Question about NEC Dterm DTP 16D-1 Corded Phone
NEC phone How do I turn off the DND do not disturb feature?
CLICK THE DND BUTTON ONCE, GIVE IT A FEW SECS AND IT SHOULD GO OFF.
Posted on Oct 29, 2008
How do I take off do not disturb
If you have a DTP-16D phone, I believe that device was used primarily on the NEAX 2000 system by NEC. If that is true, you can try the default DND cancel code: #8 (*8 sets it). Unfortunately, the system codes CAN be changed by the installer, so it could be something else. Please let us know if that works. Thanks.
Sep 18, 2015 | NEC Dterm DTP 16D-1 Corded Phone
How to disable do not disturb on NEC Dterm80 phone?
Have a coworker call your extension to see if DND is on, they will go straight to voicemail or get a fast busy. Speaker 42 may be the default cancel DND code, depending on your system and whether the codes were changed. Anyway, ringing is set up in system programming. If someone calls your extension it will likely ring, but outside calls have to be assigned to ring in system programming. Usually need a tech to do the programming since it gets complicated very quickly.
Sep 09, 2014 | NEC Dterm DTP 16D-1 Corded Phone
Phone is displaying DND (do not disturb)
Do not pick up the receiver press feature button dial 60 press feature button again, at least this worked for me.
Mar 17, 2009 | NEC DTU-32D-2 Corded Phone
Features
Not sure how you set this feature but here is the solution:
To set DND you would have pressed your feature button, 60,and then feature button again (if you were forwarding to another extension you would have had to enter an extention after 60 and then the feature button. This sets your DND or call forward.
To eliminate press feature, 69 and then feature again this should cancel the call forawrd or do not disturb.
Oct 01, 2008 | NEC Dterm DTP 16D-1 Corded Phone
Taking off DND
press "feature" 69 then press "feature" again ~ problem solved!
May 16, 2008 | NEC Dterm DTP 16D-1 Corded Phone
Stuck on Do Not Disturb
Press Feature + 69 + Feature to cancel DND.
Feature + 60 + Feature turns DND on.
Apr 22, 2008 | NEC Electra Elite DTU 16D-2 Corded Phone
NEC DTH16D-1
Press Feature 69 Feature to turn off the do not disturb. Feature 60 Feature turns it on.
Sep 25, 2007 | NEC Electra Elite 32D-1 Corded Phone
NEC Dterm DTP 16D-1 Corded Phone Logo
416 people viewed this question
Top NEC Lands Phones Experts
Brian LaDuca
Oloyede Monsuru
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
