Question about Refrigerators
Electrolux ERL6296XK1 Fridge Freezer has flashing error code E F Cannot reset the error so not sure if fridge / freezer are actually working. It did have a problem with the ice maker over filling before the error code appeared.
  • Tall Mom Nov 07, 2008
    Electrolux E23CS78GS
    Cannot reset the error. Both Frig. & freezer are not working. Had repair person come out twice & they called Electrolux who said it was the evaporator fan - which was then replaced but it did not fix the problem. The repair person left with the E F code still flashing. It also has a problem with the ice maker over filling which occurred before the error code appeared. Unit has been in use for only 14 months.
Had the same problem with an ew26ss65g50. unplug the machine and let it defrost. then plug back in after an hour or so. problem is the evaporator fan gets iced up from water spilling in/on it and air does not circulate. makes a horrible grinding noise before it shuts down. anyway, my icemaker is off right now and that solved the shutdown problem. working on repairing it.
Posted on Nov 24, 2010
Water dispenser line frozen, items freezing in fridge side. Freezer constantly running/blowing
Your freezer is what actually cools the refrigerator. The cool air enters from that spot on the top left of the freezer. Make sure that isn't blocked. It's sounds like the thermostat that controls the air flow from the freezer to the refrigerator isn't working or the air flow control device is stuck.
Either way if you can, unload and unplug the unit. This will do to things. First it will reset the circuits that control everything and secondly if the air flow control is frozen thawing out the refrigerator and freezer may free it up.
Feb 04, 2014 | Electrolux 25.9 Cu. Ft. Side-by-Side...
Electrolux icon side by side fridge is flashing E and F instead of holding the temp for the freezer and fridge. How can I fix this?
Hello Debbie Zymet - Typically error code E and F indicates that there is an error with the evaporator fan in the refrigerator compartment and fan in freezer. I would suggest contacting a professional move forward accurately for proper diagnosing and repair.
Nov 18, 2012 | Electrolux 25.9 Cu. Ft. Side-by-Side...
Fridge/freezer. Freezer works great but fridge is
Air from the freezer is blown into the fridge by a fan, some new type frigs have electronic controls that open and close a vent to frig. the older ones have two vents in the frig from the freezer and when covered with frost or ice the air will not reach the frig. check for ice or just defrost the freezer if there is ice or frost, also check for food or plastic over vents in freezer. Also check that the freezer fan is running as these sometimes become blocked or defective motor.
Mar 07, 2010 | Electrolux Freezers
Electrolux fridge freezer.FRIDGE NOT COOLING?
i checked out a different website and got my solution straight away.
Jan 08, 2010 | Electrolux Refrigerators
Any info on electrolux RA1300 gas fridge. Freezer works well but fridge compartment doesn't chill
If you had an electric fridge the problem is usually the evaporator fan motor ($30).
I suspect that you may have the same problem. Generally, freezers are cooled only, when the fridge needs cooling, the evaporator fan comes on and blows cold air from the freezer to the fridge compartment. The advice below is for an electric fridge but may also work for you, it's worth a try I suppose.
Check to be sure you can get a replacement fan first, they last about 4 - 5 years. Available from a parts supplier or electric motor company.
Unplug fridge, or disconnect gas etc. Fan should be located usually in top of freezer behind a vented cover plate. Remove cover, remove screws holding fan in, may have to cut wires. Replace with new motor, make sure the fan spins the same direction (CW OR CCW) as your old one, if you don't know which way it should spin then be sure it pushes air into the freezer area and doesn't spin backward drawing air from the freezer area.
Nov 10, 2009 | Electronics - Others
Freezer not working on ariston fridge freezer 2 orange lights on top of fridge keep beeping every two hours causing fridge not to work is there a reset button
freezer not working on ariston... Solve freezer not working on ariston fridge freezer 2 orange lights on top of fridge keep beeping every... (More) freezer not working on ariston fridge freezer 2 orange lights on top of fridge keep beeping every two hours causing fridge not to work is there a reset button
Sep 13, 2009 | Freezers
Fridge freezer
there is a fan inside freezer behind back panel. if pipework behind panel is covered with ice, it will prevent air circulation and the fridge is affected first
take back panel off and check for ice build-up and that the fan is working
Jun 23, 2008 | Electrolux ERN2820 Bottom Freezer...
Power light flashing on & off
Try to unplug and plug the power cord this may help, flashes is an error code. Try also the defrosting, error codes alarm the owner if there are some abnormal operation int the unit.
Jan 08, 2008 | Zanussi ZEBF250W Bottom Freezer...
Refrigerators Logo
309 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
