Question about HP DeskJet 5150 InkJet Printer
Cartridge carrier stuck
The printer could make alot of noise while load a paper for printing for some time. I didnot worry about since it was perfectly printing. One morning it contnually started to blink it start and resume buttons indicating an error. When I opened it top cover I discovered that it was attempting to move the ink cartridge carrier but it was stuck in it starting posistion. Todate no solution as I have no service manualto guid mein the opening and isolating the course
  • Anonymous Dec 27, 2007
    the cartridge is stuck at thr right. it is not manually movable at all.
  • carla5672 Apr 04, 2008
    I changed the cartridges and now the cartridge carrier is stuck and the power light and resume light are flashing, the only thing that I can see that may be causing this is the the black square box bits in front of the cartridges are lifted up, this has made removing the re-inserting the cartridges very difficult, can you help me
    President:
  • HP Master
  • 2,022 Answers
Just open the cover and out oil or any lubricant on the rod of catridge carrier and and manually move the head from left to right at for 5 to 10 times. but doind all these thing make sure your printer is completly off. bye
Posted on Sep 28, 2007
I just ran into this problem myself and whats happening is your ink cartridges are stuck on the black thing below them (i think its called a service station).
what u have to do is either take it apart which i did and to bottom right of the service station is a white gear with a pretty small gear below it leading into the service box so what u wanna do is turn the large gear clockwise, it might be a bit hard to push because it is obviously jammed and once it turn you will see a black rod moving towards the back of the printer keep on turning it until the black box thing (service station) drops down and frees your ink cartridges. once u turn it on i had troubles getting it to work because it was all messed up so u might have to reset the printer after this.
alternatively you might be able to reach the spindle u have to turn without taking the printer apart i haven't tried it because i just finished running my wires and restarting my printer to be bothered. anyways theres a little opening at the bottom right of the printer and u might be able to get a small flat head screwdriver in there to turn it. i wouldn't advise it because theres a lot of small boards u can scratch and damage in the process.
best of luck
tense_lion
Posted on Oct 22, 2008
    Scholar:
  • 87 Answers
U will have to get that lid shut before the carriage will move...try a screwdriver and push it down...otherwise the machine will have to be taken apart.
Inkworks
Posted on May 22, 2008
  • Orn Wilson
    Orn Wilson Nov 06, 2008
    These problems sound like the service station is not moving for some reason or another. Could be a failed motor or it could just need to be cleaned. Excessive ink buildup that drys and hardens can hinder free flowing service station movement which will give you a carriage jam error etc. Disassemble machine and clean service station. We do this repair for $45
    Inkworks
    866-381-0541
Where do I put the replacement cartridges?? I can't see where it goes on this printer???
here is your answer this was found here in your manual if you need it heres a link with picture instructions. start on page 15
MANUAL:
Open the printer, and then press down on the print cartridge carrier levers.
Open the color cartridge foil, and then remove the cartridge from the pack.
Remove the tape from the color print cartridge, insert the cartridge in the right carrier, and then close the color
cartridge lid.
If a black print cartridge is included in the box contents, open the black cartridge foil, and then remove the
Note: You may need to purchase a black print cartridge separately.
14 Remove the tape from the black print cartridge, insert the cartridge in the left cartridge carrier, and then close
the cartridge carrier lid.
Close the printer, and then load plain paper
Mar 26, 2010 | Lexmark X4650 InkJet Printer
Lights are flashing on printer and it will not print . the voice says there is a problem with the printer. I did the alignment process but the voice keeps saying there is a problem. I took both cartridges...
There 3 light on the printer that able to indicate to user when problem occur. Which is the light u mean here?
1st button light blink rapidly = the printer may be out of paper, so load more paper and press the 1st button itself to continue. Or may be paper jam is occur, so clear the paper jam and press the 1st button light itself to continue.
If 1st button light blink slowly = mean the cartridge carriers are stuck, so raise the scanner unit and remove any object blocking the path of the cartridge carrier, make sure the cartridge are closed and installed properly, then lift the scanner unit, gently push the scanner support towards the cartridge carriers, and carefully lower the scanner unit until it is completely closed. After that press the 1st button itself to continue.
If 2nd LED light blinking = the color cartridge need to be replaced soon.
If 2nd LED light is ON = the color cartridge need to be replaced immediately.
If 3rd LED light blinking = the black cartridge need to be replaced soon.
If 3rd LED light is ON = the black cartridge need to be replaced immediately.
YBC (/\)
Sep 28, 2009 | Lexmark X2500 All-In-One Printer
I get a clicking noise when I print on a Dell 3115
The print cartridge carrier could be stuck and clicking agains the wall or gears might be clicking.
If your machine doesn't work at all, open the cartridge cover, take the cartridges out, close the cover, wait for it to call the carriage carrier to the side, then turn it off, unplug wait 2 minutes, plug it back in, turn it on, open the cover, install the cartridges back, close the cover and try printing again.
If that doesn't solve the problem follow these steps
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
If the problem still remains
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
After you have done all the suggestions, whats the status of your printer, are you still unable to print? is the printer still just clicking? are you able to remove the cartridges from the machine or is it just clicking?
If your not able to do the suggestions or the cartridges won't come to the center, your printer has a mechanical hardware problem that will require service.
Sep 05, 2009 | Computers & Internet
The amber lights are blinking next to the printer icons and exclamation points on top of the printer. How do i get that to stop so my print job can go through?
YBC (/\)
Aug 06, 2009 | Lexmark X2500 All-In-One Printer
White line going down printed page
Hello sir; you need to clean print head and cartridge seat, follow the steps; turn power on open top cover (as when you replace cartridge)let the cartridge carrier move to the center the UNPLUG the power the carrier will stay in the middle you can it freely, move it away from seat should find alot ink stick, remove it, clean out wipper blade and print head it should take care of your problem.
Jun 04, 2009 | HP Office Equipment & Supplies
HP LaserJet 1320 folds over top left corner of every page printed
I see this problem alot after a paper jam occurs and someone has pulled the stuck paper out. There is probably a piece of paper stuck in the printer somwhere. If you open the front toner door and take the cartridge out, you will see a roller at the bottom front. DON"T touch the roller but take it out. You may find the paper there!
May 24, 2009 | HP LaserJet 1320 Printer
Dell 944 carrier jam
THE CARRIER MAY HAVE A FINE PEACE OF PAPER STUCK IN THE FEEDER ROLLER OR IN THE ROLLER PANS, REMOVE EVERYTHING, GET A CAN OF AIR AND BLOW IT OUT GOOD AROUND WHERE THE PAPER FEED AND EXITS THE PRINTER, THE CARTRIDGE MAY MAYBE GETTING SNAGED ON THE PRINT HEAD ALSO. SHACK THE PRINTER UPSIDE DOWN TO GET ANY TYPE OF MATTERAIL IN THE MACHINE, IT CAN BE PAPER, PAPER CLIP, STAPLE, PENCIL, ERASER MATTERAIL,
INK BUILD UP ON THE ROLLERS, CHANGE THE TYPE OF PAPER YOU ARE USING, IT MIGHT BE CHEAP PAPER PRODUCTS, LABEL GUM STUCK INSIDE THE PRINTER HOUSING AND EVERY TIME YOU USE IT JAMS.
ROD
Feb 13, 2009 | Dell 944 All-In-One InkJet Printer
Epson 1280 ink carriage making noise and not printing
hello there. try re-seating the cartridge. Take it out, then put it back in.
Nov 28, 2008 | Epson Stylus Photo 1280 InkJet Printer
Lexmark x3550
Changing print cartridges Changing print cartridges Removing a used print cartridge
  1. Make sure the printer is on.
  2. Lift the scanner unit.
    The print cartridge carrier moves and stops at the loading position, unless the printer is busy.
  3. Press down on the cartridge carrier lever to raise the cartridge carrier lid.
  4. Remove the used print cartridge.
Note: If you are removing both cartridges, repeat step 3 and step 4 for the second cartridge. Installing print cartridges
  1. If you are installing new print cartridges, remove the sticker and tape from the back and bottom of the cartridges.
    cartridge_tape_remove_one_2.jpg Warning: Do not touch the gold contact area on the back or the metal nozzles on the bottom of the cartridges.
  2. Press down on the cartridge carrier levers to raise the cartridge carrier lids.
  3. Insert the black cartridge or the photo cartridge in the left carrier. Insert the color cartridge in the right carrier.
  4. Close the lids.
  5. Close the scanner unit, making sure to keep your hands out from underneath the scanner unit.
    scanner_unit_close_2.jpg The control panel display will prompt you to load paper and press button_select_0.jpg to print an alignment page.
    Note: The scanner unit must be closed to start a new scan, print, copy, or fax job.
Jul 22, 2008 | Lexmark X3550 All-In-One Printer
HP DeskJet 5150 InkJet Printer Logo
346 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
