USB Port Please can someone tell me the use of USB Port? I want to know its uses
    Problem Solver:
  • 5 Answers
USB port is used to plug external devices such as pen drives and other supported devices.. first of all there exist two usb ports: 1.0 and 2.0 . so when you connect your devices via usb, make sure that you have the 2.0 port for faster transfer rate.it is also a way to add more devices to your pc without having to unscrew anything.there are plug and play devices and non plug and play devices which require specific driver
Posted on Oct 26, 2008
I accidentally unplugged the hard drive, the DVD drive and the aux input without making a note of where they were attached.
As per your hard drive and your DVD drive, you should see the SATA(serial ata) ports on your motherboard. NORMALLY, these are marked starting with either a 0 or a 1... ex: SATA 0; SATA 1; these are used to help the motherboard use the right sequence as it boots up. ***THOUGH THESE PORTS MAY BE NUMBERED, THE BOOT DEVICE OPTIONS CAN BE MANIPULATED FROM INSIDE THE BIOS***
Now, as per your Auxiliary input, you should see printed on the board a port that says Aux 1. I assume you are trying to get the front USB\card reader port on the front of your unit hooked back up. If you will look at the pin configuration holes on the Aux cable then you SHOULD be able to match that up with what you have on the board.
Hope this helps.
If you need any further assistance please let me know.
Apr 15, 2016 | Computers & Internet
Use magic jack on my kindle fire?
No. There the USB port on the Kindle Fire doesn't host any signal. It is strictly used as a port to plug an external storage device into.
Mar 10, 2015 | magicJack Plus
Hi, my Lap top usb port is not working when i checked with one of hardware guy hes telling that usb problem and need to be change motherboard for laptop. Please let me know we can get only usb port in...
As an alternative to replacing the motherboard. Purchase a PCMCIA USB card and insert it into the PCMCIA slot in your ThinkPad. Use this USB card for your USB devices, cheaper than replacing the motherboard if you can get one. This model ThinkPad is old.
Jan 24, 2011 | IBM ThinkPad T43 Notebook
I have ipod nano 1st gen and my ipod wont detect by itunes even my explorer using USB 2.0, i have firewire port wall charger when i try to plug it it charge but idont know if it will work to computer cause...
There might be a few issues here:
1. Your ipod software needs to be updated
2. Your usb cord is bad
3. Your usb port is not working properly
Either find someone that has a firewire port and update it via itunes, or use someone elses computer to update your ipod's software.
www.huskyipodrepair.com
http://repair-scratched-ipods.blogspot.com
Jan 26, 2010 | Apple iPod nano
I have an ACER ASPIRE X1700, and I don't know where the printer UBS port is. Could someone please help me?
You can place the Printer USB Cable in any USB port.
If you are not familiar with how the USB port please refer this link.. USB PORTS
Hope this will helps you.
Thanks & regards
Nandu :)
Dec 31, 2009 | Microsoft Windows? Vista Home Premium...
A USB device has exceeded the power limits of its hub port
Hey,
Buy a usb hub with a power adapter.
this one for example
http://www.xpcgear.com/usbhubuh204d.html
Let me know if you need anything else.
Thanks,
Ekse
Feb 23, 2009 | Microsoft Windows XP Home Edition
Recessed USB Port ?
Through my experience and my friend having the same laptop. His is not like that. I have never heard of a recessed usb port. Most all usb connections on have about a half inch male fitting. Unless you are Tech savvy and know how to open the case and fix it yourself I can see it causing you problems down the road. I could be wrong, but like I said, I've never heard of a recessed usb port. Have a great day and I hope this helps you out.
Jan 15, 2009 | HP Pavilion zd8000 Notebook
Hanging problem
ya u are rite connect the cable thr will show that mtp connected then transfer music but is it hanged on than this means ur usb port has problem than try to use different usb port...make it sure u are using rear usb port of ur pc.....hanging problem is only due to breakage in transfer of data that is only due to low usb port...i have same problem i always connect my media player in front usb port of pc then i got to know that it has low speed than i connect it to rear of usb port in my pc that is high speed port than it worked smoothly
Sep 02, 2008 | Samsung YP-K5JAB MP3 Player
Camera won't let me upload!
try useing it on another computer you dont have to install sony software to use the camera on another computer if it dose work that tells you that its prob your USB port.
Feb 20, 2008 | Sony Cyber-shot DSC-S700 Digital Camera
Could anyone tell.........
What the Adapter Serial to USB does is create a virtual COM port on your computer. Try to see what port number it's assuming. Sometimes it can be a conflict of COM's. Use the Add/Remove Hardware wizard. Regards
Sep 11, 2005 | Sony Cyber-Shot DSC-F55 Digital Camera
Computers & Internet Logo
177 people viewed this question
David Payne
David Payne
