Question about Dell 5100cn Laser Printer
Color Faded I have a Dell 5100cn printer and have been using Dell compatable color and black cartridges with great results. The supplier changed the cartridges recently and when I added Cyan and Magenta a couple of days ago all of the colors are super faded and streaky. Black prints fine but colors do not.
  • PCrich Dec 06, 2008
    same
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 188 Answers
This sounds like a typical Developer Drive failure. The Developer Drive for color is different that the black developer drive. This is why black can print fine, but colors are faint or non existant. see below,a recent bullitin about this exact issue from Dell. ( the ROS, is the printhead, and is located behind the 4 developers.
5100cn Printer
Print Quality Issue
1. Problem: - Color images are extremely faint or not produced, but black images are produced without any problem.
Resolution: - Replace Developer drive assembly (H6702) and clean ROS Window/Glass.
If you chose to persue this repair, you can probably find a replacement developer drive by doing either a google search for the part number listed ( H6702 ) or an ebay search for the same. We can also provide you with removal and replacement instructions.
Good Luck
Posted on Oct 30, 2008
The Black Developer is probably the issue (Part #: M6091)
Posted on Apr 17, 2012
Why is my printer printing very faded grey text instead of black?
getting low on black toner? When you changed the black toner, did you remember to remove the plastic strip? Silly question, I know, but it happens.
Jul 17, 2014 | Dell 5100cn Laser Printer
Dark print colors no longer dark.
Check your default print settings have not been set to draft mode or half tone.
Apr 08, 2014 | Dell 968w Printer
No color printing
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
May 05, 2013 | Dell 5100cn Laser Printer
Dell color laserjet 5110 cn will not print color documents. This network printer was printing color fine until yesterday mid-day when it started printing in black & white only. I tested by printing a...
This has to do with the document printing properties. When you are ready to print a document, choose properties and make sure you go through the printer settings under that software.
The test page only verifies the cartridges. The printer properties of the software control the printer during printing.
Mar 17, 2010 | Dell 5100cn Laser Printer
2600n faded print on both left and right side.(word doc, no images) not using color black print only.
Is the cartridge an original HP or an inexpensive compatible? The black cartridge could be out of toner. Not a common defect for the Q6000A cartridge though. If it is a poor quality compatible the defect may be the result of a misaligned internal component. Either way replacing the black cartridge should resolve the issue.
Jan 18, 2010 | HP Color LaserJet 2600n Printer
Compatible cartridge for HP 1513 used in INDIA having 136 & 132
HP printers supplier, can arrange or supply in Hyderabad India,
the hp printer PSC-1513 catridge (color)136 and catridge 132(Black)
or advice us, where could we get said catridges. Thanks
Sep 03, 2009 | HP PSC 1510 All-In-One InkJet Printer
How can I ignore the low toner error message and print black on a Dell 5100cn?
i believe that if you remove the color toner cartridges, it will stop asking and only print black. you may also be able to specify in the print menu settings to disable the color printing
Jun 10, 2009 | Dell 5100cn Laser Printer
Dell 3110cn color laser prints with black "haze" on all pages
You probably used a "GENERIC" toner cartridge on one of your toners.
This caused the developers to get contaminated, now they need to be replaced (probably Black & Blue)
Jan 12, 2009 | Dell 5100cn Laser Printer
Dell 5100cn leaving line only on full color pages
There is more then likely damage to one of the photo developers. This is what transfers the toner to the imaging unit. The Developer frame assembly has to be totally removed in order to change one or all of the developers.
The only other posibility is that the printhead needs to be cleaned, however, in order to clean the printhead you would still need to remove the developer frame assembly to access the front of the printhead.
Sep 26, 2008 | Dell 5100cn Laser Printer
Dell 5100cn Laser Printer Logo
709 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
