Question about AEG MCD343EUM 750 Watts Microwave Oven
Door latch has broken and is stuck inside locking mechanism
Hi, the hook broke and is stuck on/in the locking mechanism.
How do I get to teh broken hook it to get it out?
  • 1 more comment
  • robgreen Oct 19, 2008
    IT IS AN AEG MICROMAT DUO 3534E THE ENR # 947.602 262
  • robgreen Oct 20, 2008
    i have followed the good instruction to repair the latch head piece on the door successfully - thanks.
    How do I get the outer cover off to get to the locking mechanism?
  • William Miller
    William Miller May 11, 2010
    Please reply back with your brand and model number so we can help you.
  • AEG Master
  • 9,086 Answers
I'm not familiar with non-US models, but you would probably have to use needle nose pliers to pull it out.
If that won't work, you'd have to remove the outer cover of the oven, and then you can see how the door latch heads (the hook-like devices sticking out of the door) interact with the door latches and the opening mechanism.
Then you can call AEG at the number in your manual to see if they will sell replacement parts.
If you don't have the manual / IFU, then I would suggest contacting the manager at the dealership from which you purchased the oven to see if they have contact info for AEG.
To replace your latch heads, normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
Posted on Oct 19, 2008
  • William Miller
    William Miller Oct 21, 2008
    Again I'm not familiar with non-US model, so they may have some locks or latches I'm not aware of.
    But generally you remove all the screws in the outer wrapper / cover, then lift up and back to loosen the cover.
    In some cases, you may run into special screws.
    If you still need help, please post a couple of photos of the sides and rear of your oven.
How to repair kitchen aid door springs
proceed according and fix it. God bless you
  1. Open leverCheck your microwave lever to determine if it is damaged. If it is broken, simply replace the lever to get your microwave door fully functional again.
  2. Door springResponsible for keeping downward pressure on the door hook, the microwave door spring can begin to malfunction. If this part is broken and prevents you from opening your microwave door, replacement is necessary.
  3. Door latchOne reason your microwave door may not open properly is a broken door latch. Located inside the microwave, the door latch manipulates the door hook to keep the door closed for safety and top performance. If broken, the door could become stuck in the locked position.
  4. Door hookIf your microwave door will not release properly, the door hook could be damaged. Located inside the door, the door hook is made of plastic and prone to breakage with extended use or age. As this part is unable to be repaired, the only option is to replace it.
  5. Button or button springIf the microwave door will not open, it could be an internal failure of the button or button spring. If it is determined that either of these parts is the source, both are replaceable and it is recommended that they be installed at the same time.
  6. Handle actuatorIf the microwave door will not open the plastic handle actuator could be broken. Connected between the door button and the door latch assembly, this plastic part could become damaged and brittle over time, which makes breaking inevitable. If this occurs, replace the handle actuator to get your microwave fully functional again.
Nov 01, 2013 | KitchenAid Microwave Ovens
Microwave door alignment
test all this steps and fix it. God bless you
Oct 27, 2013 | Microwave Ovens
H5460NO/01 door lock is not working
test this steps and fix it. God bless you
Lock faults
Read more: http://www.appliancepartspros.com/repair-help/microwave-repair-help.html#11#ixzz2aaubHCcG
Jul 30, 2013 | Sharp Microwave Ovens
Door wont open
follow this steps and fix it. God bless you
Read more: http://www.appliancepartspros.com/repair-help/microwave-repair-help.html#11#ixzz2aSkJuabC
Jul 29, 2013 | Haier Microwave Ovens
The door doesn't open
please follow the instruction and fix it. God bless you
May 28, 2013 | Cuisinart Microwave Ovens
Broken plastic hook on inside of door
Hi
Please state the exact model number of the microwave. Also by broken plastic hook are you referring to the door latching mechanism? Please carify by adding a comment.
Many Thanks.
Oct 07, 2009 | Jenn-Air Microwave Ovens
NEFF H5470NOGB Microwave door latch fault
theres a small plastic hook inside the door which holds a tension spring this will have snapped off stopping the latch from entering the lock its actually quite easy to fix the inner plastic frame can be unclipped with a small flat blade screwdriver exposing the hook mechanism and the spring will be lying in the bottom of the door frame you can reconnect it to the metal inner frame it stretches the spring a little more but it will never snap again ive done this loads of times with no probs otherwise you will have to replace the outer door to reinstate the broken hook.
Oct 27, 2008 | Neff H5470 Microwave Oven
Broken latch microwave door - won't open
I have a semmins microwave working in great condition, last night the latch mechanism inside the microwave don't allow the door latch to close.Only the top portion, bottom portion is ok.
Sep 14, 2008 | Sharp R-1870 Convection/Microwave Oven
Panasonic s550bf Door Latch
Do you still have the piece that broke off? If so, you may be able to use two part epoxy to glue it back in place. I did this with a colaric MW and it did the trick. The latch was hook shaped and made from a hard plastic. Pete
Sep 02, 2007 | Sharp R-1610 Microwave Oven
AEG MCD343EUM 750 Watts Microwave Oven Logo
1,323 people viewed this question
Top AEG Microwave Ovens Experts
William Miller
William Miller
Kazim ERGUNEY
Kazim ERGUNEY
Raj Patel
Are you an AEG Microwave Oven Expert? Answer questions, earn points and help others
