Question about Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft. Front-Loading Washer
Whirlpool Question any solutions to the problem with the washer.
I finally called a tech service and he mentioned that our CCU central unit is not working and it cost $280 and $60 another part which both are back ordered for 3 weeks. the service call was also $70 so far and hopefully that fix the problem. will keep you updated. by the way, if you see F70 and F71 mentions that CC Central unit of the machine is not working and need to be replaced.
thanks and good luck for others with problem
Posted on Oct 20, 2008
What does an F-1 code mean on the display? washer will not start.
power problem
  • Whirlpool Fault Codes - AppliancePartsPros.com www.appliancepartspros.com > Appliance Repair Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • Washer Diagnostic& Repair - F1 Error Code power supply ... www.youtube.com/watch?v=BAVS9mI3JLQ
    • BY APPLIANCEVIDEO.COM
    • 4 MIN
    • 65K VIEWS
    2014-02-07 · Troubleshoot your trusty Whirlpool Top Load Washer that has these following symptoms: F1 Error Code At: http://www.appliancevideo.com To ...
  • Whirlpool Cabrio f1 error and how to fix it https://whirlpoolcabriof1error.wordpress.com Control board W10189966 will work with the Whirlpool model numbers listed at the bottom of this page. These models include the Maytag Bravos and Kenmore Oasis.
  • whirlpool F1 code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • 68 POSTS
    • FIRST POST: 2008-07-28
    2009-09-29 · Discuss whirlpool F1 code in Washer Repair. "whirlpool cabrio washing machine displays f1 code. have already pushed cancel and restart to no avail.
  • Cabrio Washer by Whirlpool F1 Error Code - Facebook www.facebook.com/CabrioWasherByWhirlpoolF1ErrorCode Cabrio Washer by Whirlpool F1 Error Code. 793 likes. Got the F1 Error Code? Tell your story! Share ALL your issues with this washer to warn others...
  • Whirlpool Fault Codes - Appliance Help Online appliancehelponline.com/whirlpool.html Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • May 04, 2016 | Whirlpool WTW8200YW Cabrio Top Load Washer
    Why do I have this Clicking Noise after bearing and seal replacement
    1. Ft. Cabrio Top Load Washer‎
      Adwww.sears.com/‎Black Friday Sale Save Over 40% on Select Appliance
      Hot Buys. Free Delivery Over $399.
    2. Appliance Hot Buys
      You'll Save More When You Shop Hot
      Appliance Buys on Select Products!
    Search Results
      Whirlpool WTW6400SW Cabrio Washer Makes clicking ...
      www.fixya.com > ... > Whirlpool WTW6400SW Cabrio Washer
      Whirlpool WTW6400SW Cabrio Washer, makes clicking noise spin cycle related issues. Get free help, solutions & advice from top Whirlpool experts.
    Nov 26, 2015 | Whirlpool WTW6400SW Cabrio Washer
    Whirlpool washer cabrio stuck on spin cycle
    solution- ID- is in the control program and the door lock. If, there is any warrenty on it, call Whirlpool and a Tech can help you with it.
    Sep 10, 2012 | Whirlpool WTW6400SW Cabrio Washer
    Cabrio washer F1 error
    Hi
    Thanks for using FixYa. Error code F1 indicates primary control failure and to resolve this you?ll have to replace the machine control assembly. Yes you are right, this error should be fixed by whirlpool as its a common issue with whirlpool Cabrio washers, you can call 1-800-253-1301 whirlpool will send a tech. to fix it and pay for the part. Please do rate the solution if the issue is resolved or post a comment for further assistance.
    Thanks
    Rylee
    Sep 07, 2010 | Whirlpool WTW6400SW Top Load Washer
    Whirlpool washer model WTW6200SW1 getting an F1 alert code can not clear by hitting cancel. keeps repeating.
    Hi
    Thanks for using FixYa. Error F1 means primary control failure and to resolve this you’ll have to replace the machine control assembly. This error should be fixed by whirlpool as its a common issue with whirlpool Cabrio washers, you can call 1-800-253-1301 whirlpool will send a tech. to fix it and pay for the part. Please do rate the solution if the issue is resolved or post a comment for further assistance.
    Thanks
    Rylee
    Jul 04, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
    I have a Whirlpool Cabrio Washer with a F 1 error message
    Hi
    Thanks
    Rylee
    Jun 25, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
    I need the washer machine settings
    download info from whirlpool.com, go to user manuals
    Mar 26, 2009 | Whirlpool Washing Machines
    Whirlpool washer
    No problem. I emailed you some helpful sites. Good luck.
    Jan 02, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
    Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft. Front-Loading Washer Logo
    59 people viewed this question
    Dan Webster
    Dan Webster
    Sal De
