Question about Sharp CD-DD4500 System
The rotary cooling fans run constantly, even with power OFF.
The 2 rotary cooling fans in the stereo run constantly, even with the power turned OFF. Is there a sensor that is bad and thinks that the unit is too hot? Is there a do-it-yourself fix for this problem? I am planning to replace the fans because they are very noisy (I suspect they are on the verge of wearing out).
Thank you in advance.
  • 1 more comment
  • erict197088 Nov 05, 2008
    Sharp stereo model # CD-DD4500. Great stereo...
    Fans are worn out due to constant running. They are probably designed this way to keep the unit cool as there is power to the system at all times while plugged in. Fine with me, but I need to find replacement fans for this stereo. Anyone have a link for this type of replacement parts? The fan motors have RF-310T-11400 on them. Thanks for the help! ET
  • tinkerer314 Nov 25, 2008
    I found the replacement fan motors on-line but do not have the info with me at this time. I will post it as soon as I can. The fan motors were about $34.00 apiece. You will need to remove the current wires and solder the connections to the new motors.
    The site for the parts is Partstore.com (1-866-925-7278). Part #: aa-rmotv0027awzz. It is listed on page 9 of the parts list for the Sharp cd dd4500. The motor is listed at $17.02. I replaced the fan motors and the silence is golden!
When I turn the engine off the engine cooling fan stays on and does not shut off
depending on the engine temperature the fan is supposed to remain on after you turn the engine off, until the engine reaches a preset cooler temperature. when it reaches cooler temperature usually within 5 minutes or so it should cut off... if you cut it off and it is running 30 minutes later.. then there is a problem with the fan relay or temperature sending unit.
Sep 28, 2015 | 2009 Dodge Grand Caravan
Hi , ive got GA22 but it running very high,sometimes trips out. We have replaced everything to date - service,soleniod,flushed cooler,cleaned cooler,new pipes,new seperator,thermostat on constant...
Check the direction of the cooling fan, if it is a centrifugal fan it will blow no matter what way it turns, but it will not blow as much if it goes the wrong direction. Check for the arrow and make sure it is going the way it says it should.
Mar 23, 2015 | Atlas Copco GA Rotary Air Compressor - 20...
The cooling fan runs constantly even when the dvd recorder is turned off. Is this correct ??
If it runs for more than a couple minutes when the unit is completely powered off, it's not normal and should be checked.
Jul 07, 2011 | Televison & Video
The freezer constantly drips water even with the ice maker turn off, the fan constantly runs but when the door is open the fan shuts off
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 07, 2010 | Microwave Ovens
Crafatsman Rotary Tool Single speed - chuck has no power - that is motor will run smoothly - - chuck will turn - but your finger can stop it - it is free wheeling on it's own even while the motor is...
These are fairly easy to disassemble and get back together, take it apart and find out what got stripped, It might be an easy fix, then again, it might be going back to sears. They will take it back no matter what. Hope this helps.
May 29, 2010 | Craftsman Single Speed Rotary Tool
Exhaust fan is running constantly, without even
It could be that the fan button is sticking or a contact has welded itself closed therefore its getting power all the time.
Mar 08, 2010 | Maytag Appliances Over-the-Range Microwave...
Mercedes benz airconditioning
You might check the cooling fans on the condenser to see if they are running when the ac is on.If they are not check for blown fuse,or bad cooling fan relay.Do you notice if the ac cools better when running constantly,and the ac is not so cool when in traffic,stopping and going,and running slow?If so the cooling fan,or fans are not working.If the fan fuse and the relays check out fine,then replace the fan,or fans.If I can help any more please ask.roniecon@gmail.com
Aug 19, 2009 | 2004 Mercedes-Benz C-Class
Stereo wiring 98 saturn
That stereo is now most likely dead. speaker wires are mostly green/black stripe, white/b s, grey/b s and violet/b s. ground is black and power are red and yellow.
May 31, 2009 | 1992 Saturn SL2
Refrigerator Compartment Fan
Sounds like they ran it in with your themostate and it is not working.. i would try replaceing themostate
Oct 13, 2007 | Refrigerators
Sharp CD-DD4500 System Logo
79 people viewed this question
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
