Question about GE Dryers
Install dryer belt - GE Dryers
  • 550 Answers
More information needed to specifcally match the model
however dryers are all similar so
generically, UNPLUG dryer
A:top mounted lint filter (kenmore maytag(New))
  • remove lint filter
  • remove screws in lint filter housing
  • with putty knife or other flat blade depress lock tabs at front corners of top body panel
  • tilt top panel up
  • remove screws 1/3 way down each side, remove door switch wires
  • remove front panel set aside
B:dryers with screws at bottom of front panel (maytag speedqueen)
  • remove screws from bottom of front panel
  • tilt front panel up
  • remove door switch wires
All
  • pull drum forward & out
  • examine drum felts, rollers, and slides for wear replace if worn
  • wrap new belt round drum at old wear marks
  • insert drum
  • wrap belt round motor pully
  • pull tensioner pulley hard to end of travel against spring
  • wrap belt round tensioner pulley
  • release tensioner
reassemble
Posted on Oct 19, 2008
  • AlmostBob
    AlmostBob Oct 28, 2008
    If you give a question without details you can only get an answer without details
    we have pictures, video, instructions, makers part numbers,
    but
    "more information needed to specifcally match the model"
Tip
Hotpoint Dryer Belt Diagrams and Replacement
Your dryer belt has broken and you have a new belt to install, but you do not know how to route the belt properly. Here are some pictures or diagrams to help you see how the belt needs to go. Of course the belt needs to go around the drum so that is not included.
The important part is the routing around the motor and the tensioner pulley.
For Hotpoint Dryers
1970- 1990 standard capacity
Style: Flat with ribs
Installation Tips: Ribs against drum
1970- 1990 Large capacity
1990 – to present
1b9906a.gifStyle: Flat with ribs
on Mar 06, 2010 | Dryers
Tip
Kenmore Dryer Belt Diagrams and Replacement
For Kenmore models starting with 110 or C110 with a removable back use this:
For dryers starting with 110 or C110 with nonremovable back use:
For Dryer models starting with 417 use:
Installation Tips: Ribs face toward drum
Cant figure out how dryer belt goes around pully and moter
Go to repairclinic.com and click on the "Get Repair Help" link. Select the "Dryer" category, followed by "Click here for a dryer belt installation diagram". There are numerous illustrations that you can use to assist you with the proper routing of your dryer belt. If the model number is correct, refer to diagram H. I hope this helps you.
Feb 16, 2011 | Roper REK2950W Electric Dryer
Please, can you tell me how to tighten the belt on an Inglis dryer model J073500
Sorry for the troubles but you cant tighten the belts on those or any dryer for that matter. Here is the problem your belt is worn out and that's why it is loose and if you have replaced it and its loose you are installing the belt incorrectly around the idler pulley or have the wrong belt or your idler pulley is worn out. I hope this helps solve the issue your having and for instructions on installing the belt go to youtube and type in whirlpool dryer drum belt installation they will show you the correct way to do it and whirlpool builds your model dryer.
Jan 22, 2011 | Dryers
Tip
Fridgidaire and GE Dryer Belt Replacement
Here are the belt diagrams for replacing your dryer belt for Fridigaire and Ge Dryers
For Fridigaire dryers 1970-1985
9b6122a.gif Style: Flat with ribs
For 1985-1995
For 1995- present
Style: Flat belt
Installation Tips: Side of belt with words faces away from drum
For Ge Dryers
1990 – to present
on Mar 02, 2010 | Dryers
How do I replace the belt on my Asko T761 dryer? Do I go in thru the front, the back? Are there instructions on-line for belt replacement?
How to install a belt on ASKO dryer
Belt Type: Flat belt with ribs
Installation Notes: Ribs go against drum
You could Refer to :-
http://fixitnow.com/wp/2006/05/08/asko-t700-dryer-wheel-drum-and-belt-replacement-instructions/
It would be a Generic one but would help you.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Mar 11, 2010 | Asko T761 Electric Dryer
Fit new drive belt to tumble dryer
I need to know more. like how to instal belt or how to find what belt fits your dryer . need more info like mod # there 5 different belts for hotpoint . and several different ways to install them so model # ______________ needed . **** . pls .
Jan 02, 2010 | Dryers
How to instal new belt.
Remove the back panel, there you will find a tensioner, that will release the pulley.
Undo the belt routing and install the new one.
See here:
Maytag Dryer Belt Routing
belt routing for maytag performa ... -
Maytag gas dryer belt routing - FixYa
Sep 18, 2008 | Maytag Dryers
I need instructions to install belt on my clothes dryer Model no.lde9304ace
HI,
Please CLIcK HERE all the steps are given including pics to install a belt on your dryer.
Jul 23, 2008 | Maytag Dryers
Dryers Logo
513 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
