Question about Panasonic Vacuums
The pole is stuck won't detach from the head of the vaccum, and the pole won't extend anymore
  • 566 Answers
Please say which type of vac? assume upright ? with a flx hose and attachments for vac of stairs or hard access areas are u saying the flex hose with the pole iside it stows at rear of vac and unclips extends pole from flex hose?? which part is stuck ?
Posted on Oct 19, 2008
How do I get a stuck floor attachment off the pole
treat this like a stuck jar lid. put it under hot tap water for about 30 seconds then try and get it to release. Make sure your vacuum is unplugged and only let the connection get wet
Nov 15, 2014 | Electrolux UltraLux 2000 Bagged Canister...
Hi. I have a Dyson Animal DC28, purchased on June 28th of 2010. The wand is stuck in the hose and I cannot remove it to use it.
I think I figured this out. If the hose gets twisted too many times while being used, the pole has a hard time going in and out for removal. (Kind of like how old phone cords got all twisted up after use for a while) To get it out, lift the pole out as far as you can then tug on the hose pulling it down & out ways until you can work the pole all the way up to get it out. Once out, detach the hose from the wand and turn it a few time (I had to go counter clockwise) to un twist the hose a little. Seemed to fix this problem for me.
Jul 11, 2011 | Dyson DC28 Animal Bagless Upright Vacuum
I have a Dyson Animal DC28 and the wand won't pull out. This has just happened out of the blue - I was using it with no trouble up to now. I pull up and it just gets stuck. Any help would be...
I'm sorry to hear you're having difficulties with your DC28 Animal. From what you've described, it sounds as though the hose may have been twisted the last time you replaced the wand on the machine. This is easy to resolve by following these steps:
  • Extend the wand upwards as far as possible
  • With the rear of the cleaner facing you, follow the hose down to where it attaches to the cleaner
  • Whilst stretching the loose section of hose away from the cleaner, pull the hose release tab to detach the base of the hose from the cleaner
  • Allow the hose to untwist itself
You should now be able to pull the wand out to it's fullest extent, removing it from the cleaner. Once you've done this, simply reattach the lower end of the hose to the cleaner.
If you have any further questions, or if you'd prefer someone to talk you through this process, you can call us free on 1866MYDYSON.
Kind regards,
Jack
Dyson Online Customer Support
Jun 27, 2011 | Dyson DC17 Animal Bagless Upright Cyclonic...
The check bag light comes on and vaccum quits but bag is not full. We changed bang anyway but vaccum would not start.
This is most probably due to a worn out or clogged Control Valve Assembly.
Detach the hose and see if it runs. If it does, place hand over hole. If it shuts off, CVA is probably the cause. A clogged CVA is generally due to using generic/made-to-fit bags. Genuine bags have "Home Solutions" printed on them.
You can try turning the dial all the way to the large dot, then try to run the vacuum.
If it is the CVA, you'll need to take it to an authorized Aerus Electrolux store and have their service tech repair or replace the part. I recommend a service and clean of the vacuum at the same time. This will extend the life of the vacuum.
Nov 23, 2010 | Electrolux Guardian Bagged Canister Vacuum
Unplugged vaccum hose and head of vaccum but still no vaccum what could be the problem
if the motor is running and you have checked airway then you may need a filter
Feb 27, 2010 | Kenmore 34721 Upright Vacuum
Electrolux oxygen plus 2100w telescopic tube is stuck. I wanted to extend it but the handle will not release and is stuck. Can you offer any suggestions?
I have a electrolux 2000 and my tube has a small tab that you push before it would let me release it. I had trouble getting it off as well. What I did was push the tab, Plasing one foot on the vaccume head holding it down while pulling up and twisting. I'm not sure if yours is attached the same way but this method worked for me. Good luck!
Aug 18, 2008 | Electrolux Vacuums
Pull Cord
CHORD STUCK , NOW FIXXED BUT METAL SPRING CAME OUT, WHEN WOUND BACK, HOOW DOES IT ATTATCH TO PLATIC COWL AGAIN?
May 15, 2008 | Euro-Pro PT205 Leaf Blower Powerful 12 AMP...
Door stopper stuck in vaccum
I would first check down by the brush roll, take off the plate so you can get to the inlet to see if it stuck there, could be in the hose or the bag tube. Could be that it damaged the motor fan, you have to remove the motor to check it. If You had listed the model number, it would have been alot of help.
Dec 25, 2007 | Vacuums
Vacuums Logo
105 people viewed this question
Top Panasonic Vacuums Experts
Jim Parker
Jim Parker
Roger Potts
Are you a Panasonic Vacuum Expert? Answer questions, earn points and help others
