Home | Fujitsu Siemens | AMILO D-7830 (FSP:810U60145) PC Notebook | Fujitsu siemens ami...
Fujitsu Siemens AMILO D-7830  PC Notebook
Problem for Fujitsu Siemens AMILO D-7830 (FSP:810U60145) PC Notebook
Fujitsu siemens amilo d 7830
By chops on Jun 21, 2006
When turning on the laptop the green light appears computer comes on when will not do anything, thought it might be battery, will a run down battery stop the laptop from booting even when power supply is connected. also trying to charge the battery there is no red flashing light, only a orange flashing light for about one minute. then is nothing.
Same Problem
Dec 06, 2008
-   My laptops cord was cut and I replaced with a new cord, and now it won't do anything but show a flashing yellow light for battery which I know is shot, and when first pushing the power button will briefly flash the top two green lights on the side, 2 up abover and then a solid green power light for 5-6 sec then shut off leaving the flashing yellow light on the side.-   jack_reeve
Jun 08, 2008
-   press start button, three green lights then no start up, no screen just a slight sound from the rpm on the hard drive. BIOS screen does not appear laptop wont start up. Have tried all solutions mentioned so far without success. Have new battery,power supply okay, changed chip intel 3.06 no ideas, thanks-   aspire2b
Solution #1
posted on Aug 18, 2006
Somewhat Helpful)
Stark
Rank: Apprentice
Rating: 92%, 11 votes
Sounds like you have an exhausted battery. Even rechargeable batteries must eventually be replaced when exhausted.
Try removing the battery and booting the laptop while plugged in. If it works, the battery is exhausted and you'll have to get a new one.
If the laptop still doesn't boot with no battery, and you don't hear the whirr of the hard drive powering up and starting to spin, then you have a boot problem.
Was this helpful?
Yes
No
Solution #2
posted on Jun 27, 2006
Somewhat Helpful)
silly girl
Rank: Wiz
Rating: 81%, 3605 votes
Try to use a boot floppy, or at least try to boot with the
drive installed/attached to see if the laptop tries to access it.
You can also look for the reset switch, sometimes an innocuous hole
on the base or rear of the laptop - you stick a pen or paper clip in
it.
Remove any RAM upgrade chips. Frequent source on boot failure if they're the wrong size, speed, or chip config.
- this will take it back to the default device settings, in case you changed something that didn't take hold until you tried to
re-boot.
From the manual:
The notebook is prevented from booting by a disk in the floppy disk drive.
Check whether this floppy disk is a system disk. Remove the floppy disk.
Operating system files may be damaged or missing.
Boot the notebook with a system floppy disk, via the floppy disk drive.
i If the operating system is reinstalled, all data created up to that point will be lost. Make regular back-up copies of your data.
Some laptops have an initialize mode - you press down some keys while booting to reset the setting back to default. I'm not sure what those are in your laptop, but you can check in your manual, or in the store you bought it in.
Good luck
Was this helpful?
Yes
No
Solution #3
posted on Aug 02, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
no solution yet....but if I take the battery out and just use the power supply it will boot normal ....will not boot with battery in....if I put it in while computer is on....it freezes up
Popular Solutions for Fujitsu Siemens AMILO D-7830
Questions and Unsolved Problems for Fujitsu Siemens AMILO D-7830
Do you recommend Fujitsu Siemens AMILO D-7830 (FSP:810U60145) PC Notebook?
Answer
Answer
i need to down load a free version of my sound card as no sound card since my computer went into... (More)
Answer
Whilst typing on screen the cursor drops to the bottom of the page at random - has anybody any idea... (More)
Answer
On startup after the Fujitsu logo screen, I get the ami screen with the following message: CMOS... (More)
Answer
problem: solfware not found. on my fujetso laptop computer.how to solve this?
Answer
audio molto basso, le casse esterne o cuffie non funzionano inoltre quando si inseriscono non... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Fujitsu Siemens AMILO D-7830 ...:
Top PC Laptop Experts
Rank: Guru Guru
Solutions: 712
Experience: 30 Years of professional repair and design.
Ask Me
Find more PC Laptop Experts
Top Computer & Laptop Repair
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
