Question about Clarion DB538RMP CD Player
DRX5675 button lights and dim display
The button lights on my DRX5675 do not light up and the display is dim. Any ideas? Thanks.
The light is dim with the door open or closed running.whats wrong?
Lights lowering in the kitchen when turning on microwave ...
Nov 4, 2012 - Lights lowering in the kitchen when turning on microwave oven: symptom of an ... In the best case, this may be normal if the dimming is minor.
Possible causes of dim Microwave Oven display ' All About Circuits > ... > Electronics > General Electronics Chat
Jun 13, 2013 - I've seen some Microwave ovens that will not display a backlight anymore. They still work, but the display is so dim, you have to be inches away to. ...Monitoring the output of a light-dependent resistor, or photoresistor, allows ...
What Is Causing My House Lights To Dim?
Dec 21, 2015 | Microwave Ovens
How do i replace burned out lightbulb in my in my cambridge soundworks cd - 740 clock radio ?
I believe the problem is either a faulty light sensor the unit has to dim the display when the lights dim since it was designed for bedroom use with alrms and snooze button. or it is simply a failure in the circuit that drives the LCDs. Mine has been dim for a long time but I can still see just enough to adjust the sound settings. I tune and set stations by sound. so the display has not been an issue since we do not use it for a clock or alarm. I doubt there is a fix for the dim display.
Mar 10, 2014 | Cambridge Soundworks CD-740 Clock Radio
Dim display on Cambridge Soundworks 88CD
I can't find a manual for this but my guess would be there is a setting for the Display to dim it at all times unless you touch a control.
Feb 26, 2010 | Cambridge Soundworks 88CD CD Player
The lights have gone dim
Press the yellow button on the remote, do not release. You will notice that lights will go from bright to dim and vice versa. Remote shows percentage of light on the LCD (display). Good luck!
Oct 31, 2009 | Hampton Bay AC414-LRU 52'' Kemper...
Cannot connect in any way to router, all lights on.
access your router's web-based configuration page at
Sep 04, 2009 | Linksys Wireless-G WRT54G Router
AC display won't dim after stereo installation
If you disconnect the stereo, does the temp. display go back to working properly? Did you connect the stereo Illumination wire correctly? Are all the other stereo wires connected correctly? Double check what the wires in the aftermarket harness are supposed to be and don't just go by color.
Jun 17, 2009 | 1996 Oldsmobile Cutlass Supreme Coupe
ASUS X80L has no display
hello..try to remove memory and make a clean using a paper eraser..thanks...^_^ ...
May 13, 2009 | Computers & Internet
Wave Radio-dial face,display very dim.
Our Bose did the same thing after a power outage. This one doesn't have a CD button, so we tried holding down the Clock button and used the volume control and that seems to have fixed it.
Mar 23, 2008 | Bose Wave Radio
Possible remote control problem
Have you tried holding the dimmer switch for 16 to 20 seconds?
Oct 21, 2007 | Hunter 20531 Vista Brushed Nickel Ceiling...
Clarion DB538RMP CD Player Logo
35 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
