Question about Fuji Cameras
I am unable to find how to get my camera to the USB mode to transfer pictures to my computer??
Hi dedebeth,
the easyist way out of your problem is to spend a small amount of money on a generic card reader, make sure it reads the same type of card as your camera and has drivers to go with your computer operating system.
baz cargo
Posted on Oct 19, 2008
PICTURES NO LONGER TRANSFER TO MY COMPUTER
Try NOT connecting your camera to your computer.
The best way to transfer pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa.
Organize edit and share your photos
Feb 15, 2014 | Canon PowerShot SX130 IS Digital Camera
Unable to transfer from camera to computer de to PTP blocking transfer
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
If you really want to do it the hard way, select "USB Mode" from the Setup menu and change it "PC".
Apr 30, 2012 | Panasonic Lumix DMC-LZ2 Digital Camera
I couldnt able to copy from my sony camera to my pc
RE not being able to USB function on Sony Cyber Shot camera connecting it to TV....solution was to change USB Mode on camera from PTP to AUTO.
Turn on camera, press home button. Click to Main Settings 1 and then use down arrows to go to Main Settings 2. Highlight USB MODE PTP, and use right arrow to change setting to AUTO, and press Home button to exit.
Apr 21, 2011 | Sony Cyber-Shot DSC-W220/B Digital Camera
I am unable to get my nikon coolpix l11 to install on my computer that has windows xp. I downloaded and installed nikon transfer 1.5.3 for windows and i installed it but nothing happens. I plug my camera...
Consider NOT using the USB connection.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Nikon Transfer or any other photo cataloging program.
Nov 16, 2010 | Nikon Coolpix L11 Digital Camera
Photograph Transfer. Unable to transfer from VAIO
Consider NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Feb 09, 2010 | Panasonic Lumix DMC-FS3 Digital Camera
DSC-S730 copy my picture to my computer?
The procedure to transfer pictures to a Computer depends on whether or not the Camera has the capability of using Picture Transfer Protocol (PTP). If the Camera is capable of PTP (in this case; DSC-S730 - YES), set the USB mode in the Camera menu to PTP and then use the PTP procedure to copy the pictures to the computer. Otherwise, use one of the standard USB transfer procedures.
This procedure must be performed while logged in as Administrator or to an account with Administrator rights:
  1. Turn on the Computer.
  2. Turn on the Camera.
  3. Insert the recording media containing the pictures into the Camera.
  4. Set the USB connection or Transfer mode setting in the Camera menu to PTP .
  5. Use the USB cable supplied with the Camera to connect the Camera to the Computer. NOTE: Connection through a USB hub or other USB device --such as a printer or keyboard-- is not supported and cannot be guaranteed. The Camera should be connected directly to a USB port on the Computer.
    NOTE: The Scanner and Camera Wizard should automatically start.
  6. In the Scanner and Camera Wizard window, click the Next button.
  7. Under Choose Pictures to Copy , do one of the following:
    • Click to select each picture you want to copy.
    • Click Select All to select all the pictures for copying.
    NOTE: Selected images will be marked with a green check mark.
  8. Click the Next button.
  9. Under Picture Name and Destination , in the Type a name for this group of pictures field, enter a name for the folder where the pictures will be saved.
  10. Next to the Choose a place to save this group of pictures field, click the Browse button.
  11. In the Browse for Folder window, click to select the location on the computer where you want to save the pictures.
  12. Click the OK button.
  13. In the Scanner and Camera Wizard window, click the Next button. NOTE: The pictures are copied to the Computer.
  14. After the transfer process it finished, under Other Options , click to select Nothing, I'm finished working with these pictures .
  15. Click the Next button.
  16. Click the Finish button.
If you are still unable to transfer pictures, please switch the USB mode of the Camera to Normal or Mass Storage and try again.
After following the steps above, the pictures from the camera should successfully be copied to the computer. If for some reason the pictures did not copy, try using the method for standard USB picture transfer.
I'm assuming you are using the Windows XP Operating System in the Computer. If not then follow this link:
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C116935
Good Luck!!!!!!!!!!!!!!!!!!!!!!!
Sep 06, 2009 | Sony Cyber-shot DSC-S700 Digital Camera
Unable to connect to computer
Try using a separate card reader to download your pictures.
Sep 05, 2009 | HP Photosmart M547 Digital Camera
Can't transfer pictures to computer
First start easy share program, than turn on camera, then plug in to usb
Jul 01, 2009 | Kodak EasyShare C340 Digital Camera
Unable 2 transfer pics 2 PC from Nikon L16
while the camera is connected to the computer does it show up in My Computer? If it does then you can go into the folders and get your pictures and copy and past them where you want them.
Jun 13, 2009 | Cameras
Unable to unload pictures from camera to computer
I would never use my camera to transfer pix to computer. I would buy a (usb or other) card reader and save wear and tear on camera.
~Thomas~
Mar 24, 2008 | Vivitar ViviCam 35 Digital Camera
Cameras Logo
29 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
