D52w20 hdtv...power button blinks 3 times but wont come on
Can you help me avoid this problem?
  • jason May 11, 2010
    have you made sure all the soldering is good?
    have you resoldered any and all solder joints that don't look shiny or that just don't look good?
  • 905 Answers
You would need to be able to replace the power components
Posted on Oct 21, 2008
Rca d52w20 blinks 3 times, wont turn on
The set has a three strikes and you are out rule---tries to come on three times and then if fails, shuts down.
A short exists inside the set.
Mar 17, 2012 | RCA D52W20 52" Rear Projection HDTV-Ready...
My RCA D52W20 --> turns on sometimes, when it does, it blinks once, slow, and then after the 1 slow blink, blinks 9 times fast. now, i dont know whats wrong but sometimes the tv wont even blink to show...
Sounds like the Flyback needs resoldering then replace the Three caps CP150, CP120, and CP114. You can get the repair kit by that same name from www.tvrepairworld.com the kit also contains the CD with instructions.
Mar 28, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
My tv will not turn on
CK for Bad capacitors on your Deflection Board its the bottom board on left hand side cp150 cp114 cp120/ if (cp150)- 2200uf 16v is puffed up on top It is Bad replace all 3 capacitors 220uf 35v is the other 2.
Jan 02, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
My 52 inch rca tv power button blinks on and off
my rca tv will not power on power button blinks four times
Aug 17, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52 in. Rear Projection HDTV power light blinking
Liz, yes it is a power supply problem, better question is; low voltage or high voltage power supply ? count the blink code, it should repeat the code, once you have the code call your local tv shops and give them the model number of your tv and the blink amount and they`ll tell you price to fix, gl, video-tek
Jun 05, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
The power light blinks 3 times and never comes on
you need to replace the flyback 259296 and CP150 you van get both parts with free instalation instructions at the following link.
http://servicemanuals.vstore.ca/
Nov 22, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Tv wont turn on blinks 9 times then 1 time
I was inform that it could be a sensor (bad diode), you have to get a multimeter tester and test the diodes and if current flows from both sides then replace that diode.
Nov 14, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have RCA HDTV Projection television.Problem wont turn on when press on power button..the power button will light amd turn off 3 times..bit picture or sound..please help
If you have the D52W20 series or any other of the ITC222 chassis TVs 3 blinks means you need to replace the flyback. Very easy and inexspensive repair. You need flyback 259296 you can get a new replacement at the following link with free online tech support that will walk you through the repair step by step. Heres the link.
Aug 14, 2008 | Televison & Video
No power
Check the ribbon cable connections between the boards to insure they are correctly seated as a 19 code usually means
Chassis detection, which means its not detecting a valid chassis usally the ribbon connections are the cause of that.
Jul 31, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Televison & Video Logo
52 people viewed this question
Top Televison & Video Experts
