Question about Sony Playstation 3 (PS3) Console
Left analog stick doesn't work within the game
My left analog stick doesn't work within any games but does work in the game menus. For instance, I can use it to select a car in burnout paradise by moving it left and right but in the game i can't steer. Any ideas?
  • 7 Answers
SOURCE: analog stick
I had this problem to..........I took off the metal clasp on the joystick and continuly and forcefully rotated the joystick untill it moved in a smooth fashion then I replaced and it works fine.
Posted on Feb 13, 2008
SOURCE: the right analog stick does'nt work with fallout 3
if it works while youre on ur pip boy map then all you have t do is find a safe or door to pick the lock on. idk why and i know it sounds wierd but it worked for me i just picked the lock successfuly and it worked again.
Posted on Apr 23, 2009
hotratchet
  • 952 Answers
SOURCE: my analog stick is not working on the psp menu
you really cannot use your analog stick if you're at the menu. its really like that. i've had my PSP for years and i believe that there's no mod or configuration to do that. Sorry mate.
Posted on May 01, 2009
fossildude
  • 832 Answers
SOURCE: my psp's analog stick is not working properly one
hi thanks for using fixya!
On this kind of error, I recommend that you bring your psp to a service center to further check that contol analog stick.
Regards!
Posted on May 12, 2009
  • 7 Answers
SOURCE: My analog stick is stuck in the upwards direction.
actually i had the same problem i also had a psp because my friend fried his i took his nub and put it into mine same both gen 100 psp but it was still stuck in the upward position making it an internal error in the psp itself not always the nub
Posted on Jun 25, 2009
Analog problem
Do you mean it the analog stick turns left or it turns left in-game?
Jan 30, 2014 | Sony Dual Shock 3 Controller for...
Left analog stick My Xbox left analog stick does
Analog stick might be bad and may need replaced. If you don't feel comfortable tearing it apart, you may want to look into a new / used one.
Oct 12, 2013 | Microsoft Xbox 360 Controller
Left analog stick wont work during black opps 2 play however on the menu screen it works
Hi
it looks like it may be an issue with the game.
Maybe the left analog is disabled. check control settings.
Jul 21, 2013 | Logitech Cordless Precision Controller for...
Problem with logitech dual pad right analog
Try to disassemble the pad. Reseat the analog stick and re-assemble the pad.
May 12, 2012 | Logitech Dual Action for Pc (963292-0403:)...
On cod my logitech controller's control pad moves my player but i cant move with the left joystick (they have been switched somehow)
You have to go through the game settings and ensure that you have set the primary control to be done by the left analog stick. In other words, make sure that you have the left-analog stick as the tool to move your player around while playing the game.
Also, if that doesn't work, there is a possibility that your left-analog stick is somehow jammed and as a result doewsn't perform the right function.
This could be a factory fault or one that arose as a case of mis-management. Whatever your result is, kindly let me know.
Hope this solution was helpful? Please comment for more information and thank you for using www.fixya.com
Jan 02, 2011 | Logitech Cordless Precision Controller for...
Looking for a ubisoft game manual and not sure if this is a location that will help..not much of a gamer, but need manual for ps2 Heroes of the Pacific game. I looked on the "ubisoft" site but didn't see...
FLIGHT CONTROLS blacklinespacer.gif Steering or Roll: Left analog stick Left/Right Change Pitch of Plane: Left analog stick Up/Down Roll Left/Right/Move Vertical Rudder Left/Right: Right analog stick Left/Right Throttle: Right analog stick Up/Down Engage Warspeed: R3 (click right stick)
blacklinespacer.gif COMBAT CONTROLS blacklinespacer.gif Give Wingmen Order: Attack: Directional Up Give Wingmen Order: Defend: Directional Down Give Wingmen Order: Break: Directional Left Give Wingmen Order:Form Upk: Directional Right Next Target: x.gif Closest Air Target: Hold x.gif Rear View: triangle.gif Cycle Secondary Weapons: square_white.gif Next Objective: circle.gif Closest Objective: Hold circle.gif Target Camera: l2.gif Fire Secondary Weapon: l1.gif Zoom In Gunsights: r2.gif Pause Menu: Start Change View: Select
From http://www.gamesegment.com/PS2/instructions.cfm/id/6386730
Nov 17, 2009 | Video Game Consoles & Games
How do I kick off in ncaa football 07 for xbox
You use the left analog stick to position the kick. When you are ready, pull back on the right analog stick and when the gauge fills up, press forward on the right analog stick. The key to a good kick is to position the right analog stick in the same direction of the kick. (As if you were kicking in the direction your turned with the left analog stick.)
Good luck and happy gaming!
Mar 22, 2009 | EA Sports NCAA Football 07 for Xbox
Right analog stick not working
Check the controls on the game's control section. If you play another game that uses the right analog control and it works on that game then it's the control set up for FIFA. Make sure that the analog control light is on when the game boots up. Sometimes if the analog control light is not on when you turn the game on and you turn it on afterwards, the analog stick controls don't work properly. That happened to me on NFS Pro Street. If this helped you leave feedback please. FIXYA!
Feb 19, 2009 | Sony PS2 Dual Shock 2 Controller...
Sony Playstation 3 (PS3) Console Logo
71 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
