Question about Quantum Fireball Lct20 (QML20000LD-A) 20 GB Hard Drive
Hard drive 20.4 gb
I plug it in and it will not register it is there
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 201 Answers
1st of all, check your PC is it has 2 HD or not, if there are 2 HD then make sure 1 is set to Master and another 1 is Slave or Cable Select. If there is only 1 HD, then have to set it to Master.
After this, enter the BIOS to see whether the PC can locate the installed HD or not.
If it is not, then make sure the HD is connected single with IDE cable (do not share with CD-ROM or the other HD, if it is share the unplug the other 1).
If the problem still then may be u can check the HD either is still functional, find a IDE to USB converter in computer shop and connect your HD to your PC and see either the HD can be detected or not as an external HD. If no, then the worst case show your HD is spoil already.
YBC (/\)
Posted on Oct 07, 2009
Bent pins on mt toshiba portable hard drive
how damaged are these pins can you send a photo
you might need to straighten the pins you could use point nosed pliers
depending on gaps / spaces between pins pliers might not fit
or use tweezers or 2 fine screwdivers holding one at the center of bend the other at the top to try to straighten
hope it helps
Sep 08, 2012 | Toshiba Canvio 500 GB USB 20 Portable...
When plug in to the usb port does not register on the computer
I standard platter based hard drive should never make a clicking noise. It indicates the head is damaged and can no longer read or write. Think of it as an old fashion record player. Best case scenario it's about to fail.
Sorry for the bad news.
Aug 31, 2012 | Toshiba (HDD2189) 60 GB Hard Drive
OKI (70050501) 20 GB Hard Drive
To back up the data from this hard drive, connect this hard drive to an USB hard drive adapter, then plug this USB adapter with the hard drive into the USB port of a working computer. The computer will see this hard drive as an external mass storgae device. You can then open the folders and files on this hard drive and copy your data to this computer or to an USB memory stick.
Jun 04, 2012 | OKI (70050501) 20 GB Hard Drive
My kingston quit working on my comp., will not register at all, I am not able to use,
If you are plugging it into a hub try unplugging usb hub and plug back in then insert the stick again to see if it comes up
Dec 01, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
I need the driver for XP for my archos mini HD
External hard drives are normally Plug and Play. If you're being prompted for a driver, you might need to install the chipset driver for your motherboard.
Jul 29, 2011 | Archos MiniHD 20 GB USB 20 Hard Drive
Not registering on my computer
You might try a different cable, but make sure it is under 18" for bus-powered devices. You might also check the drive on another computer.
Jan 24, 2011 | Hitachi SimpleDrive Mini 250GB USB 20...
My Transcend StoreJet 320 GB USB 20 Hard Drive is having a problem When i connected the drive to my laptop it got detected for sometime and then disconnected automatically
Probably not the right answer for your problem. Mine is an external 1 TB Simple Drive. Mine wouldn't respond at all. I unplugged the power cable from the back of the hard drive and replugged it in and instantly it worked (with the computer and hard drive plugged in). I had tried rebooting the computer, plugging/unplugging over and over into the computer and that didn't work.
Jun 16, 2010 | Transcend StoreJet 320 GB USB 20 Hard...
Trekstor 160g hard drive, disconnected whilst in
your hard drives logic card has bursted
so contact to your's hard drive recovery console
Aug 27, 2009 | Trekstor (21202) 160 GB USB 2.0 Hard Drive
Quantum Fireball Lct20 (QML20000LD-A) 20 GB Hard Drive Logo
264 people viewed this question
Top Quantum Computers & Internet Experts
Tape-Techie
SirEbrum
terminalcon
Are you a Quantum Computer and Internet Expert? Answer questions, earn points and help others
