Question about Samsung SGH-T619 Cellular Phone
My t619 not connecting to yahooo
I'm tring to connect to yahooo but always give me network not avialbe
    President:
  • 846 Answers
Hello tamtam_dream
Do you have an internet access package in your plan with your service provider. You have to have internet access to be able to connect to yahoo messenger.
Posted on Apr 01, 2009
WIFI is not connecting
how are you tring to connect homw network or public wifi need to know more
Oct 03, 2014 | Apple iPod 16GB nano Silver 4G...
Wireless
I don't know what OS you are using ... below is the process to solve your problem in Win xp.
When you try to logon the wireless network, you may end up getting this error message: "Windows was unable to find a certificate to log you on to the network xxxx".
This particular error is normally related to the authentication on a wireless network, usually because the Windows is looking for 802.1x connection by mistake. We can fix it with the following steps.
Step 1
Click on the Start Menu --> Control panel.
Step 2
Double click on Network Connections in the pop-up window.
Step 3
Right click on wireless network connection, then click on Properties.
Step 4
Now click on the Wireless Networks tab and select the network in the list at the bottom. Click on Properties once you select the wireless network that is having problems.
Step 5
Click on the Authentication tab and now uncheck the Enable IEEE 802.1x authentication for this network box. If the box was checked, then that was why you were getting the "unable to find a certificate to log you on to the network" message because Windows is looking for one, but your wireless router is not setup for certificate security.
Step 6
Click on the Connection taband check the Connect when this network is in range box.
Step 7
Click on the Association tab and uncheck the 'The key is provided for me automatically' box, then choose Network Authentication & Data encryption and type in the Network key according to the wireless settings on your wireless router. Please contact the technician of your wireless router if you have no idea about the information.
Step 8
Click on OK and Click on OK again to save your settings.
As yet, this problem has been successfully fixed, Windows can log you on to the network automatically at once.
Mar 23, 2014 | HP Compaq nc6400 Notebook
I Have 1 desktop and two Laptopsthat I'm tring to connect.Have desktop and one laptop going can't get the other one connected
Dear! You should keep in a same workgroup name like MSHOME. Now you should take a network sharing wizard and after complete it you have to take a restart. Now, You should use same IP scheme or class like 192.168.0.1. 192.168.0.2, 192.168.0.3 etc.
Now check your connectivity on different PCs with this command on run;
"Ping -t 192.168.0.1" or change your IP address. If it will ping then it successful and will work 100% guaranteed.
Now your problem has removed and your problem has solved.
Good Luck
Aug 13, 2009 | Computers & Internet
I am unable to connect bluetooth devices to my samsung sgh-t619 cell phone.
are you trying to pair it with a phone? or bluetooth headset? if it is asking for a pass word...if you want to pair it with another phone, make sure that both of them has the same pass word, for a bluetooth headset the default pass word is 0000.
Jun 26, 2009 | Samsung SGH-T619 Cellular Phone
Tring to use a wireless n usb on a g router
Make sure to use the wireless utility of your wireless N adapter and not the Windows Wireless Zero Configuration utility. You can also change the wireless channel of your router to channel 11 and power cycle the router by turning it off for 30 seconds then turn it back on. Try to connect again. Make sure firewall on your computer is disabled.
Apr 15, 2009 | Belkin (F5D7230-4) Router (587009)
How to connect ActionTec T704WG (old router working with 2 other laptops) to new Toshiba Laptop
go to the wireless option in that given the view avialbe networks just find your networks and connect it disable the friewall and antivirus
Apr 02, 2009 | Actiontec Electronics (GT724WGR) Retail...
Connect itouch to internet
From what it sounds like, you are working in a Windows environment. What you are trying to do is bridge your wireless ad-hoc network with your wired network connection. Windows does not support this method of connection even though they have the option for "allow other network users to connect through this computer's internet connection". That would only work if you had two ethernet cards in your system, and that option bridges one ethernet port with the other. It doesn't support bridging to your wireless adapter.
Most laptop wireless cards do not support an "infrastructure" mode, which would turn your notebook into a mobile router. Instead they create an ad-hoc network completely separate from your wired network. There are some commercial pieces of software that can bridge the two, though I've never been able to make them work.
The easiest route would be to go to Target or a local electronic store and pick up a wireless router. You would take the ethernet connection from your laptop and attach it to the router. Then your laptop and iPod would both connect to the internet through the router.
Mar 29, 2009 | Apple iPod touch Second Gen (8 GB,...
Router asks for some kind of pin...
I have never heard of such. Sound like your computer is tring to get you to enter the WEP key or Passphase to access the router.
If you don't have a WEP key or Passphase setup on the router then you should just be able to click "ok" or "enter" (with the field blank) and bypass this screen.
Also check your network properties on the computer that is giving you trouble. Open your network connection, right click your wireless connection and click on "properties". Check the tabs and make sure you don't have WEP or secure network highlighted in one of the check boxes.
Jan 29, 2009 | Linksys Wireless-G WRT54G Router
Psp
First you need a wireless connection[home,coffee shop,hotel,etc]go to settings,scroll to network settings,click x,infastructure mode click x,new connection,scan follow prompts then go to internet browser select connection
Aug 09, 2008 | Sony PlayStation Portable (PSP) Console
Unlock Samsung sgh-t619
To get your IMEI no your mobile you need to use the following code *#06# This will display the IMEI number of your mobile
How to Unlock Samsung T619:
What you need to start is your Samsung T619 and a NON TMobile sim card. You can borrow a friend’s if you need one.
1 - Power the phone off
2. Remove the TMobile sim card
3. Insert the NON-TMobile sim card and replace the battery.
4- Turn on the phone, “wrong sim” should appear on the screen.
5-Dial *2767*3855# and wait. It could take the phone a few seconds to reboot. The phone will reboot,and the non T-Mobile SIM card in the phone will work,but this is only a TEMPORARY unlock step
6-Dial <span>*7465625*638*00000000*00000000# phone will say it is personalized.
7-Dial #7465625*638*00000000# The phone is now unlocked permanently.
8-Dial *#7465625# to check the lock status.
Apr 17, 2008 | Samsung SGH-T619 Cellular Phone
Samsung SGH-T619 Cellular Phone Logo
66 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
