Question about Sharp 65DR650 65" Rear Projection Television
Cant adjust picture with remote
Hi
I was talking with a gentleman earlier but we got disconnected i have a sharp 65" dlp that will not let me adjust the picture settings with the remote. it's stuck on "dynamic fixed"
  • Anonymous Mar 20, 2014
    Can dynamic fixed for picture adjustment be switched to unfixed.
  • 82 Answers
If you are using the The HDMI port "dynamic Fixed" is all the picture setting options you get. It's some manufacturers preseleted settings that you can not adjust, mine does the same thing.
Posted on Jan 03, 2009
Really dim picture
check your bulb life, there is a way to do that using your remote
Jan 26, 2016 | Mitsubishi WD-65638 65-Inch 3D-Ready DLP...
Sharp aquos 65- we have sound but no picture. What do I do?
There has been a power supply failure. The process of disconnecting then reconnecting the TV shocked the failing power supply back to life but ultimately it failed
Jan 29, 2013 | Sharp Aquos LC65E77UM 65 in. LCD HDTV
Color
U hear grinding noises,squiling noise,before colors fades in&out,turn to Black&White picture,than died?Yes,than ur DLP tv have a colors wheel,it defective,require replacing.The colors wheel is spinning off of it motor axis.The tv tech,should be hire for changing the tv colors wheel.
Jul 24, 2010 | Sharp 65DR650 65" Rear Projection...
My 2001 ws 65807 still has great picture but the remote seems to have gone south so I cant get to advanced convergence adjustment feature. The set has been moved twice since I originally purchased it. Is...
PART number for the original remote is :290P10310
Almost any Mitsubishi remote made in the last 8 years will operate this set--even the ones for the DLP type sets--stay away from universal remotes as most of the time the will do only the basic functions---I have talked to customers of mine who found used ones at swap meets etc for very little money---I would bet you can still get the remote from Mitsubishi--if I remember most of these are around 40 dollars from them.
Another idea is have someone at a TV shop look at your old remote--if they know what they are doing they can test it( I have a laminated card with a strip on it--point the remote at the card and the strip should light up when you press any button)
If if cannot be fixed---Try either Mitsubishi or I have seen a lot of these remotes for sale on Ebay.
Let me know if this helps you-----I am here to help people.
SD TECH
Oct 25, 2009 | Mitsubishi WS-65807 65" Rear Projection...
My tv will not power up. The light comes on and then goes off.
What is Wrong with TV? Have you replaced Lamp? If so and still no picture then it can be Ballast Board it connects to Lamp Box , Ballast is what turns Lamp on Call Encompass 1-800-638-3328 or Mats 1-800-628-1118 and you can also look up Parts on E-Bay!
Sep 29, 2009 | Sharp 65DR650 65" Rear Projection...
New TV won't ''talk to'' old VCR
using the magnovox remote, reprogram the vcr's channels. set it up to use cable not air. when the vcr was unlugged it lost it's channel memory. don't buy new cables, you're getting a picture and sound so that means your rca cables are ok.
Jan 20, 2009 | Sharp Aquos LC-32D40U Television
Hi, I have a toshiba 65H82. When I watch DVD's or just about any show that has music and people talking...I cannot hear the people talking because the music is too load. Is there a way to adjust this so...
you need to go in the menue under audio, there should be a prompt for mode, or something like that, should be able to switch between music, movie, sports, and so on, if you cant find in there, look for an audio button on the remote, hit that, see if it has those settings in it
Jan 11, 2009 | Toshiba 65H82 65" Rear Projection...
65 inch Sharp DLP TV
You likely just have a bad lamp. It is possible the light engine itself is causing the problem but the easiest way to determine which one is giving the problem is to replace the lamp. If the problem still persists the light engine is likely bad. The light engine is about $1000 plus installation. The lamp is $349.
Feb 08, 2008 | Sharp 65DR650 65" Rear Projection...
Sharp 65DR650 65" Rear Projection Television Logo
186 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
