Question about Ricoh Office Equipment & Supplies
Aficio 2035 Anybody know where I can get a manual for this multi-function copier? I have the 2035S/ P model, and am trying to figure out how to set up the scanner feature in a peer-to-peer network. Thanks in advance for any help. Note, the Ricoh website was of no help.
  • ashtro Oct 19, 2008
    First, many thanks for your response Bubbabear. I started to do what you said, but under File Transfer there are only 2 options, "SMTP Server Name" and "Delivery Options", with the latter off. No "Domain" selection under File Transfer. Looking around...
  • ashtro Oct 21, 2008
    Bubbabear,
    No luck. I put in the Domain like you said, but under Step 8 (select file), there is no option. This being under the Key OP/ Address Mngmnt/ New Program. I select the New Program Button, and after that here are my choices:
    Name
    User Code
    E-Mail
    Group
    I am able to put a Name in for this "New Program", but I browsed around everywhere within the Key OP group, to no avail. If your free and have any more suggestions, I appreciate any more help. Thanks again. BTW, I printed out the configuration page, and can send/ drop that (dropio is what I use) that printout to you.- ashtro
  • Ricoh Master
  • 2,794 Answers
Can't give you the service manual due to legal reasons but you can check on copytech.com and see if you can get one one there. The service doesn't really tell you how to do it either so I can tell you how to do it:
1) Press user tools/counter.
2) Press file transfer.
3) Enter the workgroup name under domain.
4) Exit out to go to Key OP tools.
5) Look for address book management.
6) Select new program.
7) Give it name (name of person or computer)
8) Select File.
9) Select Browse
If it worked you should see computers displayed on the screen. If you don't see any, follow the troubleshooting suggestions below:
For you workstations:
1) Make sure you have a shared folder on each computer that allows for access to all users (or everyone).
2) Each computer needs to be accessed by a user id and password. You will need to type them into the copier.
3) No computer should have any firewalls turned on. Firewall control must be done on the router. Windows Firewall software needs to be disabled from each workstation. You may need to get into administration settings of each workstation to disable it permanently.
4) Certain versions of Norton sottware can block communication regardless or weather or not the firewall is on or not. If that's the case it will have to be disabled to get to work.
5) File and printer sharing should be turned on each workstation.
I do these for customers on a regular basis. I had to find a lot of this out on my own. Hopefully this will help you out.
Posted on Oct 19, 2008
  • Tim Babcock
    Tim Babcock Oct 20, 2008
    My bad.  Go to interface option under user tools/options.  It's the screen with the IP address.  Press the next button on the screen.  Insert the domain name in there.
How do i res-set the continuous door open message on ricoh 2035 copier
According with the Service manual if in the control panel don't show any places or any door, change the switches on the front cover area and the switches of the fuser area.
If the problem continuos check the laser area.
Hope this helps and just keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa.
Nov 01, 2011 | Ricoh Aficio 2035 Copier
How do I darken my copies in a 2035 aficio
Hello!
Look in to the touch panel, at the down left corner and you will see it.
You have 2 arrows. One for left to brighten and one for the right to darken.
Jul 19, 2011 | Ricoh Aficio 2035 Copier
Ricoh aficio 2035 - prints are streaky
did yo meen that lines streaky if that is issue yo must change blade of drum
May 02, 2011 | Ricoh Aficio 2035 Copier
Td sensor setting problem ricoh 2035
i think you are facing the problem with SC-390 while initialization,The TD sensor output voltage is less than 0.5V or more than 5.0V after 10 consecutive times during copying. that meens TD sensor defective or Developer failure or IOB bord faiure if you are not a tech. person please call the right person to fix this problem
thankyou
Dec 16, 2010 | Ricoh Aficio 2035 Copier
Ricoh Aficio 2035 wont duplex, displays error message error: Duplex unit is not set. Set it properly
there is a sw on the duplex unit that tells the copier it is closed my guess is that its broke
Nov 04, 2010 | Ricoh Aficio 2035 Copier
HOW TO FACTORY RESET THE SETTINGS OF AFFICIO 2035 E
Hello sir; You have to print out SMC list before you clear all memory then to reset, the procedure as follow;
1, press "clear mode", "107".then hold down "clear/stop" key.
2 enter 5990 press enter.
3, touch on screen "execute".
after print out go backto clear memory.
4, enter 5801-1
5, follow the list to reset each item.
May 27, 2009 | Ricoh Aficio 450 Copier
505 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
