Question about Microsoft Xbox 360 Console
Xbox 360 how do i connect to xbox live i have internet with aol on my pc and my laptop i got my xbox second hand and dont no how to connect it please help
    Scholar:
  • 44 Answers
I have attached a complete step by step instructional guide to get you hooked up to xbox live. I hope you enjoy the service and I hope I fixya problem.
Happy Gaming to you
Xbox live instructional guide:
http://www.xbox.com/en-US/support/connecttolive/xbox360/default.htm
Posted on Oct 19, 2008
Advent k200 wired xbox 360 internet
Make sure that your xbox account is connected to a Xbox live membership. If so go sign out, and then sign back in and it should Work.
Mar 24, 2013 | Advent Computers & Internet
I have a Cayman 3347w wireless router and I am trying to use one of the wired slots to connect my xbox 360 to the internet. the xbox will not connect. is this router xbox compatable?
Please try the following steps below;
To make a router connection to Xbox LIVE:
  1. Before you connect any cables, turn off your router, modem, PC, and Xbox 360 console. (Unplug your modem from its power source to turn it off.)
  2. Connect one end of an Ethernet cable to the Ethernet port on your modem and the other end to the Ethernet input port on the back of your router.
  3. With another Ethernet cable, connect one end to one of the router's Ethernet output ports. Connect the other end to your PC's Ethernet port.
  4. With the third Ethernet cable, connect one end to another of the router's Ethernet output ports. Connect the other end to the Ethernet port on the back of the Xbox 360 console.
  5. Turn on your modem, then your router, then your PC.
  6. Make sure your PC can access the Internet. If not, you may need to configure the router for Internet access. For help configuring the router using your PC, check the instructions that came with the router.
  7. Turn on your Xbox 360 console and sign in with your profile.
  8. If this is the first time you've turned on your Xbox 360 console, see Create Your Gamer Profile to get started with both the Xbox 360 system and Xbox LIVE play.
If you're unable to connect to Xbox LIVE, you can try to diagnose the problem right on your console. Go to My Xbox and open System Settings, then select Network Settings (setup XBOX using Automatic Configuration DHCP), Test Xbox LIVE Connection.
Hope this helps!
Mar 28, 2010 | Netopia Cayman 3347W-Ent Wireless Router
Dont no how to setup my xbox live using a t-mobile dongle in my pc???
Okay, here's what you do. Set up the dongle in your PC so internet is running.
Now Connect your Xbox to your PC with an ethernet cable.
Next Go to Start> Control Menu>Network Connections
Choose your internet of choice
Right click it
Choose properties
Click the Advanced tab
Check "Allow other network users to connect through this computer's internet connection"
Now try connecting to Xbox live. If that doesn't work go to Xbox Live Network settings and test connection.
Hope this helps you
Jan 27, 2010 | Microsoft Xbox 360 Console
HOW DO I CONNECT MY XBOX 360 TO INTERNET THRU MY DIAL UP MODEM?
Hello Brian
Using Xbox Live on Dial up Modem would be a big pain, still listing the steps for you, hope you have a stable connection to successfully connect
Required Items
- Windows ME, XP, Vista
- PC with dial-up connection working
- Ethernet Cable (RJ45) cable or CROSSOVER CABLE
- Xbox 360
Let's Get Started
1. First connect the Xbox 360 and the PC using the Ethernet cable.
2. Double Click your Dial-up Network connection and wait for it to connect.
3. Choose "Start Menu" and then choose "Settings" then "Control Panel".
4. Select "Network and Internet Connections".
5. Open the "Network Setup Wizard" and then press "Next".
6. On the next screen Ignore the checklist and press "Next" again.
7. Select "This Computer connects directly to the internet." and press "Next".
8. Now Select your dial-up internet connection as your default connection to the Internet and press "Next".
9. Select "Local Area Connection" as your private connection and leave all other areas untouched and click "Next".
10. On the Workgroup screen leave all settings alone and click the "Next" button.
11. On the next screen Turn on "File and Printer Sharing" if you want to share your files, mp3's, divx files with your xbox 360 and click "Next".
12. Now review the settings and click "Next" to apply the changes.
13. You do not need to run the Network Setup Wizard on any other pc's so just click "Next" and continue.
Now that the wizard has completed you may need to reboot your PC and dial your internet connection again.
Xbox 360 Setup
Now we have configured your PC to share its internet connection and files to your Xbox 360 we need to configure the Xbox 360.
(Steps for old Xbox 360 Dashboard, in case you do not have NXE dashboard)
1. Go to the "Xbox 360 Dashboard".
2. Select the "System" Blade.
3. Select the "Network Settings" Option
4. Now choose "Test Xbox LIVE Connection".
Your Xbox 360 will now attempt to contact your home network. It will check to make sure it can assign itself a IP ADDRESS from your PC and then it will also check DNS server information and XBOX LIVE.
let me know if this helps
Nov 25, 2009 | Microsoft Xbox 360 Console
My xbox 360 cant get a valid ip adress from my router to ad an extender to share media with my pc.And my internet connection is fine.
You dont need an internet connection to add an extender, but also if you are doing the xbox live network test, make sure you turn on INTERNET CONNECTION SHARING otherwise you will not connect,run a pc - xbox , then media connection test, etc, also make sure you have the media centre open on your computer also. Good Luck.
Nov 16, 2009 | Microsoft Xbox 360 Console
When connecting to xbox live, I cannot connect to the Internet
You may need to buy a Xbox 360 Wireless Adapter if you dont already have one
May 17, 2009 | Microsoft Xbox 360 Console
Can't connect with network
if u dont hav e a router that is ur problem. to get ur xbox 360 to connect to vista media center you cannot connect an ethernet cord directly to ur 360, u must have ur computer hooked to a router with one ethernet cord and a whole different ethernet cord connecting to the same router the computers hooked up to. after you do that go to ur vista media center, turn active sharing on, make sure your router is connected to the internet. then go to ur xbox 360 and follow the on screen instruction from the the connect to media center screen.
if your wanting to connect to xbox live and stuff like that, and u enter ur ip address and security information and it tells u that the ip adress u entered is already in use by another device, and that ur xbox 360 needs to be assigned one, do this: simply go to were u put in ur ip address and set it to get the address automaticly (or in other words choose automatic). then go to test connection (ur router should automaticly assign ur xbox 360 an ip address) and ur router should connect to the internet. if it connects to the internet but not xbox live then u have not yet sign up for an xbox live account.
by the way when u make an xbox live account please send me a friend request. my xboxc live account name is: ghdude22
glad i could help!!! :3
Feb 06, 2009 | Microsoft Xbox 360 Controller
Xbox 360 live on wireless router
In theory you should be able to "share" your internet connection. I use a Linksys WRT54GS wireless router and I have a Linksys Game adapter on my son's 360. He has not complained about lag or slow server times unless other intensive bandwidth is being used.
Nov 09, 2008 | Microsoft Xbox 360 Console
Xbox 360 to wireless laptop
Make sure ethernet cable from XBOX 360 is connected to one of the 4 access ports on the back of the router.
Mar 16, 2008 | Microsoft Xbox 360 Console
Exbox live
hey the cord you found was an eithernet cable that plugs from your xbox into your mondem at home. if your home internet is wireless you will have to buy a special wireless adapter for your 360. once its all plugged in go to connections on the 360's dashbored connect your xbox to the internet then follow the instructions to connect to xbox live you get a month free membership when you join
hope this helps please rate me
Grant
Nov 09, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
81 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
