Question about Sanyo Televison & Video
I need remote code for rmt u100. - Sanyo Televison & Video
5 Suggested Answers
  • 14 Answers
SOURCE: I need remote codes for sanyo rmt-u200 and rmt-u110 and instr
Here is a link to the remote manual list. I found no link to through sanyo to get to this but after searching for nearly two hours on google I found it.
http://www.sanyotv.com/ownermanuals.html#RMT
Mike
Posted on May 28, 2009
gopakumarg43
  • 71055 Answers
SOURCE: sylvania tv code for remote RMT-B119A
Universal remote setup codes for Sylvania TV are: 0062 0004 0009 0135 0189 0183 0227 0456 0008 0068 0075 0141 0161
Posted on Jul 25, 2012
  • 27888 Answers
SOURCE: What is the code for apex dvd player 1110w on a sanyo rmt-u100 universal remote
Your Sanyo universal remote probably has a code search feature you can use to find a code for your Apex DVD player. If a search through all codes stored in the remote fails, you may have to try using another universal remote.
Posted on Feb 14, 2015
gopakumarg43
  • 71055 Answers
SOURCE: Need the manufacturers code for a Sony DVD remote model # RMT-111A, To program the remote to my Emerson T.V...??
Sony remote control have no set-up code to Emerson.
If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability.
Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the site http://electrohelponline.blogspot.com/ Check this site too. http://remotesearch.blogspot.com/ Universal remote controls are available at most of the electronic spare part selling shops.
Type in the "brand name" of your device, in the search box [at the top right] of the display window to get gathered all the related posts to this brand devices. It will make surf easy.
Posted on Jul 08, 2015
AJIN G
  • 6694 Answers
SOURCE: I have a GE universal remote need code to replace Westinghouse RMT-15 Remote
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://electro-medical.blogspot.com/
Posted on Jul 30, 2016
Don't have a code for my sond remote control to
if it is an old remote it may not be compatible with your television though this is hardly your television manufacturer's fault since its not claiming to be universal : 3
Without knowing the model of your television i can certainly not help further as your remote control website found at:
http://esupport.sony.com/US/perl/model-remote.pl?mdl=RMTV501C
does not list samsung as an option. THERE IS however, an option to request a code from sony at the top right of the page so I suggest you try this option for speediest response. Please mark this solution as helpful <3
Oct 29, 2009 | Samsung Televison & Video
I need a remote code for a rca remote for the olevia remote control can you help
Unfortunately Olevia is one of those t.v. brands that is not compatible with many universal remote controls. They make a Universal Learning Remote specifically available from Olevia on their web site that may solve your problem if your universal remote control turns out not to be compatible with your Olevia television.
As for what codes you can try, there are many, and the codes depend on your universal remote control brand. Many times, an RCA code will work for Olevia televisions, so you should try the RCA codes that come with your universal remote first, before trying any of these other codes.
If you have a Dish Network Universal Remote you can use code 506 or 127.
Direct TV remote codes vary by model number on the remote control, but the following codes work with most Direct TV remotes: 506, 127, 11144, 11240, 11331, 11610
Cable Vision use code 506
Charter and Movie Box remotes you can use 1144 or 1178
Comcast codes are 11144, 11240, 11331, 21075, 10159, 10154, and 10088
Cox code is 1610
Brighthouse remote codes are 1610, 1144, 1240, and 1331
Time Warner remote codes are 1610, 1144, 1240, 1331, 432, and 1610
If none of these brands are what you are looking for as far as your Universal Remote Control is concerned, many universal remote controls will work with Olevia televisions if you use the codes found under the RCA, LG, Phillips, and Yamaha in the code listing included with your remote control.
Jul 25, 2009 | Televison & Video
NEED CODE FOR REMOTE CONTROL TO WORK WITH TV
If this is an original remote u should not need a code. You need to find out if the remote is transmitting a signal. If it is a universal remote use your manual to find correct code, use code search or go on internet & look up code.
Apr 21, 2009 | Televison & Video
Codes
Here are some sites that will have your codes and instructions on how to enter them:
  1. Universal TV Remote Control codes Universal remote control codes for all TV and VCR brands including: at&t, beery systems, bondwell, curtis mathis, dish network, ge, gemini, ...
    www.tvcodes.com/ - 23k - Cached - Similar pages -
  2. Universal Remote Control Codes Universal Remote Control Codes for DVD, VCR, TV and Home Theaters System.
    www.remote-codes.com/ - 7k - Cached - Similar pages -
  3. Philips Magnavox Universal Remote Code Philips Magnavox Universal Remote Code - Instructions on how to program your Philips Magnavox universal remote control.
    www.universal-remote.net/philipsmagnavox.html - 35k - Cached - Similar pages -
Apr 17, 2009 | Televison & Video
Codes for remote
Try thease codes to see if they work for the remote. If not we need the model # for the remote.
http://www.universal-remote.net/philipsmagnavox.html
Good Luck And Please Rate FixYa!
Dec 28, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Living solutions remote control codes
I have a Universal Remote Control Model ATC-1311 Giant remote. I have lost the codes to and instuction book to. Can you tell me where to get at least the code for my T>V> Thank you
Mar 29, 2008 | Televison & Video
Remote code for Coby TV/DVD
If you are a DirecTV or Cox subscriber, you may sync a universal remote to your television using code 1548 or 11548.
These codes are for use with the following Coby television models:
TFTV1022, TFTV1212, TFTV1513, TFTV1514, TFTV1524, TFTV1913, TFTV1923, TFTV2214, TFTV2224, TFTV2617, TFTV3217, TFTV3717, TFTV4717
If the codes do not work, or if you are not a DirecTV or Cox customer, the universal remote control manufacturer is responsible for creating and embedding a Coby-compatible code in the remote control. Please contact your cable carrier or the universal remote control manufacturer for assistance.
Mar 25, 2008 | Televison & Video
Philips universal remote codes
For the majority of phillips/magnavox universal remotes: Hold code search button down till red light satys on. Press the tv button and the red light should blink and stay lit. With the tv on, push the power button repeatedly until the tv turns off.(dont push the power button again after the tv turns off or it will go to the next code). Push the mute button to save the setting.
Feb 07, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Televison & Video Logo
26 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
