Question about Hobart A200 Stand Mixer
A-200 mixer oil leak
Hello I see you answer a lot of peoples problems about this sized mixer. I bought one on ebay recently and it appears to have a slow over time leak on the mixer spindle if you will and from that nut. Basically seems like a seal overhaul is in order. I was planning on disasembling the unit so i could repaint it anyways. Starting to dig into the gear box now and am clearing out the grease. There is an awful lot in there. what grease replaces it? other thing I would like to know is since this unit is an older model I'd like to know if the seals i order will be ok for it. Basically it looks like I need part 'seal - oil 1in I.D.' for the planetary spindle leak. Then a bunch of orings on the main transmission shaft. Other thing is whats leaking is just some grease that over the years became less viscous and became almost like an oil? Or does this thing take oil somewere too? Seems to be all grease in there. Thanks.
  • 49 Answers
The trans uses all grease today hobart uses mobil lith aw-2 you can get the seal from any hobart office.
Posted on Oct 25, 2008
Where the beaters fit in, there is a small oil leak when using. It will probably get worse. Bought in 1996
Oil leaks are common. As oil is stretched it separates. If it is leaking over your nice silver "beauty ring" then the ring is not catching the oil. If it is leaking below the silver "beauty ring" then the gears in the planatary area has worn down too much and is separating.
In either case, you can wipe it up with use or do what a lot of DIY people do, take her apart and remove and regrease the unit. Search online for regrease kitchenaid mixer, I would post a link but I dont want the link to be broken down the road. There are tons of tutorials for it online. You remove the grease and replace it with new. I used automotive grease from autozone, but there is a specified grease for the mixer on kitchen aid's site. Depends how picky you are.
Kitchenaid does not grease under the planatary from factory anymore, they just dont see a need. (this is an area below the silver beauty ring I mentioned. It was metal on metal when I took apart my new mixer for check up. This may be why you have grease leakage too, it was an old standard to grease there, but there is not significant friction to warrant the heavy grease there anymore.
Hope this helps.
Apr 17, 2011 | KitchenAid K45SS Classic Stand Mixer
Hobart A-200 mixer gets hot and weak. Motor housing gets too hot to keep your hand on it. Service tech told me the motors usually don't go out. What other problem could it be?
I'd say you're most likely overloading the mixer. This mixer, and others similar in size, are frequently overloaded by people making pizza dough. If you are making dough, keep in mind the A-200's capacity is 9 lb. of 40% A.R. pizza dough, mixed for 5 minutes maximum. If you need to mix longer, the batch must be cut down even smaller, but I don't even know if you're mixing dough.
Try running the mixer unloaded (i.e. nothing in the bowl) for ten minutes or more and see if it gets hot. If it still gets hot, the motor's start circuit (varies depending upon age of the A-200; Hobart used numerous motors in the A-200 over the years, incorporating different starting circuits) most likely has problems. If it doesn't get hot when operating unloaded, then you're probably overheating the mixer by overloading it.
Dec 20, 2010 | Hobart A200 Stand Mixer
I have model A-200-D Hobart mixer. Serial # 1575984. It is leaking oil into the bowl. Who can I call to get an estimate to service or repair this machine?
The oil leeking into your bowl is old grease that has broken down into oil and is getting past your oil seal you need to take out all of your old grease and oil replace it with hi-temp grease or a good grade lithium grease and replace your agitor shaft oil seal
May 16, 2010 | Food Mixers
KitchenAid 250 Watts; Classic: Leaking Oil
Found this,may be helpful.
Why do I see oil leaking from the beater shaft of my stand mixer?
Some KitchenAid® stand mixers that are not used very often or have been tipped may experience slight oil leakage from the shaft or hub attachment. To avoid the oil leakage, KitchenAid suggests that you run the mixer weekly for short periods of time. Generally, the mixer may lose approximately X cup of oil before repair is necessary. The oil used is FDA approved and is not harmful to consume, should any get into the food that you are preparing.
Dec 15, 2008 | KitchenAid K45SS Classic Stand Mixer
K45SS leaks lubricant
Leaking of oil in a stand mixer is not necessarily indicative of a large problem.
Kitchenaid stand mixers are overpacked with oil to last the lifetime of the motor. If the motor sits idle for some time (is not used), the oil may begin to drip from the gears and settle. Oil leakage may primarily be seen from around the beater shaft or planetary action.
A stand mixer can lose up to a 1/4 cup of oil before it needs to be serviced.
It is recommended to run the mixer on speed 10 for 2 minutes in order to redistribute oil back into the motor. In order to prevent future occurences, this is recommended to be done every 3 weeks if mixer is not being used.
Exploded parts views for all mixers are available at www.kithchenaid.com. Click "Customer Care" in the upper right hand corner of the main page, and then select "Locate Manuals and Guides." You will need to enter the unit's model number exactly as it appears on the bottom of the mixer. It will be listed on a white sticker.
Nov 03, 2008 | Food Mixers
A 200 T grease leak & gear noise
The o-ring on the attachment hub gear is wirn causing the leak.If the mixer is old it wouldnt hurt to change the grease.
Sep 28, 2008 | Hobart A200 Stand Mixer
I went to Kitchen Aid'sKitchen Aid's web site and had an on line chat with a tect support person name Jessica. She told me that if the mixer is not used a small of oil will leak out. to fix the problem you must run the mixer for a few minutes every month or so. This seems to work.
Rick
Jul 28, 2008 | KitchenAid K45SS Classic Stand Mixer
Servicing Hobart A-200
these mixers dont use oil,they use grease.you will have to open the transmission to change the grease.any ? let me know im a hobart tech.
Jan 25, 2008 | Hobart A200 Stand Mixer
Leaking oil
thats the planetary seal thats leaking.the seal is cheap its the labor that may be costly.is it just a nuisance leak or a lot?you dont want any oil to get in your mix.
Aug 16, 2007 | KitchenAid KSM150PS Artisan Series Stand...
Hobart A200 Stand Mixer Logo
223 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
