Question about Tao XM2go Satellite Radio Receiver
Xm2go stuck at preview channel 1. if other channels are selected it bounces back to channel 1.
  • Chevyc Dec 17, 2007
    I had the same problem. Tried the "refresh" from XM, but never recovered. I finally tried to reset the radio back to factory default settings on the menu, but when I did this the display went blank and now the radio appears to be dead. Anyone have any idea as to what is wrong?
  • Anonymous Jan 22, 2008
    I have the same problem. I called XM support number and the assistant "refreshed" the system, but no luck.
I am xm radio agent. is not a reset is a REFRESH!
Posted on Dec 21, 2007
I had a what sounds like the same problem. More than likely you need to "reset"(our account with XM Radio. (Your radio have stop communication with xm except for channel 1) You can call XM or go to XM'S website. If you have not setup your account for internet usage you will have to do so before you can manage (reset) your radio. Once you reset your radio it may take up to 1 hour before it works. My radio took about 15 min. Good luck
Posted on Nov 20, 2007
SOURCE:
I need to sync my snowball into cubase sx... its only recording on the left input not the right input of the audio wave. please help get back to work.
This is strictly a software setup problem. I use Sonar, but Cubase has to have the same features. Look for a PAN control and also where you MIGHT be able to select that both channels of the stereo are mapped to the single input. A work-around might be to bounce the input to a second track and then do a channel swap on one of the stereo channels, then combine them. I think Cubase uses the word "flip".
Search your documents for keywords: flip, bounce, swap, pan, and assign input. You can also copy and paste the recorded channel to a second stereo blank channel before flipping it and combining.
Mar 14, 2013 | Blue Microphones Snowball Professional...
Sony KV-20S40 stuck on channel fix
I have just got a kv-20s43 and your best bet is to try to restore settings, here, To reset TV to factory settings, turn the TV on, Then, while pressing the reset button on the remote control, press POWER on the TV. The TV will turn itself off, then back on, the original settings wiill be restored... definition: ch. fix- 2-6: Select when you want to control all channel selection through a cable box. Select the appropriate channel(usually 3 or 4) and use the cable box's remote control for channel selection. VIDEO: select from available inputs when you have connected video equipment and you want your TV fixed to it.
Feb 01, 2010 | Sony KV-20S20 20" TV
T. V. stuck on one channel showing the device option.
I had same problem and discovered one of the little buttons on the front of the TV was stuck down. Don't know why, unless the maid bumped it hard as we never use them. Anyway, I poked/wiggled a few times at each button and the problem stopped.
Mar 17, 2009 | Mitsubishi WS-65511 65" Rear Projection...
Mitsubishi CS-31505 TV - UN-memorize QV (Quick View) Channel?
I've learned from a Mitsu tech that there is indeed NO easy (nor logical & user-friendly) way to UN-memorize a QV channel.
However there IS a work-around to accomplish that so that the QV will revert back to its Factory Setting of "Last Channel Recall."
Using the Mitsu remote control:
1. Poke the Menu button.
2. On the Menu, select the "Add/Delete Channels."
3. Select the Antenna (A or B or whichever) and select the channel which was memorized in QV.
4. When that memorized channel number appears, select "Delete."
5. Poke the Menu button again to exit.
The QV memorized channel number is now gone, restoring the QV function to "Last Channel Recall."
NOTE: If that particular deleted memorized channel was also included among the SQV (Super Quick View) channels, it can then be added back into SQV using the Menu and SQV option.
Hope the above helps those who have encountered the same issue.
DWL
Jan 17, 2009 | Mitsubishi CS-31505* TV
Xm2go direct entry tuning problem
You have it set on a preset mode now. On the unit or the remote control press the "pre/dir" button a few times until you see the word "DIRECT" at the top left of the screen next to the antenna strength. From "direct" you can then key in the channel numbers directly to go to them.
Nov 15, 2008 | Delphi MyFi SA10113 XM Radio Receiver with...
Will not play all channels
It was just a simple refresh via the internet. thanks
Jun 16, 2008 | Tao XM2go Satellite Radio Receiver
Sylvania TV stuck in Game mode remote no longer works
go up to your TV and go into the menu. Go to the channel selection and run the auto select for channels. This will take some time but the TV will end off the first channel found, the only thing is you cannot get back into video mode without the remote
Mar 26, 2008 | Sylvania 6413TC 13" TV
Suddenly cannot tune
Reset everthing in the menu. Mine does this every few months or so. I scroll thru the menu option until a come to a reset thing.
Dec 18, 2007 | Pioneer AirWave XM2Go Satellite Radio...
Tao XM2go Satellite Radio Receiver Logo
1,078 people viewed this question
Top Tao Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Tao Audio Player and Recorder Expert? Answer questions, earn points and help others
