Question about Kenmore 23822 Top Load Washer
My Kenmore Catalyst's control panel is flashing "PF"
Some time during a wash cycle the machine stopped. I found it still filled with water and it seemed to be without power. I unplugged it and then plugged it in again, and now it just flashes PF. None of the control buttons do anything.
  • 1 more comment
  • J_ROB Dec 15, 2007
    i have the same exact problem with my washer, did you ever find a solution to it? if so PLEASE let me know
  • Anonymous Mar 13, 2014
    The power off button does not work on my Amana nfw7200tw. And, occasionally nothing works on the control panel. The only way I can get the machine to work is to unplug it and then plug it back in.
PF means power failure
the power must have went out in your home some time during the day or night
Posted on Feb 16, 2008
Flashing fp on my washing machine and stops half way through cycle please help
"PF" flashes if the washer loses power during a running cycle. The washer does not flash "PF" when it is first plugged in. Press START to continue the cycle from the moment that power was lost
-OR-
Press STOP/CANCEL to clear the display and completely cancel the cycle.
Sep 28, 2011 | Whirlpool AWM8143 Front Load Washer
I have a kenmore model 110.28922790. It will not stop filling with water. What would be the likely cause?
the water pressure/level fill switch under the control panel is defective,it uses water level/pressure per you setting on the control panel for wash load size to fill it to the set level,then start the washing cycle after it fills
Mar 23, 2011 | Kenmore Washing Machines
Our washers keep flashing LF after the wash cyle and stops workin, not spining very fast either.
Hello there :
the Dreaded LF code means
LF Long fill If the water fill time exceeds ten minutes, the water valves are turned off and "LF" is flashed.
Press STOP/CANCEL to clear the display.
check the water controle inlet valves that are attached to the machine for proper operation and replace if found bad
Jan 07, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
It turns on and fills by itself. sometimes it
a bad water valve could cause this / if it leaking through . when the tub is full it will start itself and cycle . / also the control if bad would do this .. mm
Dec 03, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Washer stuck
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 01, 2009 | Kenmore 42822 Front Load Washer
Machine doesnot agitate or drain once filled with water
it sounds like a bad lid switch if it will not drain or spin,the switch controls that-mike
Apr 24, 2009 | Washing Machines
Code pf came up and the washer does nothing
PF Power failure "PF" flashes if the washer loses power during a running cycle. The washer does not flash "PF" when it is first plugged in.
Press START to continue the cycle from the moment that power was lost.
OR
Apr 01, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Pf and of codes comming up on screen
PF - Power Failure - PF error code indicates a power failure during the dryer's cycle. Press and HOLD start to continue the cycle, or press off/pause to clear display.
Feb 11, 2009 | Kenmore 22422 Top Load Washer
Kenmore 22082
OL on my washing machine
May 17, 2008 | Kenmore 22062 Top Load Washer
Washer stops during wash cycle
you may a pluse cycle where the washer will stop for a couple of min, this cycle is for perm press to minimize wrinkels
Nov 12, 2007 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore 23822 Top Load Washer Logo
326 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
