On/off switch not functioning. Need to push and hold the switch to keep it on
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 164 Answers
Best bet buy a new switch but first, get your motherboards model and find the manual on it
so you can locate where to put the plugs of PWR SW and RST SW on ur mobo
new switch shouldn't cost much either usually less than 10$
Posted on Oct 21, 2008
Power window won't roll up on auto
If window will not roll up it can be caused by a problem with the mechanism, no power getting to motor, bad switch, bad motor, fuse issue.
Feb 28, 2016 | Cars & Trucks
Why does the power window button blink on and off and the automatic feature doesn't work in the 2008 Toyota Sienna?
NOTE:
Anytime the batteryterminal has been disconnected, please initialize the driver's door power windowand front passenger's door power windowafter reconnecting the batteryterminal.
With ignition switchin the "ON" position, do the following:
1. Push down and hold the driver's door power windowswitch to completely open the window.
2. Pull and hold up the driver's door power windowswitch until the window closes.
Continue holding the switch for approximately one second until the switch changes from blinking to a constant illumination.
3. Check for proper operation of the "one-touch open and close" function by fully pushing the switch briefly to the "DOWN" and "UP" positions.
At this time the power window switchfor the passenger's door windowshould be blinking.
4. Push down and hold the passenger's door power windowswitch to completely open the window.
5. Pull and hold up the passenger's door power windowswitch until the window closes.
6. Check for proper operation of the "one-touch open and close" function by fully pushing the switch briefly to the "DOWN" and "UP" positions.
Feb 09, 2016 | Toyota Cars & Trucks
2005 chevy impala problems
If you are referring to the failure of the auto function then try a system reset. (this fault often happens on some models after disconnecting the vehicle's battery and reconnecting.
Hold down the driver's window switch until the window reaches bottom position. Keep the switch held down for several seconds, then release. Lift up the switch until the window reaches the top position and hold for several seconds then release. Try operation of auto function again. Repeat steps in the opposite order if not successful.
Nov 04, 2012 | 2005 Chevrolet Impala
Hold switch is on?
You should just need to push the power switch down from the hold position. When it is pushed all the way up it is in hold mode. Sometimes that switch can break and affect the functionality of the Stiletto. If it is broken, you can contact a repair guy via email at sales@tss-radio.com or you can buy a replacement at http://www.tss-radio.com/products/sirius-stiletto-2-live-portable-receiver-sl2pk1
Jun 08, 2012 | Sirius Stiletto 2 Portable Satellite Radio...
I need to know how to replace my turn signal switch on my steering wheel my windshield washer turner broke off so either I need to know how to fix the windshield washer switch or just replace the whole...
The turn signal switch or in Ford terms "multi-function" switch is easy to replace if you are mechanically inclined. Lower the steering column "tilt" adjustment for easier access. Remove the lower panel (below the steering column). Remove the three screws from the plastic column covers that surround the multi-function switch. Turn the key to the run position, then from the bottom side of the column, use a very small pocket screwdriver, allen wrench or similiar tool to push up on the ignition cylinder release pin. The hole is located just below the cylinder. With the pin pushed, pull out on the key and cylinder. Next seperate the two cover halves and you will see the complete multi-function switch. remove the two attaching screws, remove the electrical connectors and replace the switch. Replace all removed components and you're done! You can purchase the switch at most auto parts stores, ford dealers or ebay. Feel free to ask if more information is needed and I appreciate a vote of four thumbs up. Good luck!
Apr 11, 2011 | 1996 Ford Crown Victoria
I keep pressing NEXT/ON/OFF and RESET to reset the
Review instructions:
Instructions say hold down Next ON/OFF > and push Reset > then release Reset > but keep holding down NEXT ON/OFF until screen flashes 12:00 >> after that, you release NEXT ON/OFF
If that doesn't work:
Timer functions are powered by battery, not by electric circuit, so your wiring is not cause of this problem.
Try removing battery for longer than 5 minutes.
This will reset time/date but not your programs >> the programs stay in the timer forever until reset.
Then try the reset procedure again as shown above.
If timer still doesn't reset:
EJ500 has a 1 year limited warranty.
You may need a new one.
Apr 09, 2010 | Intermatic Inc. EJ500C Digital Wall Switch...
My dvd player wont let me push anything it just says hold on..i can use the remote though..
To enable the hold function, on the front of the DVD player, slide the POWER/HOLD switch to the right.
****To disable the hold function, slide the POWER/HOLD switch to the left.
NOTE: When the hold function is enabled, the buttons on the DVD player are locked so they will not work if accidentally touched.***
Aug 25, 2009 | Sony DVP-FX730 Portable DVD Player
Accident turned on self clean with door open
I tried pushing in the light switch again, and i pushed it in until it stopped, evedently it is a 2 postion switch, when the door locks it pulls the door up tight, and the switch must sense this, so after I pushed the toggle in flush the lock finished locking and while I was still holding in the light switch I pushed the stop/cancle button and the lock opened up,and vola we could use the oven again, we had pizza.
Apr 11, 2009 | Kenmore Kitchen Ranges
Maitneance required light
Hi.. after you do this step come back and rate as fixya. OK..
Turn the ignitio key to run position
Push and hold for 5 seconds the Trip reset botom.
With the botom pushed turn the ignition key to OFF position.
Keeping pushed the botom.
Turn the Ignition switch to RUN position. keep pushed the trip botom for 10 seconds or untill you see the MAINT_Requi. go OFF.
Remember all this steps with the trip botom pushed. OK.
I hope this solve your question. Thank you for use fixya.
Aug 01, 2008 | 1998 Honda Accord
Need to replace battery
need more info dont you no were it is how to do it? hope u have your radio code handy to it will need a code once the battery has been replaced
Jul 20, 2008 | 1999 Mercedes-Benz E55
Computers & Internet Logo
55 people viewed this question
David Payne
David Payne
