Question about Dell Latitude D505 Notebook
Laptop getting power but not booting up!!!
Hi my Dell D505 will not boot up, not even with a new battery. According to someone who claims to know laptops it is fine! But quite obviously it aint. When i turn it on the power light and battery light turn on and the symbol in the middle of the digital display next to the power button flashes the one that has like a padlock with an "A" in it could you help with this problem?
thanks
  • 68 Answers
Are you referring to the caps lock key,kindly check the memory of the laptop.
Posted on Oct 30, 2008
UN MOUNTABLE BOOT VOLUME ERROR - BLUE SCREEN on a dell latitude D505 laptop
try to boot to safe mode using F8 key on boot and then recover system or reinstall OS
Nov 13, 2012 | Dell Latitude D505 Notebook
I can not find administrator password for my dell latitude d505 laptop.
You can remove or change the Windows User oradministrator's password. You need access to a computer with Internet access todownload the Hiren's Boot CD and burn it onto a CD. Then insert this CD into the laptop/computer and boot upthe laptop/computer with the Hiren's CD and follow the instructions. There are very useful utilities CD and it a Linux boot CDwhich contains quite a lot of Utility programs including a password removalprogram. Click on one of these links todownload HIREN'S BOOTCD :- http://www.hirensbootcd.net/ http://67.20.82.163/
May 01, 2011 | Dell Latitude D505 Notebook
I got a dell latitde d505 wont power on or anthing no blinking lights no noises. i plug it into the charger n the charger light goes off. can some1 please help me??
Sounds like you may have fried your dell latitude. I have seen many laptop's fry and it is nothing you did, but they just go sometimes.
Recomendaitons:
Take the battery out of the laptop.
Plug the charger in.
Hold the power button for a minimum 10 secs (which will reset the power options)
If there are still no lights than it is your cpu
If the computer turns on then you have a bad battery.
When batteries are bad or dead, the computer tries to run off of the battery befor the charger, it switches over to the charger after your OS has booted. In that case you can just order a new one no big deal, but if your cpu is fried then there is no hope for the laptop. :( I have lost four laptops because of this, so for your sake I hope its the battery or the GND Drain.
Also possible that the GND's drain on your board is too short and Gate 4 is driving low. To fix this you have to remove a SMT ceramic cap, which is located opposite side to the power connector, almost under it. I would guess at 1206 or slightly larger and there is an 0402 cap just next to its bottom pad at 90 degrees to it. A couple of Dell Latitude d505 have had this problem and can easily be fixed, but must be cautious and know what you are doing. I would advise seeing a professional.
Please don't forget to rate :), Thanks!
Oct 07, 2010 | Dell Latitude D505 Notebook
I cannot get to Windows XP even tried F8 function and F2 as well as F12. All it does is load Dell and then the screen goes blank
Hello sewelika, hi, your laptop has main board problems, this are the things that should be checked, sorry there are no quick fix on this.
  • check battery/CMOS battery as well, this may cause the laptop have wrong idea of what hardware are connected.
  • check for memory which causes your laptop not to boot.
  • check for Hard drive this causes window not to load, and
  • Mainboard this causes all the above not to work properly.
Sep 11, 2010 | Dell Latitude D505 Notebook
Hey man im trying to reboot mny dell d505 and i inserted the disk and everything but it says exit the disk and restart again even when i take the disk out it says exit the disk and restart the laptop wtf??...
press all the buttons keep restarting keep pressing all buttons till somet happnes also u could try taking battery off if its a laptop also taking memory out for the night and maybe hirens boot cd .
OR BRING up boot menu boot cd 1st 2nd had and whatever else good luck he he
Jan 26, 2010 | Dell Latitude D505 Notebook
My D505 did not power up this morning
check the battery status, try removing the battery and just hooking up the power supply to see if it boots up
Nov 18, 2009 | Dell Latitude D505 Notebook
I Have Dell D505 LAPTOP and it just booted up
remove all drives, RAM, battery,cards and any external connections, and see if the Lock LED indication changes. If it does change, add 1 RAM module, and see if the system POSTs. If it posts, add items back till you ID the one preventing post and replace it. If no change, then replace the motherboard ($150 or so on EBay)
Sep 24, 2009 | Dell Latitude D505 Notebook
D505 will not power up
for this problem
go to http://support.dell.com>techincal support> enter your service tag> then check for battery issue it will tell you the meaning of each code being displayed on the laptop and you can resolve the problem,
one thing you can do is
take out the battery, take out the ac adapter from the laptop
now press hold the power button for 15 seconds
now put in the battery and ac adapter and see if the battery is charging and laptop is starting if not call dell support,
further queries are welcome
Jan 15, 2009 | Dell Latitude D505 Notebook
Laptop won't keep Power
It sounds like Dell support may have been right when they told you the motherboard had failed.
May 19, 2008 | Dell Latitude D505 Notebook
Hard drive password locked
Have you tried removing the battery, open the reserve battery door, disconnecting cmos (RTC) battery, pressing power button, installing RTC battery, install battery, power up?
Apr 10, 2008 | Dell Latitude D505 Notebook
Dell Latitude D505 Notebook Logo
196 people viewed this question
Alun Cox
