My viking got stuck in reverse. I had remembered reading something about that on this site. RickE1 said to try a few things. It got stuck in reverse several times and I had to try several solutions he suggested. The last one I tried was taking the cam off and using a blow drier. Only I never got to blow drying because there was a wire behind the cam hanging there. So I tried to grab it before I blew it into the inside of the machine with the drier. Instead it just fell into the machine as I was trying to grab it . So I did exactly what I was trying to prevent. ha ha ha. Funny how life plays little tricks on you. So I didn't keep sewing. How do I get it out? Will it hurt the machine? What do I do?
MamaT
SOURCE: Viking Husqvarna model 6440 gets stuck in reverse
There are numerous things that can cause this, some very simple, some less so.
1. Fortunatly, the most common one is also the simplest to cure. When you turn the selector (upper left) knob between stitches, one of the things that is happening when you feel the resistance is that it is lifting the followers off the camstack so that it can move to another stitch. When the camstack is normally doing its job, lifting the feed cam follower is what puts the mechanism in reverse. So, while the selector is between stitches, the machine is temporarily in reverse. Also, the dots where the dial is to be placed to change the camstacks is between stitches, so if the dial is on these dots or anywhere else except snapped into a stitch, you will get nothing but reverse.
2. The buttonhole mechanism is stuck in the reverse portion of the buttonhole. Usually if this is the case, the needle position will also be stuck on the left side, and the width control /buttonhole control will not function correctly. Usually you can correct this yourself and I'll explain how in a bit. It is usually caused by lack of use of the buttonhole mechanism.
3. Either the arm that connects the camstack to the stitch length block or the block itself is stuck. Both these parts are spring loadedto bring them in the forward position, so long periods of rest are a contributing factor.
All of these causes except for the first one are because of the mechanism not being exercised frequently enough. These older Vikings do not like to sit still very longYou should fully exercise all the knobs at every sitting.
Ok, try this fix. And this is to free up the mechanisms that are probaby stuck from non use and old oil and grime buildup. Take your seamformer (cam) out of the back. Find a hairdryer and blow some heat in there for awhile. This will soften up any hard oil or grease that may be causing the mechanisms to stick. Then if you can it would be best to have what is called TRI-FLOW oil (the BEST) and spray or drop quite a bit into there covering the mechanisms and let it soak in. You might try a good sewing machine oil soaking or WD-40 in small amounts. Little by little test your knobs, slowly working whatever is stuck lose. Never force the issue. Small amounts of movement little by little will eventually free it up.
Good luck. Hope this helps. If this does not help you may have to take it to a technician and hopefully you won't find out that your take up slide isn't broken which is a major job.
SOURCE: Kenmore 385 sewing machine gets stuck in reverse
Make sure that your machine is set to sew forward. The reverse button on your machine should have a spring loaded return. If the spring is in place, and doesn't appear stretched, try a drop (just a drop) of sewing machine oil. Please use sewing machine oil. Not WD-40, or any other household oil. If the machine hasn't been serviced in a while, or used alot recently, they knob may need to be "reminded" that its supposed to go in and out. :) After applying the oil, push the knob in and pop it back out like you have been. If nothing else is wrong, it should loosen up and move freely.
SOURCE: reverse sewing button stuck HELP!!
MOdel 6430 has the stitch length and buttonhole selector on the same knob. It is the one on the bottom right side of the machine. I believe you may have selected the buttonhole by pulling out on the large round knob. You need to turn the knob back to 0 zero and push in. This should return the machine to normal mode.Adjust your stitch length to 3 and try it. The reverse knob in the center should also stick out so that it becomes operational again.
sewman7
SOURCE: When I try to sew my machine jams a little every
Although you already re-theaded and cleaned your machine, re-check this:
- Un-thread your machine and remove your bobbin. Clean any loose thread or lint out of your bobbin case. Re-thread your machine, reinsert and rethread your bobbin.
If that doesn't work, try this:
- Change your bobbin.There could be a nick along the edge of your bobbin spool that’s catching your thread as you sew.
- Raise your feed dogs if your machine has this feature.
Note:
when you start to sew a seam, hold the upper and bobbin thread tails. Hold them back and out of the way as you sew your first couple of stitches. This will keep them from getting caught in your machine.
Hope this helps.
SOURCE: reverse stitch lever not "activating" the feed dogs to go in reverse
Likely old oil and lint forming "glue" in the mechanism....suggest a General Service if you are not willing to clean this yourself, or more than 2 years since last service
