Question about Refrigerators
Ge refer not blowing cold
GE TBX 23Z refer has been working fine. moved it to assist in tile install. place back, olugged in starts to blow cool then after 2 hrs it blows room temp. It is clean dust free in under carriage and has plenty of air space. Fan blows very strong. I do hear a click and then 2 -4 seconds later another click. This continues every couple minutes. Sounds like poss the compressor is trying to engage? Not sure? It is older but a very nice unit and blows well, any ideas?
  • 750 Answers
Hello mancoder,
Welcome
You said, your GE TBX 23Z refer has been working fine. moved it to assist in tile install. place back, plugged in starts to blow cool then after 2 hrs it blows room temp. It is clean dust free in under carriage and has plenty of air space. Fan blows very strong. I do hear a click and then 2 -4 seconds later another click. This continues every couple minutes. Sounds like poss the compressor is trying to engage? Not sure? It is older but a very nice unit and blows well, any ideas?
It sounds like the compressor to me!
in a fridge that is ten years old or more it is not worth the investment of putting good money in to bad.
The newer fridges use a lot less power and your utility bill will go down
It will pay for itself in only a few years!
Here is an article I just read that you may find useful and interesting!
Repair or replace?
When to pull the plug on your old refrigerator
It nearly always makes sense to undertake simple do-it-yourself repairs,
such as replacing a gasket on a refrigerator or a freezer.
Typically, you'll also find a troubleshooting section for more-serious problems
in the owner's manual.
Should you pay for a repair or buy a new model?
The answer depends mostly on the age of your refrigerator,
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense.
If your refrigerator is under warranty or less than four years old (three years for top-freezers),
paying for a repair makes sense.
Note that refrigerators under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your refrigerator is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models are quieter and have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new refrigerator.
Data also shows that it doesn't pay to fix a less-expensive top-freezer refrigerator
six or more years old or a bottom-freezer or side-by-side eight or more years old.
Thanks to better recycling programs, less than 10 percent
of a refrigerator you replace is likely to end up in a landfill.
Let me know what you decide and if you have any more questions
Thanks for giving me the opportunity to help!
Please do not for get to give a rating before you sign off!
Thank You, HUUUM
Posted on Oct 19, 2008
Refrigerator ping noise
call a technician for a proper diagnosis
could be a problem start/run capacitor for the compressor
Jun 27, 2017 | Refrigerators
My GE model GSH25JFTCBB side by side is not cooling in the fridge side. Freezer seems to be doing fine. What could be wrong
you could have a defrost problem,a bad damper,bad computer board.first thing,open the freezer door,do you hear the fan blowing in there?you should,if not the evap fan motor is bad,if it's blowing touch the back inside wall of the freezer to see if any frost or like snow is on it,from the bottom up in the freezer remove the second bin of food and touch the back inside wall with your hand,if it has frost or snow you have a defrost problem,bad defrost thermostat,heater,sensor or board,if there isn't anything on the wall then you have a bad damper,all that happens is the evaporator coil in the freezer gets cold,then the evaporator fan in the freezer blows the cold air over into the fridge section,you have a damper in your machine that opens and closes when it's cold enough or when it needs to get colder,the door on the damper isn't opening to let the cold air in when it calls for cold air.if you can write back and let me know what you find and hopefully we can get it fixed.
Sep 15, 2012 | GE Refrigerators
I have a GE profile side by side and the freezer works fine but there is warm air that is blowing into the fridge part.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 02, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
My GE Side by Side is not working wierdly. the top few shelves on both the freezer and refridgerator are not cooling but the bottom shelves are cold.
Check to see if your evaporator fan is blowing in the freezer, then check your condensor fan behind the back panel. If those are both running make sure your coils are clean underneath your fridge. Cold goes down heat goes up, that's why it is warm up top and cold down. Start there. Good luck!
Aug 21, 2010 | GE Refrigerators
My GE side by side (GSS25JFMD WW) is not cooling. It's blowing cool air, but not cold .
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
May 15, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Is not cooling
you may have defrost problem hear if compressor morking
Apr 06, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Wont no water to empty or drain
Either the unit is really dirty or it is low on refrigerant. A unit tha is low on refrigerant will start off cold and withing a few minutes, start warming up. If you aren't seeing any water its because of one or both causes listed.
Apr 01, 2009 | GE APN08AA Portable Air Conditioner
Problem with GE Zoneline 5200 model
Heat pumps have saftey circuits that prevent liquid flooding of the compressor. Inadequate airflow across the evaporator in cooling can trip this circuit. Have your package unit serviced with particular attention to cleaning the evaporator coil and be sure your filters are clean and changed frequently in the summer months. Hope this helps GL!
Jun 07, 2008 | GE Zoneline AZ38H12DAD Split System Air...
Refrigerators Logo
393 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
