordyne Miller Furnace...
Ac blower motor attic
that is a model number for the outside condensing unit. to find the motor size for the inside unit, you will need the model off of the inside unit, gas furnace or electric air handler.
Aug 15, 2013 | Ruud UAKA048 Air Conditioner
I have an old Intertherm gas-fired furnace, Model MGH-055AB which ceased operating last night. It was quite warm when I arrived home, and when I set the heat up a little, began to hum, but the fan would...
Tom P's answer is generally correct: The motor start capacitor is usually not the problem. However, in some cases, particularly on older furnaces, where there were capacitors of certain make and production run will prematurely fail. This happened in March on a mobile home HVAC unit where both the blower fan and condenser fan motor capacitors failed open circuit. Both caps were of the same Mfg, and production lot.
Here is a suggestion (for you or an electrically inclined friend): Locate a substitute motor capacitor having similar Mfd (or MF) and Voltage ratings. Remove power from the unit. Reach into the blower squirrel cage and spin it to verify that the shaft is not frozen. Pull the wires from the existing capacitor noting color and location. Connect the wires to the substitute capacitor and secure it place. Apply power and turn on the blower. A no start? Motor replacement time.
Nov 08, 2011 | Intertherm P3RA-048K Air Conditioner
I've got a Air condition unit model BV124 30-10L16, which is the part of Lennox furnace unit. The indoor fan stops working now. The outside fan works fine. I checked the capacitor, fine too. Cooling...
Hello, a blower motor will not run for one of theese three reasons 1) No power to motor 2) bad capacitor 3) the motor itself is bad. One test you could do is take the wire of the L1 terminal on the control board and use a jumper wire and connect it to the wire on the high speed motor tap , if this gets the unit running then the control board must be replaced if it does not work then the motor is shot......make suremwhen disconnevting wires the power is off.
Sep 04, 2011 | Heating & Cooling
How to replace Intertherm M1 Combustion Blower Assembly on an Intertherm M1MB 070A BW Gas Furnace Series #m1D020401209? I think this is the problem. The furnace squeals when turned on and it seems to be...
The combustion blower is easy to replace. You may be able to prolong the life of the motor by applying lubrication to the shaft bearings. If the motor is too far gone then replacing it is the only option. Just remove the screws that mount the blower case to the heater, disconnect the wires and reverse the steps to install a new motor.
May 04, 2017 | Heating & Cooling
Replaced blower motor in my Intertherm furnace, now blows cold
most blowers have a high( black wire) and low(red wire) low works much better in the heat mode
Jan 17, 2009 | Berkel 827E Gravity Feed Deli Meat Slicer
Intertherm heating
My heating unit is blowing cool air. The thermostat will start the blower when the unit is turned on at the thermostat, but the air isn't hot. But,when I turn the unit on at the furnace/blower using the "Fan On" button, I can see the heating element heat up. After the blower starts the heating element does out. What could be the problem?
Oct 29, 2008 | Intertherm P3RA-048K Air Conditioner
A miswire
The blower is smoking because you have it hooked up to the same wires you've hooked the electric coil to.  That coil runs on 240 volts.  Those wires are typically red and black.  The motor runs on 120.  One of the wires should be shifted to a neutral (white wire).  Assuming the motor is still alive...this will fix it.
Oct 19, 2008 | Intertherm P3RA-048K Air Conditioner
WIRING
why did the wiring burn?Id have the heat exchanger inspected before rewiring.better to be safe.
Sep 17, 2008 | Intertherm P3RA-048K Air Conditioner
Intertherm P3RA-048K Air Conditioner Logo
157 people viewed this question
Top Intertherm Heating & Cooling Experts
Dennis Boxerman
Dan Webster
Dan Webster
Bill Long
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
