Question about RCA F25655BC 25" TV
Stationary horizontal lines
My television has started showing stationary horizontal lines, spaced about 1/2 inch apart. Also, the picture is excessively bright. When bright is turned to the lowest setting, picture is still overly bright.
    President:
  • 3,130 Answers
Thjeres a problem with the screen voltage driver voltage capacitor or the crt is going bad. have the shop test the b+ on the crt board first off . then remove the crt board and see if the voltage comes up. If it does the capaicitor is bad as it can take the load. But remeber theres extremly hi Voltage inside these sets so its never a good idea to try to do this your self unless you have the training to deal with HI Voltage and the proper saftey and test equipment. Good Luck
Posted on Jun 22, 2006
My 42 in phillips LCD flat seen has a black horizontal line toward the bottom how can I fix this.
Samsung LN46B650 Thin Black Horizontal Lines - Forums - CNET
www.cnet.com > Forums > Samsung
CNETI'm experiencing thin black lines from the top of the screen to the bottom. ... by babes808gpa / January 15, 2010 1:42 AM PST ... lines are about 1/4 inch apart from top to bottom of screen. starts on the right and about a 1/3 of the way toward the ...have the exact same problem, my lcd tv has multiple lines are horizontal it ...
Faulty HD- LCD - LED TV - Horizontal Lines STRIPS on the ...
? 3:05
https://www.youtube.com/watch?v=KiqJuMiEiak
Jun 8, 2013 - Uploaded by Sameh Moustafa
Faulty HD- LCD - LED TV - Horizontal Lines STRIPS on the picture SOLVED .... I just have one black line ...
TV Repair Help for Vertical & Horizontal Lines on Your TV ...
? 2:47
https://www.youtube.com/watch?v=b0sI7LB4cZE
Dec 20, 2015 | Televison & Video
Only half rca tv screen shows up
I think you may have a tv tube problem...
Jan 26, 2014 | Televison & Video
Solid thin horizontal line
Check for excess screen voltage. Adjust the screen control to eliminate these vertical retrace lines. [Thin white line acorss the frull screen at about 1 inch apart.]
Mar 10, 2012 | Televison & Video
Horizontal white lines across top of TV screen
Vertical hold circuit is failing.
Check capicitor in vertical hold circuit. You should have solid knowledge of electronics repair before attemping repair. TV's can emmit harmful radiation, and produce voltages up to or in excess of 30kV.
Oct 07, 2008 | Televison & Video
After a household power blips during bad weather, we have horizontal lines ....
Unfortunately there isn't any way to repair your tv as the magnet has distorted the tube that is in the tv and with CRT becoming obsolete the repair is likely to be very costly so probably your chaepest option is to buy a new tv .
Mar 13, 2008 | Televison & Video
Television
From what I can understand, your problem is:
1. either a single horizontal line (from left to right), very bright, no picture but with sound, if yes then it is a failure of the vertical section. More often, it is the vertical IC that is at fault, sometimes the vertical capacitor. Still, in other cases, it is a case of cold solder; or
2. multiple lines across the screen with the picture overly bright and with sound. If yes to this one, then it is a matter of excessive screen voltage. This is adjustable using the HV Screen control that is at the rear of the Flyback Transformer.
Hope this be of some help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Feb 10, 2008 | Televison & Video
No Picture Has a bright horizontal line with off white & gray vertical bars
The Problem Philips 27TS54 c101 27B800-7562 White horizontal line in the center of the screen. Color is present in the first half inch of the leftist corner of the horizontal line.
Audio is present and controllable. The green power led from a cold non plugged in state remains solid until CRT goes to ignite. A click is heard then the green power LED blinks.
I found service manual diagram of repair part or parts and install instructions
HTTP://WWW.servicemanuals.net/results.aspx?type=SM&brand=100&model=27ts54
I request any info or tips you might have pertaining to this problem
Thank-you
Sincerely
Gmyers@sbcglobal.net
2/20/2008
P.S. 25”-27” CRT board APT187
Possible Answer Posted by PEE_WEE 4/28/2005
On the CRT circuit board(picture tube), you will find R3340, which is a 10 ohm 1/3w resistor. The location of the resistor is printed on the bottom of the ckt board. It is burned open, replace with a 10 ohm 1/2w resistor. This will solve your problem. The original resistor was sized too small, should have been a 1/2 watt. This resistor is mounted standing up on ends. Mount the replacement resistor the same way. Be careful and don't get the circuit trace too hot and damage the circuit trace. (it's very small) The resistor is located on the crt(cathode ray tube), pcb(printed circuit board) socket. The resistor supplies apx +200v to the collectors of the r, g, b, video driver transistors. If this voltage is low, it causes excess brightness(excess beam current), causing the set to "shut-down". If the shut-down is too quick, you will NOT see the excess brightness, because the picture tube has not warmed-up enough to display anything on the picture tube. To see if the set displays "excess brightness", you will need to turn the set "on" about 5 to 10 times. This will heat the picture tube enough to display "excess brightness", IF that is the PROBLEM. Of course, there are OTHER defects that will cause a tv to shut down. There are built in safety circuits, that will "activate" if excess voltage/current or heat is detected anywhere in the set.
NOTE
My resistors are not numbered the same on my crt board APT187. GSM 02/20/2008
Dec 31, 2007 | Samsung TXK2754 27" TV
Tv showing blue screen with flyback lines sound ok
Flyback lines? Is the picture all white with no brightness control with faint horizontal faint lines? If this is what you are saying, the screen voltage could be bad, and if thats the case, the picture tube or the flyback itself could be bad. You could also have a bad connection on the crt socket
Dec 27, 2006 | Philips Magnavox 20MT133S 20" TV
Open Questions:
I own a Samsung LN40C630K1FXZA TV with no picture but has audio and backlights. I need help determining what boards to replace. I tried to watch some tutorials posted on YouTube and have the following information. The TV was starting to have an issue that while watching it the picture was seeming to get a little jerky like it wasn't refreshing fast enough. It wasn't always noticeable and I initially though it may have been a signal issue with our cable. Eventually we turned on the TV one morning, the picture came on and then disappeared after 2 or 3 seconds but we still had audio. I tried to pull up the menu screen and that was not visible. I performed the flashlight test and there are images visible with the light. I removed the back cover and took pictures of the attached boards and also saw that the backlights seemed to be working but did seem like they were not quite a constant consistantly light. They never completely extinguish but do seem to fluctuate in brightness slightly. I did not see any visible issues with any if the capacitors being swollen or blown and did not see any apparent burnt components or boards. Below are the readings I got from one board but I was not sure where to get the readings on the TCON board. Main PBA readings CN201 1. 18v. Actual 13.1v 2. Sw. Power Actual 13.1v 3. 18v. Actual 13.1v 4. 5v. Actual. Falling to -1.6mv 5. 5v actual. Falling to -1.7mv 6. 5v actual 5.15v 7. 5v. Actual 5.15v 8. ground actual 13.1v 9. Ground actual 13.1v Any help would be greatly appreciated so I can buy the right parts from you. Thanks, Chris
Jan 19, 2019 | Samsung Televison & Video
See all RCA F25655BC 25" TV Questions
Televison & Video Logo
74 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
