Question about Maytag Washing Machines
My Washing Machine won't drain, the motor sounds but no spinning happens. Maytag Performa Model # PAV3240AWW
  • Anonymous Dec 12, 2008
    maytag neptune mah6700a with not drain. about 3 years old what is the problem?
    Prodigy:
    An expert who has answered 500 questions.
  • Maytag Expert
  • 517 Answers
You have blocked filter or pump has an object in it if machine is about 2 to 3 years old pump may need replacing
Posted on Oct 19, 2008
Maytag performa PAV2300AWW does not spin (wash cycle works fine). During the spin cycle the tub does not rotate...but i can hear the motor running...water drains...Pls help
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 29, 2010 | Maytag PAV2300 Top Load Washer
Maytag Performa PAV1000AWW. Motor buzzes but does not turn.
Your motor has gone bad...
If
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Aug 13, 2010 | Maytag Washing Machines
My Maytag washing machine does not really agitate
It sounds like the belts need replaced. There are 2 of them. One drives the transmission, and one drives the belt. They should both be replaced. Also, there are rollers on the motor bracket that wear. Make sure the motor moves smoothly back and forth in the bracket.
Jan 28, 2010 | Maytag Washing Machines
I have a maytag performa top loading washer, model # PAV3240AWW, that overflows. It doesn't happen every time and it doesn't matter what size the load is or what cycle I am using.
You have sand and sediment in the sump base of tub. All you di is remove the rubber hose on the water level switch and blow out the tube with your mouth. You will feel it when the **** is out of there. Then reconnect that hose tightly to the switch and pump out any remaining water in the tub. here are some repair photos
Oct 08, 2009 | Maytag Performa PAV3200
Washing machine won't go into a spin cycle.
check the lid safety switch for proper operation
Oct 04, 2009 | Washing Machines
Washer is making a loud noise when its trying to rinse
you will have to open up the panel to check where the smell comes from. It could be on the motor which may cause also a loud noise or from the electrical, loose connection or bad relay may cause a noise of a different kind.
Sep 21, 2009 | Maytag Performa PAV3200
My maytag washing machine spins but won't agitate.
sound like the agitator motor went out the way to fix this is to take the agitator out and replace it along with the motor
Sep 01, 2009 | Maytag Performa PAV2200
8-24-2009 5:55 P.M. I have a Maytag Performa PAV3240AWW top loading washer 2-3 years old has worked well for an active family of four until the last load of wash. It seemed to wash and rinse cycle OK when...
It sounds like the belt broke or the lid switch could be bad. Use a screw driver to manipulate the switch with the machine on. If you can tip the thing back enough to check the belt. I hope this helps.
Aug 24, 2009 | Washing Machines
Maytag washer m/n PAV3240AWW
I suggest changing the belt for a new one, in fact if this model has 2 belts, replace them both.
I ran 2 laundromats... this occured frequently due to over loading the machine and then the belt would get damaged just enough to foul up the proper agitation and the spin/drain cycle.
Just change the belts and i'll bet that will get you back into service!
Let me know.
K
May 26, 2009 | Maytag Washing Machines
WASHING MACHINE
There could be a couple of reasons for this. When this occurs, look to see if the load is evenly distributed around the circumference of the tub. If not, redistribute and continue with spin cycle. The machine may not be level. Check to ensure that the machine's leveling legs are making contact with the floor and that there is no movement when you attempt to rock the machine. If the unit is sitting on a soft floor, this could happen from time to time.
Jan 26, 2008 | Maytag Performa PAV3200
Washing Machines Logo
238 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
